Old 12-18-2013, 01:25 PM   #6497
Visconti
Drives: 05 STi
Ironic as it may sound (and I'm serious), there is a big chance I get one of your FF kits , only thing is I'll be getting custom fuel lines made.
Welcome back.
I'm working on a much better kit.. different everything - except the tuning.
If your actually interested in doing something I wouldn't have a problem working with you again
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Sportsguy83 (12-18-2013)
Old 12-18-2013, 01:26 PM   #6498
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Welcome back.
Once the fuel line issue was resolved I've had no problems with the hardware I got from john. A little more work than I would have liked, but its the price you pay jumping in early.
Sent from my SGH-M919 using Tapatalk
mikalem is offline
The Following User Says Thank You to mikalem For This Useful Post:
Old 12-18-2013, 01:59 PM   #6499
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
John
By different everything do you mean a different sensor / hardware ? Maybe the new zetronix line ?
Sent from my IBrick
SmsAlSuwaidi is offline
Old 12-18-2013, 02:03 PM   #6500
Visconti
Drives: 05 STi
Sent from my IBrick
Except the sensor
Visconti is offline
Old 12-18-2013, 11:20 PM   #6501
s2d4
s2d4's Avatar
Feel free to correct me if I'm wrong but I'm pretty sure the IAM is setup to not be able to move on the stock tune - which might explain why it doesn't move at all on another vendors tune.
I could be wrong too but this actually goes against the subaru knock control strategy documentation I've read thus far. It either doesn't move at all because there is no knock or it has been intentionally bypassed?
@mad_sb @jamesm @Td-d @vgi
s2d4 is offline
Old 12-18-2013, 11:26 PM   #6502
Visconti
Drives: 05 STi
I'll have to double check with the dev guys at EcuTek but I'm under the impression that the IAM can't go up or down if the 'increment amount' is @ 0
https://www.dropbox.com/s/14q9dardy5...Multiplier.png
Visconti is offline
Old 12-18-2013, 11:55 PM   #6503
jamesm
that's not correct. i found that to behave weirdly in my experimentation with it though. even with the increment amount set at 0 (as stock) the iam can definitely go up and down. changing it does effect the step size though.
the easy way to disable the iam is to ensure that the current applied advance value is never greater than 3.9 degrees, as this is one of the conditions to entering rough correction mode. of course this can be accomplished by stuffing timing in the base map and reducing values in the advance map to achieve the same total timing.
it is widely accepted that this is a bad idea, at least from what i've read.
jamesm is offline
Old 12-18-2013, 11:58 PM   #6504
Visconti
Drives: 05 STi
btw
I will have a tune update available Friday for all roms.
Originally Posted by jamesm View Post
that's not correct. i found that to be weird in my experimentation with it though. even with the increment amount set at 0 (as stock) the iam can definitely go up and down. changing it does effect the step size though.
I'm going to try and confirm that with the EcuTek guys..
How much did you see the IAM changing with the default values?
Visconti is offline
cuddefred (12-19-2013)
Old 12-19-2013, 12:00 AM   #6505
jamesm
btw
in increments as low as 0.02 was the smallest i've seen. it could actually be smaller and be stepping through the other values without me seeing it though, as i don't poll the iam often.
jamesm is offline
Old 12-19-2013, 12:01 AM   #6506
CBR600RR
Drives: Raven Black
And I'm back.. will be responding to posts / questions shortly
John
Glad to see you back John!
CBR600RR is offline
The Following User Says Thank You to CBR600RR For This Useful Post:
Visconti (12-19-2013)
Old 12-19-2013, 12:57 AM   #6507
cuddefred
Drives: Black 86 GT
cuddefred is offline
Old 12-19-2013, 01:01 AM   #6508
cuddefred
Drives: Black 86 GT
John, with the new stuff approach from Ecutek is there any chance that we will get to see the ECU remembering the last map we used. This would be really good if it could be done.
Glad to see you back on here and just remember to try and play nice with the others cos some of us miss you
Old 12-19-2013, 05:40 AM   #6509
EcuTek
Drives: Toyota GT86
We have had a lot of comments on this and it is noted. It will be looked at going forward as we are very clear it is a popular request.
And yes John. Please play nice!
EcuTek is offline
The Following 5 Users Say Thank You to EcuTek For This Useful Post:
cobrabyte (12-19-2013), cuddefred (12-19-2013), RedAlert (12-20-2013), Sportsguy83 (12-19-2013), Yruyur (12-19-2013)
Old 12-20-2013, 12:45 AM   #6510
Visconti
Drives: 05 STi
Thanks!
Phil at EcuTek said there's a few more things he wants to try out in regards to the map switching. It's been a while since he's looked at it but we both agreed that a fresh look at the problem is all that's really needed, he's pretty sure he'll get it sorted.
Visconti is offline
cuddefred (12-20-2013)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
