Old 06-27-2013, 03:00 PM   #15
Dante@Hidguy
Dante@Hidguy's Avatar
Drives: Audi A4
Originally Posted by BadMoon View Post
I was never a guy willing to take a risk at modding bulbs. I've installed HID kits in projector lamps. But never been willing to mess with the other stuff. I get the look I want without the risk. I don't have a problem seeing the road although these do not put out the same light as an HID. There is no comparison.
I agree with this statement. There is zero comparison even if you put it up against a H9 bulb.
- Dante
P: 619-427-7116 x.302
W: www.HIDGuy.net
E: Dante@HIDGuy.net
Dante@Hidguy is offline   Reply With Quote
Old 12-04-2013, 10:36 PM   #16
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
If it was me, I would get aftermarket bulbs in the stock halogen projector.....
2500k- 5000k H11, 55W
The cheapest and reliable way to go without worrying about burnt out wires or drawing more power.
CyberFormula is offline   Reply With Quote
Old 12-05-2013, 12:49 AM   #17
Poodles
Drives: 2015 Series.Blue
Originally Posted by infinite012 View Post
Aren't H9 going to put out more light than the H11? Go with the H9...
Also, getting a blue tinted bulb is going to harm light output. Think about the last time you sat in a car with window tint. It blocked light, right?
Correct. The halogen cycle doesn't but out a lot of blue wavelength. That's what the coating does, block everything that's not blue. They then run the bulbs hotter and harder leading to less life. There's more to it, but it's all BS marketing...
H9 is 2100 lumens vs H11 at 1250 (quality OEM HID is 2800 (D2R) to 3200 (D2S) with most aftermarket bulbs being lower)
Originally Posted by 86WRX View Post
My only concern swapping H9 with H11 will create more problems down the road.
First off H9 draws more electricity than H11 which in the long run had chances to burn the wired and housing of our projectors which are difficult and expansive to replace.
Possibly. They're only 10 watts different which is minor in the scheme of things on the wiring. I'm betting the high beams use the same gauge wiring so it's likely fine. The housings, I'm unsure if the projector housings are metal. If they are, they're fine.
Alternator issue- since the wattage are higher, the alternator works extremely harder to put out energy and heat to keep up with the higher wattage lamps. That will shortens the life of the alternator which costs at least $300 or so to replace.
Extremely doubtful. There's quite a large margin built into these things. Also, the headlights aren't near the drain of the electric fans on the radiator. Not going to have issues from 10 more watts, period.
H9 is a high beam light bulbs. That means we are running a high beam at all time. The heat output and the life of the light bulbs will reflect on how long the bulbs will last.
The choice and decision we made is end up we suffers towards your pocket unless you lease your FRS, then do whatever. Here are my humble $.02
Andrew
H9 is not a high beam bulb. It's used all the time for low beam halogen projectors. Yes, they will burn out faster given their output (blue coated ones lasting even less time)
Old 12-05-2013, 04:01 AM   #18
Bushman7140
Drives: 2013 FRS M/T Firestorm
First try uploading a pic from an iPhone, This is the sylvania zxe H11's..
Bushman7140 is offline   Reply With Quote
Old 12-05-2013, 06:09 AM   #19
CyberFormula
looks good.
Try shooting from a distance and from the side where it shoots a wall.
Old 12-05-2013, 09:43 AM   #20
Bushman7140
Here, now that I'm on a PC this is a little easier...!!
Old 12-16-2013, 09:11 PM   #21
kALMIGHTY
Drives: TRD Ultramarine '13
I went ahead a while ago and just got HID's from @Diode Dynamics. They're perfect and I'm glad I didn't just got with H9's or tinted H11's.
Name:  Screen Shot 2013-12-16 at 6.10.39 PM.png
The Following User Says Thank You to kALMIGHTY For This Useful Post:
Diode Dynamics (12-17-2013)
Old 12-17-2013, 12:12 PM   #22
Diode Dynamics
Diode Dynamics's Avatar
Nice!
Those look awesome! Thanks for your order
Nick C.
John C.
Diode Dynamics
Cheapest way to eliminate the torque dip allawd Engine, Exhaust, Transmission 42 04-24-2013 10:40 PM
Cheapest way to get 5-Axis or TRD wing in Canada? SkAsphalt CANADA 13 03-22-2013 12:07 AM
LED WHITE COURTESY FOOT LIGHT- Group Buy F-T Exterior Parts - Lighting 2 03-04-2013 05:59 AM
Gram Light equipped white GT86 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 34 02-17-2012 04:20 PM
