Old 12-03-2013, 11:59 PM   #659
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Ok the pen worked. May I suggest a "calibration failed" dialog. Thanks for the help Rombinhood. Now to see if I can download/upload/write the 1.34
Sc10n FRS #0664
ReThink is offline   Reply With Quote
The Following User Says Thank You to ReThink For This Useful Post:
Rombinhood@OpenFlash (12-04-2013)
Old 12-04-2013, 12:11 AM   #660
Sterling Doc
Drives: 2002 911 Targa
I had the same issue with calibration screens, "not initialized" errors, and locking up. After calling Vishnu, I uninstalled the open flash manager, and then connected to the tablet after going through the calibration process one more time. So far, it seems better tonight.
Liking the tunes!
Sterling Doc is offline   Reply With Quote
Old 12-04-2013, 12:12 AM   #661
ThisGuy919
While im trying to upload the new maps to the tablet im getting an "Error 0x63 while communicating with the device" is anyone else getting this?
ThisGuy919 is offline   Reply With Quote
Old 12-04-2013, 12:13 AM   #662
Drives: FRS
Are you connecting to a USB 3.0 port? If so that is the problem. Try a USB 2.0 port instead.
Rombinhood@OpenFlash is offline   Reply With Quote
Old 12-04-2013, 12:15 AM   #663
ThisGuy919
Using a 2.0 port
Old 12-04-2013, 12:16 AM   #664
Drives: FRS
Using a 2.0 port
Try launching the software first and then plug in the OFT. Sometimes that works on certain computers for some reasons. If that still doesn't work for you, I suggest trying it on another computer.
The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post:
ThisGuy919 (12-04-2013)
Old 12-04-2013, 12:22 AM   #665
ThisGuy919
that did it.. weird
The Following User Says Thank You to ThisGuy919 For This Useful Post:
Old 12-04-2013, 12:35 AM   #666
Drives: FRS
Well that was a productive hour or so
Old 12-04-2013, 02:18 AM   #667
akyp
Drives: 2012 86
I saw that about a month ago with 1.03. Couldn't read nor white to the OFT. Only thing I could was resetting the OFT which meant I had to start from scratch. Fortunately I had yet to flash my car then.
akyp is offline   Reply With Quote
Old 12-04-2013, 02:22 AM   #668
Drives: FRS
After a recent firmware update (auto update through wifi), the OFT was no longer compatible with v1.03 of the OpenFlash Manager. Which is why v1.04 was released at the same time. Unfortunately many people only learned that out after running into the problem. Easy fix but perhaps we should create a mailing list that keeps customer updated with such news since not everyone visits this forum daily.
The Following 2 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post:
DAEMANO (12-04-2013), toysub (12-04-2013)
Old 12-04-2013, 03:03 AM   #669
Tromatic
Can you prevent auto-updates? Mine will be connected to a desktop PC. I can't imagine why you would want to, but can you prevent it?
Old 12-04-2013, 03:13 AM   #670
Tromatic
Looking at the ROM files. I'm sure this is mentioned somewhere, but I've been doing a lot of reading.
These are the files in the OFT FA20 ROMS v1_34.zip 6AT file:
Stg 1 ZA1J900D.bin
The improved tune for a basically stock car, correct?
Stg 2 ZA1J900D.bin
The improved tune for a car with upgraded intake and or exhaust, correct? But CAN be used with care while monitoring some values for a bit, correct?
Stg 2 E85 ZA1J900D.bin
The E85 tune. Is there a Stage 1 for a stock car, or do you use this one?
Stock Mapping ZA1J900D.bin The "stock" OEM tune, correct?
Sorry for the stupid questions.
Old 12-04-2013, 03:41 AM   #671
cnk
Drives: '13 DGM BRZ Limited
Stg 1 ZA1J900D.bin
Stg 2 ZA1J900D.bin
Stg1, stock or car with exhaust. Stock intake.
Stg2, for cat-less headers only. Stock intake.
Stg2 E85, was tested on a car with cat less headers, but should be OK on a stock car based on folks that have tried it out on the forums. Stock intake.
Stock, stock mapping. Your stock rom is stored on the OFT in bank 1
As for not auto-updating, I guess you could try not having your computer connected to the internet, but you really should be getting updates and checking www.procedetuning.com for updated software as well.
Sent from my Transformer using Tapatalk 4
Old 12-04-2013, 03:48 AM   #672
autobrz
Drives: Mazda 3
Noob question, I compared stg 1 v1.34 to stock rom. I saw there was quite a bit of timing advance put into the base timing in the upper rpms (about the same amount when comparing stg1 to stg2) I'm trying to go for a super conservative tune to completely eliminate any knock even under the most stressful conditions (track in 110 deg weather).
So what I did was removed any added timing (go back to stock) from 3600-7400 rpms in the base timing and ign timing adv tables but kept all the values 3200 rpms and below in the base timing (because those won't see track conditions) and kept all the timing retard (compared to stock) in the ign timing adv table. Does that sound like something reasonable to do?
Also when I looked at the VVT tables, I'm not seeing values in the x and y axis that make sense. I'm looking at the ZA1J900D roms. Are they supposed to be rpms for y axis and load for x axis?
autobrz is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
