Old 12-16-2013, 01:37 PM   #2353
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I'm getting CeL PO351, A Coil Primary/secondary.
Anyone else getting this problem.
Happens WOT around 7200 to rev limiter, will take into Toyota and see what's gone wrong.
Ryan86 is offline   Reply With Quote
Old 12-16-2013, 02:12 PM   #2354
Carwhisperer
Drives: A lot of supercars.
Read through my threads I started. You'll get more info. Long story short I got p0351 a day before I had 2 DI's start to leak.
Carwhisperer is offline   Reply With Quote
The Following User Says Thank You to Carwhisperer For This Useful Post:
Ryan86 (12-16-2013)
Old 12-16-2013, 08:24 PM   #2355
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Coil pack is dead on cylinder 1. Time to replace it.
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Ryan86 (12-16-2013), whataboutbob (12-17-2013)
Old 12-16-2013, 10:20 PM   #2356
Ryan86
Road Warrior
Ryan86's Avatar
I'm told we have to lift the motor to get to the coil packs? If I'm going to do this, should I take an opportunity to change plugs, I'm at 35000km?
Old 12-16-2013, 10:23 PM   #2357
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
Why not?
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
Old 12-16-2013, 10:32 PM   #2358
Ryan86
Road Warrior
Ryan86's Avatar
Originally Posted by Team STILLEN View Post
Why not?
Would it be best to stick with plugs supplied be Toyota or would a better plug work for boosted?
Old 12-16-2013, 10:34 PM   #2359
jamesm
you don't have to lift the engine to get the coil packs out. it helps a lot when doing the plugs, but really isn't even necessary then. the coil packs are the easy part of that job.
Old 12-17-2013, 12:34 AM   #2360
DriftEm
DriftEm's Avatar
Originally Posted by DarrenDriven View Post
I'm assuming that is your car? Should I update page one?
Yes, please.
DriftEm is offline   Reply With Quote
The Following User Says Thank You to DriftEm For This Useful Post:
DarrenDriven (12-19-2013)
Old 12-17-2013, 12:43 AM   #2361
DriftEm
DriftEm's Avatar
Originally Posted by wrxgoose View Post
If I've lost 3 belts from the OEM, I really think I should try an aftermarket one. Also, probably gonna try a little bit smaller belt
Sent from my VS840 4G using Tapatalk
SO, after installing the 70mm pulley and the Gates Race Belt version of the oem belt (part number K061015RB), I lost the belt in 3 days. I believe the belt is too big with the 70mm so I'm going with belt half inch smaller. We'll see how this one holds.
BTW, Gates part number for smaller belt is K061010.
The Following 2 Users Say Thank You to DriftEm For This Useful Post:
suaveflooder (12-19-2013), whataboutbob (12-17-2013)
Old 12-17-2013, 01:17 AM   #2362
wrxgoose
WUB WUB
Drives: 2013 Firestorm
how's your tensioner? can you squeeze your belt and have the tensioner move, like mine does?
wrxgoose is offline   Reply With Quote
Old 12-17-2013, 01:23 AM   #2363
DriftEm
DriftEm's Avatar
yeah, the tensioner moved easily with the longer belt like it was at end of it's range and the spring tension wasn't enough. With the shorter belt there is a lot more tension on the belt now. One more thing I noticed, the tensioner pulley moved a lot with the long belt when engine was running, and now it still moves but a lot less.
Old 12-17-2013, 01:29 AM   #2364
wrxgoose
WUB WUB
that's the same thing my friend john was thinking. if we go with a smaller belt, the pulley has less space to move, and so will be less likely to throw the belt. We're also thinking about some sort of face-plate for the SC pulley, to keep it on there.
Old 12-17-2013, 01:30 AM   #2365
DriftEm
DriftEm's Avatar
Keep us posted on the face-plate, that is a great idea.
Old 12-17-2013, 01:35 AM   #2366
wrxgoose
WUB WUB
will do. i'm going over to lexus tomorrow (where john works. he's a member on here), and we're gonna see what the measurements are, and everything.
The Following User Says Thank You to wrxgoose For This Useful Post:
DriftEm (12-17-2013)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
