Old 12-20-2013, 12:17 AM   #127
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by mike the snake View Post
I'm almost positive it's backwards, towards the engine, which pushes the fans back towards the downpipe.
On my car, the backside of one of the fan motors is 1mm from the downpipe. No room at all, and I expect the fan to get melted by the downpipe.
I'm going to wrap the downpipe with that gold shielding material, and slip a piece of heat shield material between the fan motor and downpipe and hopefully that will help.
How does that gold shield foil material work as a heat shield? Is it pretty effective? I've seen it on a few cars, looks a little ghetto but if it works..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 12-20-2013, 01:10 AM   #128
Gen
Drives: Scion FR-S
It will melt. Mine already has...still running, but it's melted.
Gen is offline   Reply With Quote
Old 12-20-2013, 07:27 AM   #129
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The radiator should have added most of its thickness towards the front side, not the engine. At least that is how Robispec designed it. I have it too.
Old 12-20-2013, 08:30 AM   #130
Victor Draken
Drives: Toyota Gt86
Is this heat problem only for turbo or does S/C get this problem as well?
Victor Draken is offline   Reply With Quote
Old 12-20-2013, 08:34 AM   #131
s2d4
s2d4's Avatar
Compress air induces heat so it'll be both but not as bad as front mount turbo will have exhaust heat to contend with.
Old 12-20-2013, 09:14 AM   #132
Victor Draken
Drives: Toyota Gt86
so probably It is easier to fix heat issue on S/C
Old 12-20-2013, 09:23 AM   #133
jamesm
that depends on whether your talking about ambient temps or charge air temps
Old 12-20-2013, 09:24 AM   #134
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Well there will be less of it. A lot less.
The factory car has heat issues when driven hard enough. Supercharged cars do too. You don't have to drive them as hard to make it happen. Turbo cars you have to drive them even less hard.
Sellout is offline   Reply With Quote
Old 12-20-2013, 09:25 AM   #135
s2d4
s2d4's Avatar
I think this thread is talking about influences on engine/overall under bonnet temp?
Old 12-20-2013, 09:30 AM   #136
jamesm
i think so, but in my case the two are very related. the main reason why i want to alleviate the underhood heat issue is because even though i have my intake in the front bumper, my intake air temps rise drastically (moreso than normal) when sitting still. this isn't an issue when just driving around, as the intake temps drop down almost immediately when you start moving, but it makes for a lot of useless data when you're logging and need to filter out the weird intake temps.
but yeah i was more or less making a bad joke. s/c == high intake air temps, turbo == high engine bay temps.
Old 12-20-2013, 09:37 AM   #137
s2d4
s2d4's Avatar
Ever thought of W2A intercooler with its own fan? It should be more consistent?
Old 12-20-2013, 09:43 AM   #138
jamesm
i'm going to use FA20Club's badass new cooling setup once the summer rolls around, but honestly i fear that'll make things worse as far as ambient underhood temps (all that heat is getting radiated back into the bay regardless).
the intercooler that i have is crazy efficient, i see charge air temps near or sometimes lower than ambient when i'm moving. the problem is just the few minutes that you're sitting at a light where iat's jump to 130-140 .
i'm not really sure there is a way to resolve that without venting out all that hot air somehow. i've already got every turbo shield and wrap one could imagine (except the dp... maybe i'll try that).
Old 12-20-2013, 09:51 AM   #139
s2d4
s2d4's Avatar
W2A will not have this issue provided there is enough volume and its own fan on the heat exchanger. It will eventually heat soak after driving hard for a long time though.
Fender vent, bonnet vent, remove skirt plate, don't know what else...
Old 12-20-2013, 09:53 AM   #140
jamesm
i'm going to try removing the plastic thing up by the windshield wipers. see if it makes any difference...
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
