Old 12-20-2013, 10:24 AM   #127
EcuTek
Drives: Toyota GT86
Pro tip: use bootcamp instead of parallels or any type of virtualization, and the load time is actually more than 2X faster than a regular PC. I tried it both ways.
Just to jump here with our recommendation. You should always use ProECU with Boot Camp and a copy of Windows. This will guarantee its stability and it will run much faster.
We do not support using ProECU with any type of virtualisation software due to timing issues that may or may not cause timing issues on various laptops - when programming your ECU, you really don't want to have comms issues!
With Bootcamp on Mac, you get all the benefits of the Mac hardware running Windows. It does however mean you need a copy of Windows for your Mac.
EcuTek is offline   Reply With Quote
The Following 3 Users Say Thank You to EcuTek For This Useful Post:
Draco_PR23 (12-20-2013), jamesm (12-20-2013), Sportsguy83 (12-20-2013)
Old 12-20-2013, 12:25 PM   #128
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
And so, the first coming of ECUTek Retail Tuning Software came to pass. Enthusiasts everywhere rejoiced in its release, For this day will now be known to all as, ECUTekmas.
Deadspool is offline   Reply With Quote
The Following 3 Users Say Thank You to Deadspool For This Useful Post:
akuhei (12-20-2013), EcuTek (12-22-2013), jamesm (12-20-2013)
Old 12-20-2013, 12:42 PM   #129
jamesm
i got it. if the software is half as good as the documentation we're in for a treat. very good docs.
Old 12-20-2013, 01:18 PM   #130
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
ha ha!
Enjoy fellas, make sure to really dig into it and the instructions. Not something you want to miss. Lots of shortcuts and ways to navigate it that make it really easy too, mouse is mostly optional by the time you figure it out.
Xero-Limit is offline   Reply With Quote
Old 12-20-2013, 02:49 PM   #131
Kodename47
Kodename47's Avatar
Drives: UK GT86
It looks like you can edit all for map modes if they are already enabled on the .bin file from your tuner. I can certainly edit the fuelling, base and advance ignition for all 4 as well as enable the FFS, LC and auto-blip. What I do find odd is that while I can edit those, I can't chose which maps are enabled. The map in question has 3 selectable via CC but all 4 show in the editor. I guess to enable/disable the maps requires the full RaceROM functionality.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-20-2013, 02:54 PM   #132
Visconti
Drives: 05 STi
You can enable them but not edit the maps.
Visconti is offline   Reply With Quote
Old 12-20-2013, 04:16 PM   #133
Kodename47
Kodename47's Avatar
Drives: UK GT86
John, how sure are you about that?
I can certainly change values in the tables and save them I find it's the exact opposite. I can edit and save but have no way to select how many of the maps I want.
FYI, this is 3 mode map provided to me by a tuner.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-20-2013, 04:19 PM   #134
Visconti
Drives: 05 STi
Your using a older version of RaceRom which is why you can see the other maps.
The updated RaceRom code won't have everything you see but has updated code that's much better
John
Old 12-20-2013, 04:23 PM   #135
FA20Club.com
Drives: 2013 White Out FR-S
If you dont have The PRO version of the Retail software you will not be able to use map switching.
FA20Club.com is offline   Reply With Quote
Old 12-20-2013, 04:28 PM   #136
Kodename47
Kodename47's Avatar
Drives: UK GT86
John
That's it I guess. I've just realised that I have no access to edit the auto-blip settings. Where are the base maps available from?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-20-2013, 04:30 PM   #137
FA20Club.com
The software has the available roms store in the EcuTek directory.
Old 12-20-2013, 04:30 PM   #138
Visconti
Drives: 05 STi
Stock ROMS and RaceRom patches are downloaded via EcuTek Update
John
The Following 2 Users Say Thank You to Visconti For This Useful Post:
EcuTek (01-14-2014), Kodename47 (12-20-2013)
Old 12-20-2013, 04:32 PM   #139
Kodename47
Kodename47's Avatar
Drives: UK GT86
John
I hadn't run the update a 2nd time, cheers John!
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-20-2013, 04:34 PM   #140
Visconti
Drives: 05 STi
No problem.
For those of you who want the map switching with different tunes... I'll be offering a inexpensive service where you send me the ignition and fueling maps and I'll put them all together in a Map switchable tune.
I will also be offering a tune review service
John
The Following 3 Users Say Thank You to Visconti For This Useful Post:
EcuTek (01-14-2014), jamesm (12-20-2013), nelsmar (12-20-2013)
ecutek, edit, proecu, racerom, tuning
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 09:17 AM
So what ECUtek software do you need to make changes to the ECU yourself? seven Engine, Exhaust, Transmission 30 01-04-2013 11:58 AM
EcuTek's BRZ / FT86 / FR-S ProECU Software available for Pre-Order now Visconti Engine, Exhaust, Bolt-Ons 7 07-27-2012 01:00 PM
Toyota will announce the FT86 in Tokyo 2011 motor show? ossme Scion FR-S / Toyota 86 GT86 General Forum 9 12-05-2010 02:36 PM
