Old 12-13-2013, 01:14 PM   #197
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
One thing I've noticed with the international ROM guys is that LTFT is quite positive, causing them to run rich at WOT. This does suggest fuel composition differences (compared to US fuel). Maybe it may be an option to disable LTFT learning. I don't see that being a bad option since they don't have access to E85 and don't need to be able to adapt to different ethanol content (AFAIK).
Shiv@Openflash is offline   Reply With Quote
Old 12-13-2013, 04:58 PM   #198
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi Shiv!
I just made another pull run and it shows the same 11.25 AFR pretty straight line on WOT.
http://datazap.me/u/ondreiko/3-4-wot...koin-98ron?1-9
Later refueling i will try to log on another manufacturers fuel.
How can i disable LTFT to get it leaner? Or will you be able to probably arrange it among G-series roms mappings?
Ondreiko is offline   Reply With Quote
Old 12-13-2013, 05:36 PM   #199
jamesm
Originally Posted by Ondreiko View Post
Hi Shiv!
set the highest learning load bucket (currently 40g/s) to something higher than 60.
The Following User Says Thank You to jamesm For This Useful Post:
Shiv@Openflash (12-13-2013)
Old 12-14-2013, 04:22 PM   #200
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
how do i do that?
i have very similar AFR
https://docs.google.com/file/d/0B3Tt...=sharing&pli=1
Old 12-15-2013, 12:18 AM   #201
Vmax911
Drives: WRB BRZ
Originally Posted by Vmax911 View Post
I've tried it three times, advance multiplier never changes from 0. Also, upon start up KC learn drops to zero within seconds, but I'm guessing the two may be related.
Also, when I tried to download the second log last night, the manager said the tablet had to be initiated and I had to calibrate again. This happened twice within minutes. However, the tablet still had the original ROM stored. Not sure if this has anything to do with the advance multiplier or not.
Ending up erasing everything and starting from scratch. Still no IAM or KC learned (unless I'm having huge knock issues). I guess the old 700C is a bit different.
From what I understand, flashing the ECU will overwrite the entire software load. So when I flash, these parameters (IAM and KC) will function properly? Will I have any problems since this is an old ROM?
Vmax911 is offline   Reply With Quote
Old 12-15-2013, 12:33 AM   #202
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
If you have a 700c why can't you flash to stock, take it to Toyota or Subaru and get them to flash to 701c. It's a tsb and shouldn't be an issue?
FrsDuke is offline   Reply With Quote
Old 12-15-2013, 12:43 AM   #203
FrsDuke
Fanboy
FrsDuke's Avatar
http://www.ft86club.com/forums/attac...1&d=1386706237
Tsb to get flashed off the 700c calibration
Old 12-15-2013, 01:27 AM   #204
Vmax911
Drives: WRB BRZ
Unfortunately I don't believe Subaru ever released a TSB for this?
Old 12-15-2013, 01:45 AM   #205
s2d4
s2d4's Avatar
No idea but you are not the only one. It doesn't work on the ZA1JA01I either.
Old 12-15-2013, 12:28 PM   #206
FrsDuke
Fanboy
FrsDuke's Avatar
I believe Subaru's solution was to actually replace the ecu. It's been over a year though.
Old 12-16-2013, 10:19 PM   #207
Vmax911
Drives: WRB BRZ
Can anyone answer these questions?
Old 12-17-2013, 12:59 AM   #208
Shiv@Openflash
Drives: 2013 FRS
This is strange. I'm not getting any other reports of 700C ROMs not logging IAM and KC. I have even seen datalogs from 700C customers showing both channels logging properly. The only time IAM and KC won't log properly is with the stock (original) ROM. But once you upload one of our OTS maps, you will effectively have a A01C ROM and both channels should log properly. Unless something else is going on, I have not had any other reports of 700C not logging IAM or KC. But I'm open to the feedback of others just in case there is something else going on that I'm not aware of.
http://www.ft86club.com/forums/showthread.php?t=53696
Shiv
Old 12-17-2013, 12:25 PM   #209
Vmax911
Drives: WRB BRZ
Shiv
I am still on the stock ROM. If this is the way it is supposed to work (incorrect IAM and KC on the STOCK ROM), then there may not be a problem at all!
Old 12-17-2013, 01:05 PM   #210
Shiv@Openflash
Drives: 2013 FRS
Correct. Looks like there is no problem after all. Just load one of our OTS maps
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
