Old 12-21-2013, 07:25 PM   #1
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Simple frs coolant question
Hi guys
So today I decided to check my coolant level on my frs and on the reservoir it was between the low and full mark when cold wich is good but here is where I'm not sure, I then decided to open the radiator cap to see if there was any coolant up to the filler neck and it wasn't, it seemed a bit low.
Is this normal? Mind you the weather here is -17 degrees Celsius
Thanks guys
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 12-21-2013, 08:35 PM   #2
Danny86
Danny86's Avatar
Drives: 2013 Scion FRS Raven Black M/T
According to the manual it says it should be between full and low when the car is cold. So that's normal. But it says if you're low or a little under fill it up to full. So it couldn't hurt to fill it up just make sure you get the OEM Toyota or Subaru super coolant aka the blue one. If you mix another color it shortens the lifespan.
Sent from my SCH-I545 using Tapatalk
Danny86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Danny86 For This Useful Post:
humfrz (12-21-2013), Young_makaveli (12-21-2013)
Old 12-21-2013, 09:37 PM   #3
Young_makaveli
Drives: 2013 frs
Yeah thanks but the manual says nothing about the radiator level
I can see the fluid but it's not to the top was wondering if thats good or bad
Old 12-22-2013, 12:16 AM   #4
I figure that if the level is at the proper place in the overflow tank ...... after the coolant warms up ...... it will be at the proper level in the radiator.
Not to worry....
Yes, back in the day, one could look into the top of the radiator and see if the core was covered with fluid. That's because the top portion of the radiator was the reserve "tank".
Danny86 (12-22-2013), Young_makaveli (12-22-2013)
Old 12-22-2013, 12:20 AM   #5
Young_makaveli
Drives: 2013 frs
Not to worry....
Thanks man I guess if my level at the overflow gets under the low level when cold then I'll top it off
I won't touch the rad
Thanks for all the help guys
Old 12-22-2013, 12:42 AM   #6
You're quite welcome.
And if you do add coolant to the tank, like @Danny86 mentioned, be sure it's the Toyota stuff that you add.
Some say it's OK to "top it off" (don't get it too diluted) with "distilled water", NOT to be confused with regular bottled water.
Distilled water can be purchased at hardware stores or some drug stores.
Happy Holidays!
Old 12-22-2013, 12:43 AM   #7
Young_makaveli
Drives: 2013 frs
Yeah I think it's best to go to subaru and get their Bleu coolant
The Following User Says Thank You to Young_makaveli For This Useful Post:
humfrz (12-22-2013)
Old 12-22-2013, 04:09 AM   #8
Danny86
Danny86's Avatar
^this. Yes it is. Some people complain that the bottle costs $30-40something, but honestly it lasts like forever. Toyoburu claims this super coolant lasts like 10 years or roughly 100k. Why would you not get it?
Old 12-22-2013, 05:43 AM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
11 years and I think 137k miles. After that it's 7 years/70k Miles I think.
Old 12-22-2013, 09:11 AM   #10
Danny86
Danny86's Avatar
^ what he said!
Old 12-22-2013, 10:46 AM   #11
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
I topped mine off with distilled water while my blue mix is on order from Toyota because it was close to low. Probably will have to get a straw and suck out the distilled water when it arrives LOL
EDIT: Can anyone confirm if this is the super coolant you guys are talking about?
http://www.toyota.com/owners/web/pag...52&partNo=part
Found some off ebay for 16 bucks: http://www.ebay.com/itm/Genuine-Toyo...-/310197176760
or Subaru's: http://www.fredbeansparts.com/subaru...e-coolant.html
chiefshayan is offline   Reply With Quote
Old 12-22-2013, 10:58 AM   #12
FR-S Matt
Not the right stuff. I got mine off Amazon and the color should be blue on the front as you will see in the picture below. Part number is 00272-GTBC1.
[ame="http://www.amazon.com/Genuine-Toyota-Fluid-00272-GTBC1-Coolant/dp/B00AKYP114"]Amazon.com: Genuine Toyota Fluid 00272-GTBC1 Blue Super Long Life Coolant - 1 Gallon: Automotive[/ame]
This is what you are looking for and it's $38
The Following User Says Thank You to FR-S Matt For This Useful Post:
chiefshayan (12-22-2013)
Old 12-22-2013, 11:03 AM   #13
chiefshayan
Thanks! Cancelled my other order and buying this
Old 12-22-2013, 11:36 AM   #14
Danny86
Danny86's Avatar
This is the Subaru variant in case anyone was wondering.
chiefshayan (12-22-2013), Muskokan (12-25-2013)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 07:50 PM
Simple rear badge question Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 7 02-28-2013 12:51 AM
A not so simple question. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 10 01-18-2013 08:40 PM
Simple Question! Spencer Strayer Scion FR-S / Toyota 86 GT86 General Forum 0 09-09-2012 06:53 PM
