Old 12-07-2013, 12:04 AM   #15
cslntuee
Drives: Subaru BRZ Limited
HI,
I am interested in. Please keep update.
Do you plan to do the group buy?
By the way, why choose the size for 68 mm?
I did see the 70 mm product and still claim that can match stock ECU.
http://revo-tune.jp/catalogue/detail.php?id=294
Thanks.
cslntuee is offline   Reply With Quote
The Following User Says Thank You to cslntuee For This Useful Post:
MAPerformance (12-07-2013)
Old 12-07-2013, 08:30 AM   #16
Turdinator
Señor Member
Turdinator's Avatar
In for results
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 12-07-2013, 09:48 AM   #17
jdm-az-fuk
Drives: 2013 Fr-S
Ill be in for a 70mm option
jdm-az-fuk is offline   Reply With Quote
Old 12-07-2013, 09:50 AM   #18
MAPerformance
Drives: Asphalt FRS
Originally Posted by cslntuee View Post
HI,
Thanks.
If we have enough interested people we may do one. We may have to source a few cores first. And I believe 68 was as far as my machines felt comfortable going up to on the stock housing. But I will confirm with him.
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
cslntuee (12-07-2013)
Old 12-07-2013, 11:24 AM   #19
cslntuee
HI,
$250 is for a new one or it is modify from the stock which need
to send our stock to you?
TODA has taper design and mention "
the throttle shaft has not been modified to be thinner ; this is to increase the life of the single throttle body by retaining a more rigid shaft"
http://www.todaracingusa.com/catalog...idCategory=198
Thanks.
ps. I am interested, but I did not have enough knowledge for this.
I hope that you consider the optimize design there.
Old 12-07-2013, 11:46 AM   #20
MAPerformance
Drives: Asphalt FRS
HI,
Thanks.
We typically have two options. You can send your throttle body into us for no extra charge. This is if you have another car to use. Or, you pay a core charge up front and we will supply the throttle body. Once you receive ours, you will need to send your factory one back to us. We will then refund you the core charge. Ours will also have a tapered design. And to be honest, anything over 70mm will be overkill for this car, and I don't see any reason for one that large. Like I said, our shop Evo made 1053whp with a 70mm. I will keep you more informed of how we will handle the cores as this develops.
Old 12-07-2013, 12:20 PM   #21
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
subbed for dynos
The Following 2 Users Say Thank You to BlueDubbinTDI For This Useful Post:
cslntuee (12-08-2013), MAPerformance (12-07-2013)
Old 12-09-2013, 03:33 PM   #22
MAPerformance
Drives: Asphalt FRS
Sorry, we aren't going to go up to 70mm. The wall clearance is just too thin at that size and could run the risk of cracking.
Old 12-09-2013, 03:37 PM   #23
MAPerformance
Drives: Asphalt FRS
Originally Posted by Calum View Post
What angle are you cutting the new throttle plates at?
Sent from my GT-S7560M using Tapatalk
Sounds like we are using the stock angle for the throttle plate which I believe is 2 or 3 degrees. But don't quote me on that, I have to ask my machinist. We are going to use a stainless plate but it will remain the stock thickness so we can re-use the OEM rod.
Calum (12-10-2013)
Old 12-10-2013, 10:50 AM   #24
MAPerformance
Drives: Asphalt FRS
Bolted on our throttle body to my car to check everything, and it looks like the stock intake manifold is exactly 68mm. So anything bigger would not really benefit us right now. Not unless we look into intake manifold designs. Which we are still playing around with...Once we get the throttle plates finished, we can bolt it on our stock auto FRS and see if there are any gains. Any tuners out there N/A and F/I want to take one from us and do some testing with a tune? PM me if you are interested.
cslntuee (12-10-2013)
Old 12-10-2013, 12:42 PM   #25
xxscaxx
Drives: 2013 SWP BRZ
what about bolting it up to an innovate charger? The back elbow on it can be removed and ported, not sure by how much as theres a gasket there but theres some material that looks like it can be removed.
xxscaxx is offline   Reply With Quote
Old 12-10-2013, 12:49 PM   #26
MAPerformance
Drives: Asphalt FRS
Yes, that is a great question. We may have a tuner that is willing to test one out on a few turbo cars and an Innovate equipped car as well. But we may be able to hand port those elbows as well. It would be nice to take a look at one...
Old 12-10-2013, 12:53 PM   #27
xxscaxx
I have an innovate charger...so if you need anything, just let me know If you want I can talk to the few tuners i've worked with and see if they would be interested in testing it out and could use my car as the mule if needed. I don't want to clutter your thread though so if interested just send me a pm.
Old 12-10-2013, 03:25 PM   #28
cslntuee
I remember that the stock throttle body is 65 mm.
Will that gain something from increase the diameter to 68mm which can directly match the stock intake manifold or do you mean there is almost no benefit there ?
Will you still plan to show the dyno result?
Thanks again
MAPerformance (12-10-2013)
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 10:58 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
