Old 12-09-2013, 02:28 PM   #1
sw20kosh
Drives: 2013 Black FR-S
The 86's Frontal Area
Does anyone know the frontal area of the twins? An estimate even?
Old 12-09-2013, 03:08 PM   #2
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
One method, but not sure if this is what you're asking.
FRS Cd is .27 and BRZ is .29 both without spoilers. Use formula from here to back calculate the area A
[ame="http://en.wikipedia.org/wiki/Drag_coefficient"]Drag coefficient - Wikipedia, the free encyclopedia[/ame]
garfull is offline   Reply With Quote
Old 12-09-2013, 03:10 PM   #3
fatoni
without looking into it, its looking like we still dont have all the values to do that.
Old 12-09-2013, 08:17 PM   #4
u/Josh
Drives: GBS Limited 6MT
Just estimate the frontal area as a rectangle and eyeball it with a tape measure. I guess you are trying to setup some kind of virtual dyno?
u/Josh is offline   Reply With Quote
Old 12-10-2013, 12:48 PM   #5
sw20kosh
Thanks for all the suggestions. Yes this is for Virtual Dyno.
I just basically used the frontal area of an integra. Should be about the same no?
Old 12-10-2013, 12:51 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
Should be about 20 ft^2
Old 12-10-2013, 07:46 PM   #7
d1ck
Drives: Black 2013 FRS
I've done this on another car by getting a straight on front picture and scaling it in autocad using known dimensions.
d1ck is offline   Reply With Quote
Old 12-10-2013, 07:52 PM   #8
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
You can't back calculate it from that knowledge alone - you would also have to know the drag force at some speed, or the drag area. The whole point of the Cd is that it's independent of the frontal area.
chrisl is offline   Reply With Quote
Old 12-10-2013, 09:43 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Use the longest focal length lens you can find.
Old 12-10-2013, 10:54 PM   #10
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
I remember someone said they did it using the frontal area of a 370Z a while back.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 12-15-2013, 04:35 PM   #11
icemang17
Drives: Scion FR-S/ Subaru BRZ
I doubt the FRS is 20ft.....my 928 is 21.28ft and its a MUCH larger-wider car....
icemang17 is offline   Reply With Quote
CT Area- Looking for a great detailing shop in the area Phothiraj NY / NJ / CT / PA 5 10-14-2013 01:37 AM
any weekly meets in the queens area or long island area subyboy NY / NJ / CT / PA 23 08-26-2013 06:51 PM
New to the Area. 86Trueno Northern California 5 07-19-2013 08:33 AM
