Old 12-18-2013, 08:46 PM   #43
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by MAPerformance View Post
As soon as we finish the one we have in house. I think we just got the throttle plate finished, so once we put it back together, we can throw it on our fabricator's bone stock FRS. We don't have any tuning available however, so I don't know if I will have results of what it can benefit with a tune. But hopefully we can have someone try that out as well.
Any update?
Thanks.
cslntuee is offline   Reply With Quote
Old 12-18-2013, 09:32 PM   #44
MAPerformance
Drives: Asphalt FRS
Originally Posted by cslntuee View Post
Any update?
Thanks.
Yes, soon! We actually received the throttle body that a tuning shop sent us yesterday. I believe my machinist has began the process today so we can ship it back out the them as soon as possible.
MAPerformance is offline   Reply With Quote
Old 12-19-2013, 02:04 AM   #45
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Would you guys be considering ceramic coating the TB?
stevo_12v is offline   Reply With Quote
Old 12-19-2013, 10:14 AM   #46
MAPerformance
Drives: Asphalt FRS
Yes, that very well could be an option. We do use a local coating shop in our are that does all of our intake, exhaust manifolds, downpipes ect. I will get more info as we get closer to releasing it after testing.
Old 12-19-2013, 02:00 PM   #47
stevo_12v
That'd be a pretty good valued-added option :P
Btw, I had a look at my stock TB earlier on, seems it's secured by rivets. How do you guys go about re-securing back the electrical plastic part with the alloy part, or do you use bolt with nyloc nuts?
Reason being, although I have my TODA, I'm looking towards getting that ceramic coated. Might make negligible difference in extra power, but for strictly staying N/A.. every little bit helps.
Old 12-20-2013, 10:51 AM   #48
MAPerformance
Drives: Asphalt FRS
We will be using small nuts and bolts to secure the servo cover back on. The throttle plate will be re-installed with flat head screws instead of rivets, and the freeze plug will also be replaced.
Old 01-01-2014, 12:14 AM   #49
Turdinator
Señor Member
Turdinator's Avatar
Have you re-routed the coolant so it doesn't go through the TB anymore?
1974 TA22 Celica
2013 86 GT
Old 01-01-2014, 01:25 AM   #50
stevo_12v
Yup, not many ppl here know about that effective zero-cost mod
Old 01-01-2014, 01:35 AM   #51
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Share the secret!!! Please!!
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 01-01-2014, 03:33 AM   #52
stevo_12v
It's pretty self-explanatory. Re-read Turdinator's post
Old 01-01-2014, 12:09 PM   #53
RehabJeff86
Is there a DIY post?
Old 01-01-2014, 12:42 PM   #54
Ross
Drives: 85 corolla gts
All you have to do is disconnect the two coolant hoses that go to the throttle body. The install a 90 barb fitting, do not recommend plastic for this, to connect the two hoses back together. I recommend getting fuel line style clamps for replacing the spring clamps. Then top off your cooling system as needed. The primary reason those hoses are there is to prevent throttle icing, not an issue in all areas but if there is a possible concern do to your climate I do not recommend you do this. At that point you will no longer have the throttle body warmer. Sorry to thread jack and hope this answers your question.
Ross is offline   Reply With Quote
Old 01-01-2014, 12:51 PM   #55
Luis_GT
ooooh...
Old 01-01-2014, 02:25 PM   #56
stevo_12v
From my experience a 90 deg barb wasn't required. Just looped the longer hose back into the system. Might be different for US spec cars though. But yes. A good cheap effective mod as long as the area your in does NOT experience frost or snow
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 10:58 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
