Old 12-05-2013, 03:09 PM   #1
TheLaughingMan
TheLaughingMan's Avatar
TheLaughingMan's ハチロク - 427HP @ 5,280ft
Figured I would start one of these as a place to keep track of what I want to do and what I've done.
Stock Weight: 2760 lbs (full tank, no passengers)
Stock Horsepower: 162.7 HP
Stock Torque: 128.8 ft-lb
Stock Power/Weight Ratio: 16.96 lbs/HP
Stock Torque/Weight Ratio: 21.43 lb/ft-lb
Upgraded Weight: 2800 lbs (estimate)
Upgraded Horsepower: 427.3 HP
Upgraded Torque: 349.9 ft-lb
Upgraded Power/Weight Ratio: 6.55 lbs/HP
Upgraded Torque/Weight Ratio: 8.00 lb/ft-lb
If you're curious about prices, I have an in-depth Excel sheet that I'm using to track all of that. You can find it here: https://www.dropbox.com/s/wl0zhn50g6k5nvg/FR-S%20to%2086%20Conversion.xlsx?dl=0x. Feel free to use it or modify your own copy if you want.
Exterior:
  • 15% tint
  • DIY Rear Foglight Mod (pic)
  • Toyota badges
  • GrimmSpeed Plate Relocation
  • JDM-style side markers (smoked)
  • "86 Piston" License Plate Frame
  • DiodeDynamics LED turn signals, sidemarkers, license plate lights, reverse lights + LED Flasher Relay
  • Winjet JDM Headlights (Chrome) - painted black to match Japanese 86
  • FT-86 SpeedFactory/Velox Rear Diffuser
  • FT-86 SpeedFactory/Velox Street Performance Front Splitter + Race Upgrade
  • Rexspeed Carbon Hood Dampers
  • Velox Slanted Hood Louvers
Drivetrain:
  • MTEC Shift Springs
  • Driveshaft Shop 600HP Rear Axles
  • Mfactory 4.67 Final Drive Gear
  • ACT XT Street Clutch Kit w/ Lightweight Flywheel
Brakes:
  • FT-86 SpeedFactory Stage 2 Brake Package
  • Perrin Master Cylinder Brace
Wheels/Tires:
  • Kosei K4Rs (17x8)
  • Hankook Ventus RS4s (245/40ZR17)
Cooling:
  • Subaru Forester XT OEM Oil Cooler
  • Beatrush Oil Sandwich Adapter (not technically cooling, but located near the oil cooler)
Engine:
  • Perrin Lightweight Crankshaft Pulley (Red)
  • EcuTEK Racerom + Custom E85 tune from James Martin of HRITuning (9lb map, 12lb map)
  • Omni-Power MAP Sensor - 3 bar
Forced Induction:
  • Revolutions Performance RP400 Turbo Kit w/ Garrett GTX2867R turbo - powder coated, recirculating wastegate
  • Turbosmart Race Port Blowoff Valve
  • Turbosmart 40mm Wastegate
  • Mishimoto Intercooler (black)
  • GrimmSpeed Boost Control Solenoid EBCS
  • PTP T3 Lava Turbo Blanket
Fuel System:
  • Full Blown Walbro 485 Pump
  • Injector Dynamics ID1000s
  • Moto-East Flex Fuel Kit (E85)
Exhaust:
  • Perrin Overpipe
  • Invidia Resonated Front Pipe
  • Invidia Q300 w/ Rolled SS Tips Cat-Back
Interior:
  • DiodeDynamics EL "86" console plate (Red)
  • Ortiz Custom Cluster Dual Gauge Pod (52mm)
  • Toyota Cowboy Hat steering wheel emblem
  • Panorama S 2015 Sony Exmor DashCam
  • Esky EC170-06 Backup Camera
  • AEM Wideband Failsafe Boost/AFR Gauge
  • Pioneer AVH-2330 NEX with AndroidAuto
  • Innovate MTX Digital Dual Function Gauge (Oil Pressure & Temp)
Current Photos (swapped out as work is done):
TheLaughingMan is offline   Reply With Quote
Old 12-05-2013, 03:31 PM   #2
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
did you upgrade the radio?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 12-05-2013, 03:34 PM   #3
TheLaughingMan
Nope. That's what it came with
Old 12-06-2013, 08:05 AM   #4
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
I believe the new FRS's come with that new radio.
Enraged21 is offline   Reply With Quote
Old 12-06-2013, 10:25 AM   #5
mike the snake
Ghost in the Shell is one of my favorite Anime shows. Great name!
Old 12-06-2013, 11:28 PM   #6
MemphisR
Memphis
MemphisR's Avatar
The 2014s do. Not the 2013s.
Old 12-07-2013, 12:21 PM   #7
Enraged21
#RememberTheBuster
Enraged21's Avatar
yeah that's what I meant as "new". My bad lol
Old 12-07-2013, 09:29 PM   #8
MemphisR
Memphis
MemphisR's Avatar
But i noticed that yours doesn't have the knee padding on the speaker and stereo areas
Old 12-07-2013, 09:51 PM   #9
AnDrEs K
AnDrEs Kfrs
AnDrEs K's Avatar
Drives: 2013 Whiteout frs
Mine is 2013 and it comes with it
AnDrEs K is offline   Reply With Quote
Old 12-07-2013, 10:47 PM   #10
TheLaughingMan
Indeed it does not. I know I could add them but honestly they don't appeal to me that much *shrug* could find better uses for the money.
Old 12-12-2013, 06:21 PM   #11
TheLaughingMan
Got my stock weigh in today (full tank, no passengers) Now just need to do the stock dyno so I can get a baseline power:weight. After I'm done with everything I will do it again and hopefully it will be better lol
Old 12-15-2013, 01:36 AM   #12
TheLaughingMan
Finished the DIY rear fog light mod and removed the rear seats, spare, tools
Old 12-21-2013, 12:10 PM   #13
TheLaughingMan
Got the baseline dyno done today at Revolutions Performance (http://www.revolutionsperformance.com)
[ame]http://youtu.be/0FbduFgJPBY[/ame]
Now the fun stuff can begin
Old 02-08-2014, 01:37 AM   #14
TheLaughingMan
Quick little sneak peak (I'm not showing it all here). I will be doing a proper photoshoot soon I hope (it's been cold and snowy).
ハチロク, conversion, jdm, thelaughingman, toyota 86
86&BRZ パワーチェック ???????? ESBjiujitsu Engine, Exhaust, Transmission 3 05-24-2012 09:08 PM
