Old 12-15-2013, 07:21 PM   #1
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
Combating the heat
So for those who have gone with a turbo charger fighting heat can be a big battle. I can't speak for the supercharger owners so if any of you who have I welcome you to chime in.
I would like to know what others are doing to battle the heat that builds up in the engine bay.
Today I went with a few others on a mountain run and when we started going up hill and through the turns I noticed my temps started to raise. I pulled over before I got to hot and had to cool down. In fact I had to do this a few times before turning around and going down hill. Down hill was fine but I was coasting more then I was boosting so I think that had a big role I'm keeping temps down. On the highway I seem to be fine unless running it hard.
I have for cooling help
Full Blown radiator
Mishimoto oil cooler
Exhaust wrapping from manifold through the down pipe.
No bottom metal skid panel
And the fog lights removed to provide air to the oil cooler.
Braided hoses for oil and coolant.
Running full blown stage 1 kit
On order turbo heat cover by DEI
toekneehair is offline   Reply With Quote
Old 12-15-2013, 07:54 PM   #2
mike the snake
My car is getting almost the same setup you have presently. I'm running the Robispec radiator/oil cooler, but basically the same as you.
I'm planning on cutting on the fender garnishes, turning them into fender vents.
Others use the carbon vented hoods, which probably work the best at removing heat from the engine bay.
Old 12-15-2013, 08:04 PM   #3
dabocx
dabocx's Avatar
Drives: Scion FRS
I'm getting a vented hood and getting it paint matched. Just trying to find something that isn't too crazy
dabocx is offline   Reply With Quote
Old 12-15-2013, 08:10 PM   #4
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
@toekneehair what kind of temperatures were you getting, also what was the outside temperature?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 12-15-2013, 10:00 PM   #5
Gen
Drives: Scion FR-S
It was between 65-70 F (18-21 C) degrees here. Despite what most of the shops are saying, there IS an issue with heat and these turbo kits.
I have a 25 row setrab oil cooler, Koyo radiator, turbo blanket, vented fenders, and yes, it will get dangerously warm if pushed hard for a long period of time on my FBM turbo kit. 2-3 minutes of boost can cause coolant temperatures to start creeping past 107 C. Traffic requires the heater on when the ambient temps are above 90 F.
The FBM kit has a design flaw with the downpipe in my opinion. I think they've curved it in the way they did to give the MAF and cam sensor as much room as possible, but in doing so, it forces you to use slim fans without a shroud. This results in excessive temps in traffic.
@toekneehair , look on the bright side--mine caught on fire the first trip up the mountain. It looks like the mountain is 2 and 0 as I didn't make it up either.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
Boba_kz (08-22-2014)
Old 12-15-2013, 10:10 PM   #6
mike the snake
Would fabricating shrouds around the FB fans help things? IMO it wouldn't be too hard to make shrouds around the fans that fit around the downpipe.
Old 12-15-2013, 10:12 PM   #7
Gen
Drives: Scion FR-S
My plan is to get a new downpipe made and switch to the stock fans / shroud. Piece by piece I've pretty much replaced the kit at this point. One of my slim fans is on its last leg. It's melted pretty bad from the downpipe.
Beyond that, I'm not certain what to do to the combat heat as I'm far from an expert. More efficient radiator perhaps? I'm not thrilled by the prospect of the oil cooler / radiator combo. Makes sense for the track, but on a street car it looks like it's asking for trouble.
Old 12-15-2013, 10:18 PM   #8
ciro
Drives: Scion FR-S
Welcome to the reason I hate the FBM kit turbo location. Slim fans have always been bad you could consider doing push fans in front but they aren't that efficient either.
ciro is offline   Reply With Quote
Old 12-15-2013, 10:20 PM   #9
Brody602
Drift King
Brody602's Avatar
@FullBlown care to shed some light on this heating issue and if it's a problem you guys are aware of?
I thought by the temps would have been same as NA if not better with ceramic coated pieces & heat wrapped, turbo blanket, fbm radiator and fbm oil cooler?
Hope I don't have overheating issues with my FBM kit
Old 12-15-2013, 10:51 PM   #10
mrk1
Drives: Sterling BRZ Ltd
Does anyone have a picture of how close the down pipe is to the fans?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 12-15-2013, 10:53 PM   #11
toekneehair
I don't think FBM is the only kit generating heat here though. And besides under extreme conditions I think the kit has been holding up well. I like the idea of designing a good shroud for the fans that work with the slim fans. The could help some and I'm thinking about the same with the hood. I wanted to get the FA style hood I believe. The one with the center hood scoop and vents on the side. I feel like that would move lots of air.
Full blown has been extremely helpful thus far with my build. But I think I might have to get a little creative with the air thing. What about replacing the front bumper and altering the actual metal bumper underneath allow for better air flow there?
Old 12-15-2013, 11:06 PM   #12
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The problem is the car's engine bay is sealed off like an oven. We have found that guys who were in the middle east with crazy hot ambient temperatures had heat problems even with a stock car.
The lower aluminum splash guard can be removed so the the hot air has a place to escape. We also will have a shroud coming to help pull more heat away, but the main problem is venting. Whether it is our kit or not, power creates heat, and you have to find a way to remove it from the engine bay.
FullBlown is offline   Reply With Quote
The Following 7 Users Say Thank You to FullBlown For This Useful Post:
1086 (12-19-2013), Astroboy (09-22-2014), cabasse (01-13-2014), Craig (07-21-2014), crook (01-23-2014), Marchy (07-17-2014), sato (10-26-2021)
Old 12-15-2013, 11:06 PM   #13
mike the snake
I thought about the same thing, but I think the problem lies with not being able to get the engine bay air OUT.
I found this crash bar that looks like it will still offer front protection but also let a lot more air in.
http://www.enjukuracing.com/products...Scion-FRS.html
The Following User Says Thank You to mike the snake For This Useful Post:
Old 12-15-2013, 11:12 PM   #14
Brody602
Drift King
Brody602's Avatar
Can you give more details about this shroud?
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
