Old 12-07-2013, 08:55 PM   #99
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by ucsmfu View Post
received the entire kit today.
Does anyone have the diffuser from bayson R ? drilling required ?
There should only be one hole to drill which is dead center under the 4th brake light and the outer most edges on both sides, if you decide to secure it there also. I just did the center hole as the diffuser is secure enough the way it is
Sent from Note 3 SM-N9005
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-08-2013, 12:12 PM   #100
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
For anyone who's installed the skirts, could you please post a couple of pics of the underside where the brackets attach to the skirt and car. I would like to see where they attach and line up for reference
2URGSE
Old 12-08-2013, 12:26 PM   #101
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
If you got your front lip, could you post a couple of pics please ?
2URGSE
Old 12-08-2013, 03:26 PM   #102
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The brackets attach in an upward position ( if that makes sense). Once you line it up on the car you should see where it attaches. There's only one clip in that area.
Old 12-08-2013, 04:54 PM   #103
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Yeah I thought so as per instructions. Did all brackets mount inside the skirt or do the outer brackets attach on the outside portion of the skirt ?
2URGSE
Old 12-08-2013, 05:11 PM   #104
Andrew025
Andrew025's Avatar
I put mine on the inside.
Thinking about it now, might make more sense to put it on the outside as far as support goes but I don't think it'll matter much.
The Following User Says Thank You to Andrew025 For This Useful Post:
JPxM0Dz (12-08-2013)
Old 12-09-2013, 01:50 PM   #105
djdnz
1337
Drives: 2013 BRZ WRB S/C
Does anyone have pics of the front lip? I'm very interested at the price they're selling for.
djdnz is offline   Reply With Quote
Old 12-09-2013, 04:51 PM   #106
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
i will post pics up later today
ucsmfu is offline   Reply With Quote
The Following User Says Thank You to ucsmfu For This Useful Post:
JPxM0Dz (12-09-2013)
Old 12-11-2013, 05:21 PM   #107
djdnz
1337
Bump?
How was the fitment, any complaints?
Old 12-12-2013, 05:08 AM   #108
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Originally Posted by djdnz View Post
Bump?
haven't had time to install it. Snowing here in Van
damn, price dropped $10 cheaper
http://www.ebay.com/itm/12-14-Subaru...item51b5bff03e
Old 12-12-2013, 01:50 PM   #109
alamez
Drives: Silver brz limited
How is the abs plastic holding up anybody having problems? i was told to stay away from ABS and stick to polyurethane because ABS cracks and breaks easily. Any thoughts?
alamez is offline   Reply With Quote
Old 12-12-2013, 09:53 PM   #110
Andrew025
Andrew025's Avatar
Kind of the reason I went with the poly front lip since it'll see the most action.
Front should be fine as long as you're careful though.
Sides and rear should be no problem as well unless you're going off some sweet jumps.
Old 12-14-2013, 12:15 PM   #111
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
I ordered the front lip yesterday, i hope it fits as good as there cs style
Bones36 is offline   Reply With Quote
Old 12-16-2013, 09:55 AM   #112
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Here's another link to both STi Skirts and rear apron bundle including STi badges. Appears to be identical product BaysonR sells...
http://www.ebay.com/itm/12-14-BRZ-tS...ht_2330wt_1219
Front STi lip with STi badge...
http://www.ebay.com/itm/12-14-BRZ-tS...ht_2362wt_1219
2URGSE
STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 31 12-03-2013 10:57 PM
CS Style Polyurethane Side Skirts Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 14 11-04-2013 09:49 PM
WTB CHARGESPEED STYLE SIDE SKIRTS. bahanii Want-To-Buy Requests 1 10-18-2013 02:06 PM
FS: CS Style Side Skirts and Rear Spats FRS2000 Exterior Parts (Aero, Lighting, Etc.) 4 09-23-2013 12:15 PM
2013 SUBARU BRZ J STYLE PU SIDE SKIRTS JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 7 05-10-2013 11:29 AM
