#15 |
Drives: Firestorm Scion FR-S
wow its funny I was just asking myself this question today and decided to search it and what do you know. lol So let me get this straight If I have a aem failsafe gauge and have it on AFR. On E85 how rich/low should it be going at wot.
FA20 club 60 trim + flex fuel 467 whp 356 ft lbs @ 19 lbs Owner of Sidewinders Auto LLC. San Antonio TX |
#16 |
if you're n/a then probably no richer than 12.5:1, fi maybe 11.8-12:1. e85 works well over a much wider range of afr's than gasoline, so depending on who you ask you'll get a different answer. there are a wide range of opinions on the topic, but the generally accepted idea is that it's safe to run at least one full afr point leaner than you would on pump gas.
| The Following 2 Users Say Thank You to jamesm For This Useful Post: | bgibbsunc (12-09-2013), Sportsguy83 (12-09-2013) |
#17 | ||
#18 | |
Junior
Drives: a car
As a rule of thumb I always learned that turbo cars run more rich than NA cars. Turbo AFR's usually fall between 11-12 under WOT, and like others said, no less than 12.5 for NA cars. Besides that's a seriously rich AFR, and you're MPG will suffer from that. A better AFR for NA is probably 13-14.
| The Following User Says Thank You to cdrazic93 For This Useful Post: | reeves (07-10-2014) |
#19 | ||
Drives: Mazdaspeed 3
However, since E85 is much higher octane, you can run a more aggressive cam profile to produce a higher dynamic compression ratio while cruising and boosting without encountering knock. This increases engine efficiency, so now you can go the same distance with 15-20% less E85. The newest generation of flex fuel cars is starting to take advantage of this to bring E85 mileage closer to that of gasoline. The current version of the Hydra firmware under development will also let you adjust cam profiles based on ethanol mixture to take advantage of this. Quote:
#20 | |
Junior
Drives: a car
lol jkYes, the milage is getting better, but there's still room for improvement, so for now unfortunately it's not quite up to par with gas MPG. But then again, that's not why I would be using E85 either.... ![]() that 15-20% less use of E85 due to the more aggressive cam tuning renders the E85 to be roughly what 1.2-1.25 gallons of E85 to 1 gallon of gas for the same distance?
#21 |
HINT:
Tuning for more power is completely different to tuning for MPG.
#22 |
Junior
Drives: a car
That's what I was trying to get at, but evidently failed at explaining. E85 is for making power not worrying about MPG's. Gas is for daily driving.
#23 |
#24 | |
Drives: FT86
As long as it was a constant offset you could adjust the OL fuel table to compensate. The OFT E85 tunes do a similar trick with injector scaling . |
#25 |
Drives: Hydra EMS Powered FRS Raven Black
I did experiment once to fully maximizing my Hydra EMS on my Legacy GT while using E85. The goal was the same power, so I ran the same boost level but maxized fueling, ignition timing, and variable can timing. I was able to get in the 10-15% range of gas fuel economy which was important as it made E85 about the same cost as fuel in terms of mileage.
Now E85 has a huge working range and I was able to run 17:1 in some areas and under full load I could run 13.5 AFR vs never leaner than 14.7 and 10.8 under load (stock TMIC). Now using the Hydra EMS on my FRS I'm seeing different fuel volume requirements because of the direct injection and how it increases the power potential of E85 even more than on a port injection only engine. Now I can run similar AFR ranges but I'm having to increase fueling I'm the +47% range at maximum power over pump fuel. Also I'm finding the FA20 motor does not want to run as rich on E85 to make maximum power like I see with our EJ race engines. On those engines we'll rich misfire before we peak out on power. Thanks, Phil Grabow |
