Old 11-23-2013, 06:11 AM   #379
thomsontrang
thomsontrang's Avatar
Drives: 86 GTS
Work Kiwami's 18x9.5 square with Nitto Invo's 255/35
thomsontrang is offline   Reply With Quote
The Following User Says Thank You to thomsontrang For This Useful Post:
humanshield (11-27-2013)
Old 11-25-2013, 11:34 PM   #380
captain_jack
captain_jack's Avatar
Drag DR31's 18/8 +35 and 18/9 +38 with federal ss595s 255/35/18' 1" drop.
sent from your mom
Old 12-04-2013, 03:28 PM   #381
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
sent from your mom
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
captain_jack (12-04-2013)
Old 12-07-2013, 05:30 PM   #382
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Is anybody running 255/35 or 265/35 on 18x9.5 +45 with no rub at full lock inside and outside? There are plenty of 9.5 +40 +42 +43 examples but I want to hear what the 9.5 +45 guys are experiencing. I know it depends on the wheel/tire which fit differently but since the wheel's (T66-F) actual fit is untested/unknown I can only go by a consensus referenced from other wheels. Trying to avoid tires that run wide such as MPSS (but please still post if you do have this spec with MPSS).
Old 12-08-2013, 06:35 PM   #383
captain_jack
I bought my tires from a guy who was running 18x9.5s all the way around with 255/35/18 and he wasn't rubbing.with a 1"drop as well. Don't know his offset though.decent tires fit a daily, they are federal ss595's
sent from your mom
Old 12-08-2013, 10:37 PM   #384
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
255/35/18 (R)
white_knight is offline   Reply With Quote
Old 12-08-2013, 10:56 PM   #385
switchlanez
Offset?
Originally Posted by white_knight View Post
255/35/18 (R)
Wheel specs/offset and front tire model/specs?
Old 12-08-2013, 11:21 PM   #386
switchlanez
Originally Posted by E46toFT86 View Post
Figured I'd post in this thread.
Stance SS Coilovers
CCW LM5T 18x9.5 +44, 18x10+38
Hankook Ventus V12 255/35 & 265/35
Front fender is rolled near the sidemarker. Plenty of clearance up front, could prob add 6 MM Spacer give or take to make the tires even more flush with the body. No tire stretch at all, FUNCTION + FORM Rears are pretty perfect flush fitment with minor camber. At my current ride height I dont rub @ all, but I havent really tested by putting a lot of load on the suspension. I can also achieve full lock at the front wheels.
You're the only person I've found on this forum close to the front tire/wheel size spec I've been looking for (been looking for Hankook V12 255/35 on 18x9.5 +45 and also V12 265/35). Do you think the front fender roll was necessary and what are your front height and camber settings?
The Following User Says Thank You to switchlanez For This Useful Post:
gkubed (04-14-2017)
Old 12-12-2013, 11:25 PM   #387
ShutterSpeed
Drives: Olive Drab/Army FRS
okay just looked through all 18 pages of this thread and i'm definitely going to post the meister's for sale and invest in some cr ultimates or maybe the new seeker fx with a 265/35 attached.
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
Old 12-12-2013, 11:34 PM   #388
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
sent from your mom
Would that be 255 sqaure? If so, do you have a closer pic of the fronts and how the tire looks on an 8" rim.
The Racers Line is offline   Reply With Quote
Old 12-12-2013, 11:55 PM   #389
captain_jack
This is all I have currently, but I will be going to a 225/35 soon as the front looks taller then the rears do.
sent from your mom
The Following User Says Thank You to captain_jack For This Useful Post:
Mr. (01-01-2014)
Old 12-13-2013, 01:24 PM   #390
The Racers Line
sent from your mom
Thanks mom! I appreciate it.
The Following User Says Thank You to The Racers Line For This Useful Post:
captain_jack (12-13-2013)
Old 12-15-2013, 06:32 AM   #391
thomsontrang
Drives: 86 GTS
Originally Posted by switchlanez View Post
Offset?
+38 all round, brother
also running -1.5 camber up front.
natural camber at the rear from lowering.
switchlanez (12-15-2013)
Old 12-15-2013, 02:50 PM   #392
switchlanez
Originally Posted by DesertFrs View Post
Gramlights 57Xtremes 18x9.5 40 offset
BFGoodrich G-Force Sport Comp 2
275/35/18
Will be updating soon with pictures!
Any rubbing on the inner fender liner at full lock? What's the reason you changed from the Hankooks to these?
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
