Old 12-14-2013, 08:07 PM   #337
jamesm
Originally Posted by ztan View Post
Thanks.
Which table/s did you alter to affect direct injection scaling? I can see the port injector scaling easily.
Did getting this balance right also help your tip-in knock?
the table in brzedit is called "GDI Flow Rate", not sure if it's defined in RomRaider or if so what it is called. Getting it right had no effect on the tip-in knock, though i had figured it might. the afrs are more stable getting back on the throttle, and when you're just cracking it open, but still no help in getting rid of the -1's
Old 12-15-2013, 01:55 PM   #338
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Yup, it is. Same name.
Sent from my iPad using Tapatalk HD
Td-d is offline   Reply With Quote
Old 12-15-2013, 03:31 PM   #339
stugray
Drives: 2013 GBS BRZ Limited
How are the table names defined?
Is there embedded text in the ROM?
Old 12-15-2013, 04:06 PM   #340
jamesm
they are defined in an xml definition file used by the software, which is essentially a hex editor that uses said definition file to make things a bit more human friendly.
Old 12-15-2013, 04:18 PM   #341
stugray
I understand that part. What I was asking is how do the definition tables get generated?
Do the reverse engineers have to decompile the code completely and understand every single bit of it, OR are the table definitions in ASCII embedded in the ROM code?
Old 12-16-2013, 01:29 AM   #342
ztan
Drives: Toyota 86
Originally Posted by Td-d View Post
I think both are port scaling - the one I defined originally has the same logic that I've seen over and over in the roms - but it was pointed out o me ht the other value is that defined by oft and brzedit as the scaling. I would be interested to hear feedback from someone whether my original scaling does the job.
I have tested with the following.
Stock scalings: Td-d 222.32 (2707090/x); BRZ 228.05 (60000/x, 263.1 raw)
Stock ROM:
Idle till IPW1=0: STFT+LTFT = -7.15%
Stock ROM, all GDI maps changed to 100% port:
Idle till IPW1=0: STFT+LTFT = -11.05%
Td-d scaling to 232.32, GDI at 100% port:
Idle till IPW1=0: STFT+LTFT = -10.17%
BRZ scaling to 218.18 (275 raw), GDI at 100% port:
Idle till IPW1=0: STFT+LTFT = -13.1%
BRZ scaling to 240 (250 raw), GDI at 100% port:
Idle till IPW1=0: STFT+LTFT = -4.41%
BRZ scaling to 250 (240 raw), GDI at 100% port:
Idle till IPW1=0: STFT+LTFT = -0.48%
BRZ scaling to 250 (240 raw), GDI back at stock:
Idle till IPW1=0: STFT+LTFT = -0.32%
BRZ scaling at 235 (255 raw) and Td-d scaling to 235, GDI stock:
Idle till IPW1=0: STFT+LTFT = -2.71%
ztan is offline   Reply With Quote
Old 12-16-2013, 10:43 AM   #343
jamesm
i'm pretty sure they have to decompile and understand the code. i don't think it's as simple as searching for strings.
Old 12-17-2013, 09:31 AM   #344
vgi
Drives: frs
If you guys can put together a request list of parameters required, I can start trawling around for addresses (once I'm back from holiday )
Is there any way we could help you?
so far i think ztan has asked already for defroster address so that standalone logger could be tuned on/off at will. the cruise control would work too.
Btw, how do you determine what is the length (num bits or bytes) of a specific parameter at that address? if i'm not mistaken then tactrix standalone logger by default (unless specified) assumes that it's a 1 bit param value, so the length should be specified for most of those?
vgi is offline   Reply With Quote
Old 12-18-2013, 01:33 AM   #345
Td-d
You have to look at the code to see whether it is using mov.b mov.w or mov.l to put the data in the various registers (whether an r register or an f register).
In terms of help, if you are willing to start pulling all the standard switches from the SSM routines (I see here's a discussion going on the RR thread) would definitely speed things up. I'm back in town in two days, so can get going again.
Old 12-18-2013, 08:24 AM   #346
mad_sb
Drives: 2013 Asphalt FR-S
i saw the same thing tuning my car for e85. i would log fueling error with the ports turned off and get corrections in one direction, then log with ports only and get different results. getting both 'in spec' independently fixed virtually every drivability problem i had prior to doing this, particularly rough idle, rpms hunting, dipping rpms coming to a stop, stumbling at tip-in, etc. all related to big swings in afr introduced by the disparity in required trim when the switchover happens between injection modes.
you can use the 3 port/di ratio tables to set the ratio. 100% is port only, 0% is di only.
Yup, this miss-match exists stock and is what prompted me to write the first maf scaling how-to with brzedit.. I just didn't realize this was the cause at the time lol
Old 12-20-2013, 07:57 AM   #347
ztan
Drives: Toyota 86
Once you're back from holiday, would be interested in seeing logging addresses for:
MAF voltage
Direct/port injection status or ratios
Knock sums
Defogger button
Old 12-27-2013, 01:09 PM   #348
Td-d
ztan - can you test the following two addresses for me for MAF Voltage?
Ram_Mass_Airflow_Sensor_Voltage FFF848FE
Ram_Mass_Airflow_Sensor_Voltage_1 FFF8490E
Both 2 byte parameters (16bit)
Old 12-27-2013, 01:34 PM   #349
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Has throttle position for ZA1JA01C been found yet? I'm able to log now, but VirtualDyno won't open the file without throttle position, RPM and Time.
AdrianG is offline   Reply With Quote
Old 12-27-2013, 02:43 PM   #350
Td-d
In post 312.
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
