#449 |
AutoX Nut
Drives: 2020 Toyota Supra
I'm looking to upgrade my suspension for STX AutoX competition and RCE's support of this forum has me sold on getting one of their products.
I've been autocrossing for over 2 years and feel that I'm a competent driver, but my experience has only been on stock class cars so I've never driven a car with coilovers or adjustable dampers/lowering springs. The Tarmac IIs sound awesome, but they're above my budget and I'm not even sure if my skills are to the point where I could take advantage of their performance potential. Not to mention, I'm worried that the adjustability would have me overthinking things and messing with them too much. This leaves me with the Tarmac 0's and the Koni/RCE Tarmac Spring combo. The cost of these setups is similar (taking into account the need to modify front strut housings for Koni's), so what are some things I should consider when trying to decide between these two options? I'm only concerned about AutoX performance and am not worried about daily driving/street manners if that helps at all. |
#450 |
The Tarmac 0 will get you more spring rate vs. Koni + RCE springs, so that will work better for you when autocrossing. It's a simple, easy, fast set-up that you don't have to fiddle with much. We've got our custom 350/350 set-ups...sounds like the way to go for your needs. Give us a call and we give you more details.
![]() - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | jprice130 (12-13-2013) |
#451 | |
Drives: 2015 WRX
| The Following 2 Users Say Thank You to Malt For This Useful Post: | jprice130 (12-13-2013), Racecomp Engineering (12-13-2013) |
#452 | |
AutoX Nut
| The Following User Says Thank You to jprice130 For This Useful Post: | Racecomp Engineering (12-13-2013) |
#453 | |
Drives: 2015 WRX
#454 |
We can also help you with set-up on the T2's, so don't let the 2 way adjustablity intimidate you! We've got tons of track time with them in a variety of conditions. Plus you can call us on weekends and after hours if you need help.
- Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | jprice130 (12-13-2013), whataboutbob (12-14-2013) |
#455 |
AutoX Nut
Awesome! Thanks Andy!
#456 |
Drives: 2013 FRS, 2008 R32
RCE T0's
| The Following User Says Thank You to mfbmike For This Useful Post: | Racecomp Engineering (12-14-2013) |
#457 |
AutoX-10/10ths every run
T2s arrived...
| The Following User Says Thank You to whataboutbob For This Useful Post: | OICU812 (12-14-2013) |
#458 |
#459 |
#460 |
Drives: 2015 WRX
Just curious but what is the range of ride height adjustability with the T2's? I know in the PM's we talked about the raceseng rear top hats were not necessary because the T2's had a ton of travel but since I'm going to have everything off I'd rather just do it now if I'm going to want it in the future.
If I push the shock upper mount up 2" with the raceseng rear mounts with a 1" lower on the vehicle am I going to run into issues with droop travel on the T2's? |
#461 |
Drives: 2013 SWP BRZ
I've been playing with the T2's for the past few days, and have decided they're too good looking to be hidden underneath the car, so I'm ordering a second set from Myles to put in my living room.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
| The Following User Says Thank You to smbstyle For This Useful Post: | normancw (01-28-2014) |
#462 |
RCE T0's
| The Following User Says Thank You to mfbmike For This Useful Post: | Racecomp Engineering (01-02-2014) |
| Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-16-2013 11:02 PM |
| Tarmac Zero Coilovers Specs? | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 06-13-2013 11:26 PM |
| KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! | NJA | Brakes, Suspension, Chassis | 7 | 03-30-2013 08:26 PM |
| Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 12:24 PM |
| Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster | knoxviue | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 35 | 01-20-2012 01:44 AM |
