Old 12-21-2013, 02:13 PM   #43
jamesm
Originally Posted by 350matt View Post
chap those aren't the VVT maps to tweak - you adjust the 'low det' maps as those are the ones used when the car isn't detonating
yes... those would be more clearly labeled 'whatever map' and 'whatever map (SAFE)' like in the other programs. it's not exactly clear what 'low det' means without looking in the docs.
Old 12-21-2013, 04:57 PM   #44
Kodename47
Kodename47's Avatar
Drives: UK GT86
Or just look at the VVT threshold table below
What do you need to do if running no primary cat? Just disable the CEL code or is there a setting for the rear O2 sensor that needs altering?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-21-2013, 05:00 PM   #45
Victor Draken
Drives: Toyota Gt86
Anyone could explain what's the traction Control modification you guys are Talking about
Victor Draken is offline   Reply With Quote
Old 12-21-2013, 05:03 PM   #46
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Disable P0420 in the DTC list.
That is the code for Cat Efficiency.
Deadspool is offline   Reply With Quote
Old 12-21-2013, 06:25 PM   #47
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks mate, i knew it was one of them. There is a setting for the rear O2 sensor, I can't remember exactly what as I'm not on my laptop, but it says to zero them if you remove the sensor. Is that worth doing if the cat is removed? Does the rear sensor do anything other than just check cat efficiency?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-21-2013, 07:00 PM   #48
jamesm
no. you'll zero out the AF Correction #3 Limit values only if you remove the rear o2 sensor.
Old 12-21-2013, 07:31 PM   #49
Kodename47
Kodename47's Avatar
Drives: UK GT86
Any idea what that setting does?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-21-2013, 07:35 PM   #50
jamesm
it limits the values that can reside in af correction #3 lol
Old 12-21-2013, 07:56 PM   #51
Deadspool
Much title. Wow.
Deadspool's Avatar
I have been trying all morning and no luck....
arghhhhhh it's still broked!
Old 12-21-2013, 08:33 PM   #52
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
give it some time, should be back up soon. They're normally very reliable but there was an issue with this update being the first retail release ever for them.
Xero-Limit is offline   Reply With Quote
Old 12-21-2013, 09:31 PM   #53
Deadspool
Much title. Wow.
Deadspool's Avatar
Definitely.
I've never seen a software release go smoothly on the first day, its just how it is.
I just want to play with my new toys
Old 12-21-2013, 09:36 PM   #54
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'm not going with ecutek and already have an openport, but I LOVE the vitality, competition, and array of choices. FT-86 FTMFW.
Old 12-22-2013, 10:07 AM   #55
Visconti
Drives: 05 STi
The servers are back up, I also had them add the DI ratio tables for you guys
Visconti is offline   Reply With Quote
Old 12-22-2013, 11:26 AM   #56
FA20Club.com
Drives: 2013 White Out FR-S
Cranking Comp Tables should be along shortly as well.
FA20Club.com is offline   Reply With Quote
Gas tank laley81 Issues | Warranty | Recalls / TSB 1 07-31-2013 01:45 AM
TANK Vs. FRS chae FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 06-05-2013 04:23 PM
The need of a oil catch tank... davey90 AUSTRALIA 17 12-23-2012 05:01 AM
gas tank lid htdonato Issues | Warranty | Recalls / TSB 1 11-30-2012 02:43 AM
How many miles per tank on E85 Innova Engine, Exhaust, Transmission 2 09-21-2012 10:02 PM
