Old 12-24-2013, 03:11 PM   #1
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Tune for Daily Driver
Hey guys,
I looked around here a little and didn't see a thread specifically for this so I thought I'd make one. I was just wondering what tuning software is recommended for a daily driver. I'll list what I'm planning on putting on the car and what my general goals are for the tune and performance.
Mods:
FT-86 Speedfactory UEL Catted header.
Nameless resonated/catted downpipe/overpipe combo 2.5"
PERRIN Catback exhaust 2.5"
Injen intake (Or maybe a drop-in filter to save some money)
I mostly want the tune to make the vehicle as efficient as I can with these mods, while still keeping it operating right. I don't know much about tuning, just that it can be more efficient for the car. I don't want to do anything that can mess up the engine or damage it. Also not looking for an E85 tune. Is there anything that fits this? Nice, clean, efficient, but still with some gains.
This is a daily driven car and most likely won't see any tracks. It may, in the future, see auto-x, but that's nothing I'm planning right away.
Nevermore is offline
Old 12-24-2013, 03:43 PM   #2
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
Right now I use OFT, and I don't have your mods, but I will install this winter a UEL header, and so far, I have no complain to do! and it is my daily drive!
If I would lend my car to someone, he wouldn't notice it's a modded car, he would just find it more powerfull than a standard model!
Walla Walla is offline
Old 12-24-2013, 03:51 PM   #3
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
subbed sounds like exactly what i need
eddieEndo is offline
Old 12-24-2013, 04:04 PM   #4
WRB5titch
Drives: WRBrz
I too have the OFT and let me tell you, it's fantastic. First thing I noticed was the car ran much smoother, torque dip, while still present was barely noticeable. Overall drive-ability improved! Not only that, when/if you ever decide to try out e85 you can with ease!
Daily Driven.
In case you're wondering my mods are Stock header/Nameless 2.5 axelback/TRD drop in filter
WRB5titch is offline
Old 12-24-2013, 05:21 PM   #5
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks for the recommendations OP- if you need more info on the OFT, you can visit the website at www.openflashtablet.com
Starting January, OFTs come pre-programmed so all you do is plug it in, press a button to read the stock ECU file and then another button to select what tuned file you want and then another button to flash your ECU. It is literally plug-n-play. There is no longer any need to connect to a laptop and manually upload a tuned file that you downloaded from the website (as currently described in the Getting Started tutorial video). If you have any questions, feel free to ask or email sales@vishnutuning.com. The office is open on Jan 2nd and I'm sure the guys won't take too long to catch up with emails
Shiv@Openflash is offline
Old 12-24-2013, 05:58 PM   #6
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
OF MF'in T
SloS14 is offline
Old 12-24-2013, 07:11 PM   #7
Shagaliscious
Drives: Firestorm FR-S (MT)
Will you still be able to download tune files with the pre-programmed ones? Or will you only be able to use the pre-programmed tunes?
Shagaliscious is offline
Old 12-24-2013, 07:31 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Yes you will still be able to upload/download tune files from the download section of our website. You can write right over the tune files that were preloaded on the OFT.
Old 12-24-2013, 08:11 PM   #9
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
But the OFT doesn't do logging yet does it? Isn't it important to keep an eye on AFR, fuel trims, knock, etc? If you just preempt a button and drive, how do you know how it's working? I'm just curious, since I've been learning about my tune.
mike_ekim1024 is offline
Old 12-24-2013, 08:16 PM   #10
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
It totally logs now
FrsDuke is offline
Old 12-24-2013, 08:21 PM   #11
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I'm very new to modding, what is this logging I keep seeing everyone talking about and how difficult/important is it to do and keep up with?
Old 12-24-2013, 08:47 PM   #12
jamesm
you might pay someone else to change your tires, but you still check the pressure and tread depth every once in a while. it's kinda like that.
i'd say if you're paying for an e-tune or running an ots map, it's important to log initially and confirm everything is good to go, then maybe check it by reviewing a quick drive every so often, or when anything about your setup changes.
it's not something you have to do regularly once everything is known-good, but at the same time you do need to do it. the car isn't going to e-mail you if there's a problem.
jamesm is offline
Old 12-24-2013, 09:07 PM   #13
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
What do you do with a tune if you do data log and find an issue? With all tunes, unless you know how to custom tune, you either leave the tune or flash back to stock. That sucks. Of course, you could always pay additional monies to customize your tune by a trained tuner. At least this way you know a pro is reviewing your logs specific to your car moda and tune. I hope OFT has plans to offer a service down the road.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline
Old 12-24-2013, 09:07 PM   #14
FA20Club.com
Drives: 2013 White Out FR-S
No OTS map on this car can go without some sort of verification via logging. its best to go with a tuner that supports this as a viable option. And a detailed logging system is quite important.
FA20Club.com is offline
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 02:05 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
