Old 12-10-2013, 02:36 AM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
REVIEW | Raceseng UPM (Universal Plate Mount)
I bought the @Raceseng UPM (Universal Plate Mount) last week, after realizing that this had came out recently. I previously purchased their Tug View tow hook/GoPro mount, so the tug shaft that is needed for install was already on the car.
The details on the product can be found on the Raceseng website, here's my install pics:
Some thoughts:
  • You get what you pay for: this is over twice as expensive as the Grimmspeed kit, but the build quality is more than that.
  • Very solid construction. With the bolts tightened down, the plate mount is not movable with normal force.
  • Speaking of force, the way this is designed is beautiful. It's an outrageously simple design, yet allows almost any type of license plate angle to be achieved.
  • Lastly: this is less prone to nuts/bolts loosening than the Grimmspeed design.
UPM:
http://www.raceseng.com/upm-universal-plate-mount
UPM w/ tug shaft:
http://www.raceseng.com/upm-universa...r-s-subaru-brz
-alex
Ammunition (12-10-2013)
Old 03-20-2014, 06:55 PM   #2
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
This is great, have you noticed anything since install? I'm considering buying this.
leicaboss is offline   Reply With Quote
Old 03-20-2014, 07:28 PM   #3
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
@Raceseng if you could integrate a GoPro mount somehow on this thing I would buy it to replace my GrimmSpeed
cdo221 is offline   Reply With Quote
Old 03-20-2014, 07:41 PM   #4
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Already done:
http://www.raceseng.com/tug-view-tow...r-s-subaru-brz
The Following User Says Thank You to NLSP For This Useful Post:
cdo221 (03-20-2014)
Old 03-20-2014, 07:46 PM   #5
cdo221
I mean, a license plate relocator that also can do a GoPro at the same time .. it looks like you have to swap remove the license plate for the GoPro mount to work in this case. Or did I get it wrong, GoPro can still go mount on with the license plate on..?? haha I'm confused
Old 03-21-2014, 12:41 AM   #6
mav1178
mav1178's Avatar
That wouldn't be very ideal, you're looking at a backplate that has the GoPro mounted far away from the anchor point. It would introduce a lot of vibration and make it useless.
I got this UPM because it gives me a quick way to swap out to the GoPro mount:
http://www.ft86club.com/forums/showthread.php?t=53205
-alex
cdo221 (03-21-2014)
Old 03-21-2014, 01:07 AM   #7
cdo221
-alex
Ah I see what you mean. So basically if I got these two items:
I would essentially be able to do a quick swap between 'license plate' and 'tow hook + GoPro' mode, say in a parking lot or something? I assume you need to remove the license plate itself off the UPM before the UPM can be removed? At least that's how the grimm speed works, removal of the license plate off the plate holder first, then removal of the plate holder, then the shaft that goes into the bumper.
Old 03-21-2014, 01:19 AM   #8
mav1178
mav1178's Avatar
Quick is an understatement.
Once you've set the GoPro mount and the license plate mount orientation properly, every time you remove/install the different mounts you will end up at the proper position for either GoPro or the license plate.
The Raceseng mount allows you to twist the entire plate holder (with plate) off, and you won't lose the position you set. This is assuming you installed the shaft with Loctite as the instructions mandate.
So far I've changed my plates/GoPro mount about 10 times, it gets easier and easier to do.
-alex
cdo221 (03-21-2014)
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Raceseng | Tug View - Tow Hook + Go Pro Mount Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 1 08-27-2013 01:47 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
Raceseng | Tug View - Tow Hook + Go Pro Mount Raceseng Tracking / Autocross / HPDE / Drifting 0 08-14-2013 03:52 PM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
