#15 |
Drives: LP DSP / CSP '13 BRZ
I'm out of building a SP car if it is going to CSP. I just don't see it getting light enough in the ruleset to catch up with the tiny miata.
I also see they didn't write the rule with both on the same line, seems odd and not in line with historical examples of same "models" from different manufacturers. Ah well, saves me some money next year. Until I end up in SM like always. |
#16 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
![]() Guess I'll be looking at options other than a BRZ after I've become bored in street. Who in their right mind will dump SP money into building what really amounts to a not streetable car just for the purpose of trying to get it reclassed. CSP miatas are typically faster on most courses than the boost buggies in ASP... and that includes people like Aaron Miller, Marshall Grice, and Tom Barry. No bleeping chance for the FR-S/BRZ.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#17 | |
Detroit Region, MI
Assuming it gets dropped from STX, you'll get E85. Or leaded race gas is an option... but that will only help so much.
#18 |
AutoX Nut
Drives: 2020 Toyota Supra
Not that I had high hopes of building a Street Prepared car, but this recommendation doesn't make much sense to me. If the RX-8 is in CS and STX, why is it classed in DSP while the BRZ/FR-S is CSP? What do the twins have in Street Prepared trim that the RX-8 doesn't have?
#19 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#20 |
Anorexic
Drives: 2003 Honda S2000 Suzuka Blue
#21 | |
Drives: Some kind of Subaru
| The Following User Says Thank You to G_Ride For This Useful Post: | PoorMansRacing (12-18-2013) |
#22 |
I think the CSP classing is really just to make sure it doesn't go into DSP and scare people away or be an overdog in the class. However it will keep anyone from actually building a CSP 86, at least for a few years. They did the same thing to the RX-8, it was in CSP for years no one ever competed in one so they recently moved it to DSP.
I don't see it being competitive against the CSP Miatas at all. IMHO it's going to be hard to get the cars under 2500lbs in CSP trim, it's not like there is a ton of weight to shed in addition to what you can already do in STX. All the stuff SubiePig mentioned is probably good for 50lbs, you could run some superlight seats and maybe get to 75lbs less than STX, and that puts you around 2500lbs. Power wise if you were willing to do a fully built CSP motor maybe you end up at 210whp on E85 or race gas. 220whp I don't think is going to happen unless you are willing to wind the motor beyond what is safe. It's still not going to compete with a tiny Miata weighing 1900-2000lbs and making 150-170whp... Slaloms and offsets are a huge part of autox and you can't ignore the length and width differences and the ability to carry speed. |
#23 | |||
Conedancer
| The Following User Says Thank You to Scooby South For This Useful Post: | PoorMansRacing (12-19-2013) |
#24 | |
Drives: BMW 135i, soon to BRZ
| The Following User Says Thank You to mrazny For This Useful Post: | Scooby South (12-18-2013) |
#25 | |
Conedancer
.. I will go so far as to say, "The person that submitted it would likely be influential." from what I have heard.. ![]() Bill
#26 | |
I just don't think there's too much to imply from the precise letter that is referenced when the Fasttrack puts things to comment. More than this specific SP situation, I don't think it should be a reference point to some other proposal as to precisely which letter starts the fasttrack. In this case, sure, that first letter could very well be the most influential. It's just as likely coincidental than causal if you compare other proposals. By the way I wouldn't say that I agree that Twins are competitive in CSP. But I completely understand the angle where they believe this to be in the best interests of the SP category. Sux, but there's always STX to play with us freaks
#27 |
| The Following 2 Users Say Thank You to Eric1855 For This Useful Post: | PoorMansRacing (12-19-2013), Scooby South (12-18-2013) |
#28 | |
Conedancer
![]() Pretty much. Its still a business at certain levels.. so if one class is hurting for entries.. they will try to 'beef up' that class with a car 'close' to the specs.. At that level..there are ALOT of old-timers get their panties in a wad because alot of them can't handle change. Bill
| Mercedes A class AMG v BRZ? | Suberman | FR-S / BRZ vs.... | 20 | 09-24-2013 02:37 PM |
| Proposal for CDC FT-86 Class | Areddi | Mid-Atlantic | 37 | 05-11-2013 06:59 AM |
| FRS No class? WTF | ggpaul | Scion FR-S / Toyota 86 GT86 General Forum | 135 | 01-15-2013 12:07 PM |
| Anyone for a class? | Fuzzysmith | Northwest | 21 | 08-13-2012 12:02 PM |
| Which autocross class? | jpdarty7 | Tracking / Autocross / HPDE / Drifting | 66 | 06-21-2012 05:53 PM |
