Old 12-02-2013, 04:20 AM   #85
uEih
Drives: CBS Subaru BRZ Limited
Whoa that front lip is a at a great price! I'll hold off though, already spent too much this weekend. What I wanna know is is the genuine STi lip a flat matte black color/texture? I'm planning to paint the lip and would like to get it as close to the genuine texture as possible.
uEih is offline   Reply With Quote
Old 12-06-2013, 11:24 AM   #86
septiq
septiq's Avatar
Drives: 2013 DGM BRZ
For anyone that has the side skirt installed, did you run into a problem with a gap in the rear section where the skirt curves upwards? That damn section refuses to stay flush with the car. Any ideas?
septiq is offline   Reply With Quote
Old 12-06-2013, 12:19 PM   #87
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Mine is having trouble a bit lower than that. About midway to the start of the upward curve.
Gonna order some of this... might be a bit overkill...
[ame="http://www.amazon.com/dp/B0016HM7SE/ref=cm_sw_r_udp_awd_iyGOsb08T3J2T"]3M VHB Heavy Duty Mounting Tape 5952 Black, 3/4 in x 15 yd 45 mil: Amazon.com: Industrial & Scientific[/ame]
Old 12-06-2013, 01:01 PM   #88
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Can you guys post a couple of pics of the gaps ?
Thanks
Sent from Note 3 SM-N9005
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-06-2013, 02:48 PM   #89
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
yes, pics of gap please ? I just ordered mine, if there's a gap, I want to return it ><
ucsmfu is offline   Reply With Quote
Old 12-06-2013, 03:01 PM   #90
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
I don't know if you should be too concerned, others have installed and posted pics of these and fitment looks to be perfect. Proper placement of 3M tape should prevent any gaps
2URGSE
The Following User Says Thank You to JPxM0Dz For This Useful Post:
ucsmfu (12-06-2013)
Old 12-06-2013, 03:46 PM   #91
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Do you know how many holes need to be drilled for the front lip? Have you received yours yet? How does it look?
Old 12-06-2013, 05:20 PM   #92
septiq
septiq's Avatar
Yeah the tape that it comes with doesn't seem too strong. I purchased the 3M Black Automotive Acrylic Attachment Tape, put two layers on for extra thickness , and reattached the skirt. Gonna let it cure for a bit but it looks like it's going to stay on now
Old 12-06-2013, 07:36 PM   #93
Andrew025
Andrew025's Avatar
Yes, fitment is great; the tape that is included isn't.
It seems to have trouble sticking to the skirt.
Old 12-06-2013, 08:07 PM   #94
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Thanks for the heads up! So gaps were not an issue due to fitment then. I'll use some more aggressive 3M tape before install.
For the record, the tape included worked great for the rear aprons and it's the same stuff including same ABS plastic
On a side note guys, and may not be directly related to those that are have issues with the 3M tape sticking to the ABS plastic, but make sure you clean both the inside of the skirt with alcohol and obviously the painted area where skirts will attach beforehand.
I just checked my skirts out as they are already prepped for install, tape looks good. I tried to lift the tape with my finger nails in a few locations across the skirts and it's holding tight as it should. I also ran a piece of 3M tape down the edge of the widest part of the skirt near the back to help pull it in tight against the body. I used my own 3M tape of course because the tape that is included is only enough to run along the edge of the weather strip all the way down the inner portion of the skirt.
I can attach pics if anyone's interested...
2URGSE
Old 12-07-2013, 02:56 AM   #95
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
yes plz, which kind of double sided tape would you guys recommend ?
Old 12-07-2013, 11:58 AM   #96
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Any automotive grade double sided 3M tape will be fine. Can be found at most hardware and auto parts stores. Also, lot's of choices for size and length all over ebay
2URGSE
Old 12-07-2013, 01:44 PM   #97
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Here's a shot of where I applied 3M tape...
2URGSE
ucsmfu (12-07-2013)
Old 12-07-2013, 08:33 PM   #98
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
received the entire kit today.
Does anyone have the diffuser from bayson R ? drilling required ?
STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 31 12-03-2013 10:57 PM
CS Style Polyurethane Side Skirts Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 14 11-04-2013 09:49 PM
WTB CHARGESPEED STYLE SIDE SKIRTS. bahanii Want-To-Buy Requests 1 10-18-2013 02:06 PM
FS: CS Style Side Skirts and Rear Spats FRS2000 Exterior Parts (Aero, Lighting, Etc.) 4 09-23-2013 12:15 PM
2013 SUBARU BRZ J STYLE PU SIDE SKIRTS JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 7 05-10-2013 11:29 AM
