go_a_way1
Old 12-22-2013, 04:11 AM   #295
CSG Mike
CSG Mike's Avatar
Originally Posted by brn12345 View Post
@CSG Mike I have a question on how my car handles. The setup is as follows:
- WedsSport TC105N 17x8 +42 with BFGoodrich Rivals 225/45/17 (32psi pressure cold)
- KW Clubsport set as follows:
Front: Compression 7 clicks out - Rebound 9 clicks out
Rear : Compression 7 clicks out - Rebound 9 clicks out
Ride height (not sure how to measure this but I set it about 1.5" higher than KW recommends measuring from hub center to fender, was too low at the recommended 12.6")
- Whiteline endlinks front, Perrin endlinks rear
- Car is corner weighed for 50% cross weight
- Alignment is:
Front camber -2.5 with 0 toe
Rear camber -2.0 with +0.03 toe in on each side
The car is significantly lighter in the rear because of wheel, tools, and stock muffler removal (running Tomei 60s catback). The car exhibits corner entry push, in the middle of the corner it grips, and on throttle application for corner exit the rear end breaks loose.
I don't necessarily dislike the way it handles, but I want to decrease the corner entry push, prolong the mid corner grip and decrease the quickness the rear end breaks loose on exit. So just if this visual helps, currently I have this:
Entry Mid Exit
UUUUUUUUGGGGGOOOOOOOOO
This is what I want:
Entry Mid Exit
UUUUUGGGGGGGGGGGGGOOOO
U is understeer, G is grip, O is oversteer
Try more front camber, and 0 rear toe.
Also, cold tire pressures don't matter. Only pay attention to the hot pressures. You're probably too high hot
Old 12-22-2013, 05:29 PM   #296
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
So regarding shoes and gloves for track use, which ones do you guys prefer? I need a set of gloves for karting being winter, but ill be using them for track next season. I get sweaty hands so they will need to cool, yet keep em warm for winter. Also for shoes, since i drive 4 hours a day for work, sometimes my feet get really uncomfy so i was wondering which shoes are nice to be at the track with, yet still be comfy for walking/being at the paddock etc.
bkblitzed is offline   Reply With Quote
Old 12-24-2013, 08:54 AM   #297
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I don't wear gloves so I don't know about all that but I do wear puma race shoes and they are very comfortable and affordable. I will also say that almost everyone I know that wears gloves use Simpson. They are probably the best but they run $50-$100 per pair while puma shoes run $30-$50 a pair so your gloves might cost more than your shoes.
Sent from my Q10
Old 12-24-2013, 10:44 AM   #298
CSG Mike
CSG Mike's Avatar
I use Puma shoes, but use whatever is comfortable and gives you feedback through the pedals (particularly the brake pedal).
Puma just had a sale for 20-50% off, and then 30% off any order over $100, but the driving shoes rarely go on sale. They were mostly full price, but eligible for the 30% off $100
Old 12-24-2013, 10:59 AM   #299
ayau
Drives: Some rust bucket
Minus mechanical issues, yes, the BRZ is a great platform to start with, particularly if you're into deep customization of the car, and want to learn how to drive.
The platform has immense potential, and can teach you to drive, but at the same time, doesn't bite you hard in the ass like the S2k does. It communicates better, and corners well. It's just not as reliable or as well prepared as the S2k out of the box, but the S2k also had a 9k higher MSRP.
If you want a firm indication, we have a 2nd BRZ now.
Is this a good thing or a bad thing?
Good being that CSG still sees potential in the platform.
Bad being that you're on your 2nd car already (first car had issues).
Old 12-24-2013, 11:56 AM   #300
CSG Mike
CSG Mike's Avatar
Specifically, we now have two BRZs
Old 12-24-2013, 04:40 PM   #301
bkblitzed
is better than you
bkblitzed's Avatar
yea it just sucks that i dont have any shops near me that sells driving shoes or gloves, even though i live 10 minutes away from Laguna seca haha. I bought some momo gloves just cus a friend has some and he loves them. Gonna see if i can try and find shoes soon. Thanks for the recommendations!
Old 12-24-2013, 05:15 PM   #302
CSG David
CSG David's Avatar
While Mike uses cool racing shoes, I use Vans, Etnies, or whatever good skater shoes to drive with. In other words, comfort is key while still being able to feel the pedals. With that being said, that's probably why Mike is "the driver" of CSG and not me...LOL
Old 12-24-2013, 05:44 PM   #303
bkblitzed
is better than you
bkblitzed's Avatar
yea i always just wear hightops when driving or karting lol. But after a while the heel starts to get irritating and they dont breathe that well.
Old 12-25-2013, 10:18 AM   #304
bukit
Drives: 2013 Subaru BRZ, 2011 VW Golf TDI
Try wrestling shoes, although they're not flame retardant, they'll provide good pedal feel. I'm sure you can find them at your nearby sporting goods store.
bukit is offline   Reply With Quote
Old 12-25-2013, 04:41 PM   #305
bkblitzed
is better than you
bkblitzed's Avatar
Also thinking about buying the Bell Sport SA2010 Auto Racing Helmet. My Simpson Bandit is pretty worn out. It was either the bell or the HJC Motorsports AR10 II SA2010 Auto Racing Helmet. Reason i chose these 2 is for the ventilation and the price. Im leaning more toward the bell though.
Old 12-25-2013, 05:15 PM   #306
robtan
such handling many wow
robtan's Avatar
Drives: '14 Scion FRS
For starters merry Christmas. I would like to know what a good tire would be for stock suspension and upgraded brakes(brake ducts, rotors, pads, ss lines etc).
Thanks in advance.
robtan is offline   Reply With Quote
Old 12-25-2013, 05:20 PM   #307
Stevo22
Stevo22's Avatar
Drives: GR86
The favorite street tire around here is the RS3.
Stevo22 is offline   Reply With Quote
Old 12-25-2013, 11:41 PM   #308
gbrz
is painters tape an effective way to protect your paint on the track? i was thinking of covering the bumper, front of fenders, hood, mirrors and behind the tires/wheels
gbrz is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
