Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
View Poll Results: Which square or staggered setup should I go with? | |||
18x9.0 +44 (square) | 22 | 28.57% | |
18x8.5 +43 (F) / 18x9.0 +44 (R) (used on TWS demo car w/ recommended 245/35R18 square tires) | 5 | 6.49% | |
18x8.5 +43 (F) / 18x9.5 +45 (R) | 16 | 20.78% | |
18x9.5 +45 w/ 245/35R18 tires (square) | 7 | 9.09% | |
18x9.5 +45 w/ 255/35R18 tires (square) | 27 | 35.06% | |
Voters: 77. You may not vote on this poll |
12-09-2013, 05:38 PM | #29 |
Drives: Attitude
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | chanomatik (12-09-2013) |
12-09-2013, 05:47 PM | #30 | |
Drives: 2005 Toyota Camry
I know what you are talking about though; on a S13/14 aftermarket coilovers would give worse clearance vs stock spring/shock. I can assure you that on FRS/BRZ, this is not the case and where the spring perch on the front strut sits is virtually identical to where the aftermarket spring sits, assuming "normal" spring length and shock travel on most off-the-shelf coilover kits. -alex |
The Following User Says Thank You to mav1178 For This Useful Post: | FM Wheels (12-13-2013) |
12-09-2013, 06:00 PM | #31 |
A better example:
This is a stock replacement S13 front shock. If one were running a stock diameter tire (any size), the tire would end up sitting slightly below the spring perch. I've seen someone run a 17x9 +30 R33 GT-R wheel with spring/shock only on a S14 with no fitment issues. However, look at the same assembly for aftermarket coilovers for S13/14: The spring is physically smaller, but it is lower and given the same size wheel, you'd have less clearance on the inside. But this is not an issue with our cars, since the factory spring perch location is same as aftermarket coilovers. -alex |
The Following User Says Thank You to mav1178 For This Useful Post: | chanomatik (12-09-2013) |
12-10-2013, 10:25 AM | #32 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
12-10-2013, 11:02 AM | #33 |
Glorious BRZ Master Race
Drives: Subaru Libird
Suspension clearance shouldn't be an issue as I will have ST coilovers.
18x9.5 +45 w/ 255/35R18 tires seems to be the popular choice in this poll. I've been getting mixed opinions saying 255 will or won't rub the inner fender liner but if I choose a narrower tire (Hankook V12) I should be ok. If clear, would anyone think pushing it to 265 would clear with no fender modifications? @DAMotorsports fit 275 square without rubbing nor fender mods but offset was around 42 or 43 IIRC. Just asking for opinions on clearance, not asking whether it's suitable from a functional aspect (I know when 265 is overkill).
12-10-2013, 11:25 AM | #34 | |
Drives: 2013 Scion FRS "Raven"
@desertfrs was running 265/35/28 v12 on his car before going to 275's. He was not rubbing and I believe he was running 18/9.5/+40 but I’ll let him chime in. We chose the widest tire we could due to the overall plan for the car. We started with a +48 and added 6mm spacers putting us around a +42. We daily drive the car with 1.5 camber and 0 toe. Our ride height is 26.5 inches from the ground to the center of the fender. |
12-10-2013, 03:01 PM | #35 | |
Drives: 2013 GBS BRZ (AT)
I have 245/35/18s on TC105Ns 18x9.5 +35 offset. I have Racecomp Yellows that lower the car 0.8", I plan on installing my Koni Yellows soon but I am guessing those will not have an effect on the ride height. Any ideas? |
12-10-2013, 03:05 PM | #36 | |
NASA SpecE30 Racer
- King Tut
The Following User Says Thank You to King Tut For This Useful Post: | Pokeguyjai (12-10-2013) |
12-10-2013, 03:10 PM | #37 |
Thanks for the advice. I'm going to keep an eye on it to make sure it only happens when I go full lock (I only go full lock when I pull out of my drive way, so at low speeds) I actually feel the wheels shudder when it happen, so it is easily avoidable in the future.
12-10-2013, 03:54 PM | #38 | |
The Following User Says Thank You to switchlanez For This Useful Post: | Pokeguyjai (12-10-2013) |
12-10-2013, 04:01 PM | #39 | |
Sorry but not really sure what you mean but inside or outside? |
12-10-2013, 04:04 PM | #40 | |
What is your tire model?
12-10-2013, 04:11 PM | #41 | |
It is rubbing on the inside, the markings are on the springs and spring perch. |
12-10-2013, 04:34 PM | #42 |
NASA SpecE30 Racer
I was confused, I thought you meant you are rubbing the frame rails on the inside. I am really surprised you are still rubbing the spring perches. My advice is now to ditch those Yellows and Konis and get some Tarmac Zeros or another coilover with a smaller spring diameter.
- King Tut
Similar Threads | ||||
WheelDude.com | Rota Torque - Staggered and Square setup - IN STOCK and ready to ship | WheelDude.com | Wheels and Tires | 6 | 08-20-2013 09:34 PM |
Square vs staggered setup | slowbrz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 05-11-2013 10:18 PM |
Staggered wheels + square tyre setup? | white_knight | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 03-18-2013 09:27 AM |
Staggered vs. Square | WWEVOX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 01-12-2013 03:57 PM |
Square or Staggered? | dabocx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 02-02-2012 09:40 PM |
