Old 11-28-2013, 08:01 PM   #813
kayhettin
kayhettin's Avatar
Drives: Firestorm FR-S
The main factor is my Apexi Exhaust. It's 2.36in i.e. 60mm.
Kayhettin of Elysiam Entertainment
2013 Firestorm FR-S 6MT First 86
www.facebook.com/elysiamguild
kayhettin is offline   Reply With Quote
Old 11-28-2013, 10:06 PM   #814
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by sw20kosh View Post
Awesome!
Just wondering what your sense is on why 6 psi = 297 whp and then 9 psi = 308 and 315 whp. If the kit is really at a timing advance wall at ~300 whp is it worth it to go 3 more psi for marginal gains?
Is it because the 6 psi is tuned more aggressively while kayhettin and yours is tuned very conservatively which would explain why there isn't a bigger difference?
Yes, as I tuner I like to avoid running too much boost if the timing is not available. Sure it's cool to say you can tune a stock engine to 14psi on pump gas, but in the end the engine is not happy at all and will not give you a very good return in whp per psi.
Even at 6 psi, we're just barely able to achieve mbt timing. I know this because all of our tuning is done on a very accurate reading dyno. Above 300whp, we're tuning with the knock limitations of the fuel in mind. This is the reason we're not getting the same power return per pound of boost when we go higher in boost. With that said, I still think it is worth going to 9psi for those looking to break 300whp on our dyno. I would definitely not look to go any further on 93 pump gas though. If we were to run 100 octane fuel or WMI, we'd be able to tune for mbt timing, run a leaner AFR, and likely be closer to the 330+whp range at 9psi. Hope this makes sense.
Kayhettin's car is the only car of the three initial releases that does not use our 3" DS-333 exhaust system. It still makes very good power, but loses a bit on the top end due to the 2.35" chambered muffler exhaust system.
One thing to note too for those that are curious about the UEL vs UL vs small turbo vs large turbo debate. Our particular combination of the factory UL manifold and large turbo makes great torque way down low and at the same time makes usable power all the way to the new 8K redline There is not a huge drop off in in power after the usual power peak, hence our reasoning for tuning to 8K. With our 4-1 UL race header in place, we were seeing peak power that held all the way to 8K+ rpms. Just some food for thought.
- Toan
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
Dinko (11-28-2013), kanundrum (11-28-2013)
Old 11-28-2013, 10:08 PM   #815
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by bjun View Post
Just curious, the Ptuning dyno testing was done at 6psi, and yours is at 9psi. Is 9psi too much stress on the OEM mechanics or is that moderate?
It's fine as long as you have a very good tune.
The Following User Says Thank You to ptuning For This Useful Post:
Old 11-28-2013, 10:12 PM   #816
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Any dyno plots of Kayhettin's car?
MooKz is offline   Reply With Quote
Old 11-28-2013, 10:26 PM   #817
ptuning
ptuning's Avatar
Drives: White FR-S
The Following 3 Users Say Thank You to ptuning For This Useful Post:
Hicklinc (01-11-2018), MooKz (11-28-2013), No Brakes (12-03-2013)
Old 11-28-2013, 10:41 PM   #818
MooKz
MooKz's Avatar
Wow it's crazy seeing 200tq at a little over 3k RPM's. I'm guessing that's compliments to the pipe work and Toan on the tuning of course? The other guys running the gt28 and gtx28 are seeing that kind of torque at a little under 4k RPM if I'm not mistaken right? I'm new to all this but have gotten accustomed to all their dyno plots and wasn't expecting this. It's great stuff. To the guys making this kind of HP what are you doing about wheels? Are any of you running stock? That's what's holding me back right now. @ptuning has my kit ready for me but I'm thinking of waiting until like next March because of snow and stuff. This is my daily
Old 11-28-2013, 10:50 PM   #819
kayhettin
kayhettin's Avatar
I'm running 255/35/18, 18x9.5 +38 squared.
Old 11-28-2013, 10:51 PM   #820
MooKz
MooKz's Avatar
On what kind of tires?
Old 11-28-2013, 10:55 PM   #821
kayhettin
kayhettin's Avatar
You should be able to daily it as long as you're not hard on the throttle it (under 3k rpms). I'm running Yokohama Advan Ultra High performance summer tires. I'm looking to get some winters on my stock wheels. But also looking to get a beater as well.
Old 11-28-2013, 11:02 PM   #822
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Weight of this car and that HP, that size well... Is almost a need! Lol
Old 11-28-2013, 11:51 PM   #823
kanundrum
Drives: 2013 Whiteout FR-S
Some Parking Lot and Road Driving. I have a 255/40/17 Square setup on 17 x 9 with 0 Interior (You will hear the exhaust and everything louder). Car with out driver and seats is a total of 2652lbs
[ame]http://youtu.be/cW_HdGWq9gw[/ame]
The Following 12 Users Say Thank You to kanundrum For This Useful Post:
Dinko (12-03-2013), diss7 (12-02-2013), GT 86 Brah (12-04-2013), MadFRS (11-29-2013), MDSubarubrz (11-30-2013), mkivsoopra (11-29-2013), Mrc@ptuning (11-29-2013), OjiGeorge (12-01-2013), PStaff716 (11-30-2013), SnapOv3st3r (12-02-2013), sw20kosh (11-29-2013), White_Lightning (11-29-2013)
Old 11-30-2013, 01:22 PM   #824
xwd
How do you think the turbo would perform with a P&L 4-1 EL header? I may be looking at the kit early next year but using a GTX2876R instead. I don't suppose you have anyone using one of those or a GT3071?
Old 11-30-2013, 01:54 PM   #825
jamesm
i love the sound of the 3076r pointed right out the back.
The Following User Says Thank You to jamesm For This Useful Post:
kanundrum (11-30-2013)
Old 12-02-2013, 12:17 PM   #826
kanundrum
Drove about 300 Miles and averaging 28.5 mpg almost staying out of Boost
The Following 4 Users Say Thank You to kanundrum For This Useful Post:
bjun (12-02-2013), diss7 (12-02-2013), kayhettin (12-02-2013), ptuning (12-02-2013)
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 01:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 07:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 01:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 11:13 AM
