| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
200hp/2762lb (BRZ Premium) = 13.8 pounds per horsepower 265hp/3252lb (WRX limited) = 12.3 pounds per horsepower 305hp/3417lb (STI limited) = 11.2 pounds per horsepower Even the base WRX has a better power to weight ratio than the BRZ, and the STI blows it away. To match the STI's power to weight, you'd need about 250hp in a BRZ. |
#58 |
Trust me, I'm the Doctor
Eh, I was probably remembering back when we only had estimates and someone did a bhp/weight comparison over on another forum.
That is easily doable on FI with boost pressures that would be well below what an STI driver would consider "useable" on his vehicle.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#59 |
#60 |
Drives: WR Blue BRZ, 240Z
A car has to be heavy enough to get the tires up to proper operating temperature. Just slapping 255's where 215's once were doesn't improve performance. If this were true, why not use 275's...or 305's...
In the case of a light weight / low powered car, wider (and by default, heavier) tires hurt performance. Higher unsprung weight makes the suspension and brakes less effective. Higher rotational mass reduces acceleration and cold(er) tires result in a lower coefficient of friction. Where's the benefit here? Oh, they look better.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#61 | |
Drives: Sterling Silver BRZ Limited MT
http://www.ft86club.com/forums/showthread.php?t=42085
#62 |
Drives: 2009 Scion tC RS 5.0
You'll get more bang for your buck with a gym membership if you're looking shed pounds in the BRZ.
09 RS 5.0 -- #862 of 2000 -- 5spd
#63 | |
#64 | |
I've spent a lot of money to shed weight on this car. Why would I piss it away on 30 pound tires? There are many great performance tires in the 20 to 24 pound range...tires that this car's power, chassis or suspension will ever out drive.
| The Following User Says Thank You to Gary in NJ For This Useful Post: | SirBrass (12-05-2013) |
#65 | |
#66 | |
grassroots did an experiment where they took a car and had two setups with the same tire but one wheel was 3 lbs heavier. at the end of the day, it was faster than the lighter tire. do i think heavier wheels are faster? no. i just dont think its nearly as significant as you make it seem. besides, what size tire are you finding a ten pound discrepancy? maybe some run flats or offroad tires but even then its not the weight that is killing the performance. |
| The Following User Says Thank You to fatoni For This Useful Post: | SirBrass (12-05-2013) |
#67 |
Drives: 2013 Scion FRS in white out
I am new to the car world but have spent many years on motorcycles, dirt, street, and race track. I'm sure someone will correct me if I'm wrong, but on a bike 7lbs weight loss is effectively the gaining of one horse power. So really if its true to a car 70lbs weight loss should effectively give you a 10hp increase.....anyone else ?
#68 | |
Dismember
Drives: 2013 Red Scion FR-S
#69 | |
Drives: 2014 WRB BRZ 6MT
#70 |
Drives: '23 BRZ
2900 lb. car with 200hp
70 lb. weight loss => (2900/2830)*200 - 200 = 5hp Losing 70 lb. would be the equivalent of gaining 5 horsepower as far as power/weight goes (which has a strong correlation with 1/4-mile trap speed). |
| Tags |
| weightloss, you're all too fat! |
| Weight Loss Potential Thread | Entropy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 01-16-2017 04:51 PM |
| ≥≥≥ WEIGHT LOSS PROGRAM ≤≤≤ Lightweight battery kit. New Years Resolution Complete!!! | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 52 | 05-26-2013 11:19 PM |
| CEL, Loss of Traction Light, Loss of Power | pituala | Issues | Warranty | Recalls / TSB | 19 | 09-05-2012 11:23 AM |
| Weight loss potential? | SevenTenSplit | Engine, Exhaust, Transmission | 10 | 12-10-2011 02:16 PM |
| weight loss | cynic | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-24-2011 04:04 AM |
