Old 12-10-2013, 04:37 PM   #15
rallysrt
Drives: shitboxes
Originally Posted by Pokeguyjai View Post
I have -2 degrees in the front. Thanks guys for the help.
Camber bolts/slotted struts?
rallysrt is offline   Reply With Quote
Old 12-10-2013, 04:40 PM   #16
mid_life_crisis
Drives: FR-S 10 #103 AT
Funny thing is that people have the same wheel setups, higher offsets than I do, stock suspension, and they are not getting any rubbing.
Stop bragging, the others just wait until the car is parked.
Oh, the tire rubs? Never mind...
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Pokeguyjai (12-10-2013)
Old 12-10-2013, 05:51 PM   #17
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
From the words of my mechanic from EFI:
"We use 1/2", grade 8 bolts with self locking washers to get the 2 degrees of
camber in front. We put them in the upper hole and push the top of the wheel
in as far as it will go."
Not sure what method that is called.
Pokeguyjai is offline   Reply With Quote
Old 12-10-2013, 06:23 PM   #18
rallysrt
Drives: shitboxes
Easy fix, lose just a little camber. Lol
It'll be a little more difficult to get it even without proper eccentric camber bolts, but still pretty easy.
The Following User Says Thank You to rallysrt For This Useful Post:
Old 12-10-2013, 07:48 PM   #19
mfbmike
Drives: 2013 FRS, 2008 R32
Sounds a bit excessive considering your suspension.
Positive or negative, camber is camber. Sounds like you need less negative camber, based on what you're telling us.
Natural camber when lowering cars varies from car to car. Some might lower and naturally end up with -1, -2 or anywhere in between.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Old 12-10-2013, 08:02 PM   #20
Pokeguyjai
Pokeguyjai's Avatar
But my car looks too cool with the negative camber!!! Just kidding lol
I will look into it, thanks again!!
Old 12-10-2013, 08:04 PM   #21
mfbmike
18x9.5 + 40 nt03's with 265/35 michelin PSS, -2 camber all around and no rubbing
the difference, coilovers.
Rubbing issues boricua FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-23-2013 07:28 PM
window sounds like its rubbing jybrd Issues | Warranty | Recalls / TSB 9 07-10-2013 05:45 PM
Rubbing sound? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-15-2013 11:06 AM
Tire rubbing sound, Please Help dco107 Scion FR-S / Toyota 86 GT86 General Forum 6 01-11-2013 10:05 AM
License plate rubbing on Trunk Jayde BRZ First-Gen (2012+) — General Topics 28 08-11-2012 09:45 AM
