Old 04-08-2010, 11:14 AM   #197
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Originally Posted by himbo View Post
The reason that NA Subie motors have crappy hp/lt ration is because the motor traces its roots from the 1960's and it has absolutely terrible heads.
This is an ignorant inference, generalization, and plain old lie in regards to the Subaru engine.
chulooz is offline   Reply With Quote
Old 04-08-2010, 01:39 PM   #198
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
evidence to the contrary?
i am also of the opinion that generally, subarus don't have great head/port designs. i know that boxer engines can make power with good heads and/or turbos, but it seems to me that the subaru n/a engines don't make much power, relative to their size.
-Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 04-08-2010, 11:04 PM   #199
chulooz
Registered you sir
chulooz's Avatar
-Mike
The modern design of the EJ engine is just NOT from the 60's; traces it's roots is a joke of rhetorical diction, like saying toyota engines trace their roots from the 30's (which isnt much of an explanation of fail, as it is a honor to long standing engineering). The heads, whether opined crappy or not (they are not crappy they just have a different goal aside from HP) are NOT the only other reason why the N/A has a 'relatively' crappy HP/L... like someone mentioned, observe the Tq/L, its what Subaru is really about.
So the 60's part is ignorant inference, the terrible heads is the ignorant generalization, and the premise in full is the plain old lie.
Old 04-08-2010, 11:50 PM   #200
NESW20
2.1L 3SGTE
well, when i get on Subaru's website, i see their 2.5L n/a engine that makes 170hp and 170ft.lbs. that's 68hp/L and 68ft.lbs/L.
honda, with their 2.0L Si engine (K20Z3 i think?), has 197hp and 139ft.lbs. 98.5 hp/L and 69.5ft.lbs/L.
please don't for a minute think that i don't like subarus or the 2.5n/a engine. i just think their heads could use some improvement is all.
-Mike
2008 Civic Si Sedan
Old 04-09-2010, 12:04 AM   #201
chulooz
Registered you sir
chulooz's Avatar
haha, fair enough, we'll just have to wait and see if Toyota can do anything about it.
Old 04-09-2010, 12:11 AM   #202
Myka
Myka's Avatar
Drives: Lincoln Town Car
I remember reading that rally cars or awd cars focus more on torque, but that would be where cam specs come into play rather than head flow right? If subaru had cylinder heads and said, "Okay, we want more torque." They would turn to cam specs. Do you have flow numbers from any of the boxers? I'll look, but I'm new at this internet thang, I usually be out hasslin da streets and e-thuggin
Myka is offline   Reply With Quote
Old 04-09-2010, 01:07 AM   #203
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
-Mike
Wait, wait, wait... you're comparing Si to base model Impreza? Am I the only one think that's not the fair comparison. Base Impreza is only Impreza with NA engine. While Civic has ridiculous amount of NA engine and model to choose from. Specially you're using top base Civic Si (in US), while you're using lowest base for Impreza? Because it's NA?
Also you have forgotten about the drive train. If that KA20 engine was put to AWD drive train, do you think it'll dyno same amount of hp & tq? My guess, I don't think so.
Honda has fan for NA engine, but Subaru fan is pure Boxer Turbo engine. Took em over 10 year to finally get extra 5hp/3tq and still running SOHC on current 2.5L engine (EJ253) on NA, while took em 3 yrs to get 20hp/26tq on Turbo with DOHC (EJ257). Subaru don't give a damn about NA Boxer engine (no offense to Subie fan here). They put their whole research into TURBO boxer engine. Cuz they know that, they can't make good NA boxer engine like Porsche and no one is stupid enough to buy $30k plus NA Impreza while you can buy Turbo ver for cheaper.
Old 04-09-2010, 02:21 AM   #204
Matador
hashiryu
Drives: Mk4 Supra
bhp is bhp. Same goes for torque. AFAIK, the Subaru engine figures are not at the wheels. So yeah, corrected for drive train losses, it ought to put down the same hp & tq.
Also, comparing a Turbo engine to an NA engine is pure bollocks. Apples to oranges; Turbo engines almost always have a higher specific output (hence why in motorsport their displacement is calculated @ 1.7x the rating).
Matador is offline   Reply With Quote
Old 04-09-2010, 02:38 AM   #205
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
Like Matador said, when they list those HP / TQ numbers, they don't give you WHP, its BHP. (Basically what the engine can produce at the crank)
Also, what Matador said, Turbo vs NA isn't a fair comparison either, which is why he picked the 2.0L K20 vs the 2.5L EJ25 because it was the closest comparison available.
I don't find any error to the logic there.
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 04-09-2010, 02:40 AM   #206
ichitaka05
Site Moderator
ichitaka05's Avatar
No, it's totally different. 2wd bhp vs awd bhp. I need to look for thread on some dude change his Impreza Wagon into FR with stock NA engine and when he dyno it, hp & tq was higher.
So it's okay to use top model Honda engine vs low model Subaru engine? That's more like Apples to Oranges here. Bring the current low model AWD/4WD NA Honda i4 engine (in US) vs current low model AWD NA Subaru H4 engine (in US) and compare the hp/l & tq/l. That should be Apple to Apple.
Old 04-09-2010, 04:15 AM   #207
NESW20
2.1L 3SGTE
i'm comparing their ENGINES. both are small displacement 4 cylinder engines currently available on the market. i was showing that Subaru n/a 4 cylinders don't necessarily have more "torque/L" than other engines. BHP is "brake horsepower" as measure at the crankshaft (on an engine dyno, with the engine not installed in any car, only on a stand in a shop/lab). you are thinking of WHP or "wheel horsepower" as measured by chassis dynomometers (the rollers that cars drive on). they are not the same. all car manufacturers list BHP in their spec sheets.
2wd and awd whp are different. bhp is bhp is bhp is bhp is bhp. the reason your example of the FR impreza had a higher HP rating after it was converted was because there was less drivetrain loss, so more of the engine's BHP was converted into WHP.
the only reason i chose the n/a 2.5L subaru engine is because they don't offer a high-output version here in the US, except the 3.6L H6. it has HP ratings of 256hp and 247ft.lbs of torque. that's 71hp/L and 68.6ft.lbs/L. that's their "high end" n/a engine here in the US.
but just to make you happy, here's the breakdown for honda's base level Civic engine: 1.8L I4. 140hp and 128ft.lbs of torque. when you do the math, it's 77.8hp/L and 71.1ft.lbs/L. Subaru still falls behind in the specific power and torque output.
i hope all of this makes sense for you. drivetrain has NOTHING to do with BHP, only WHP. you are getting the two confused.
-Mike
2008 Civic Si Sedan
Old 04-09-2010, 10:04 AM   #208
ichitaka05
Site Moderator
ichitaka05's Avatar
-Mike
K, I totally mistaken the bhp & whp on that one, sorry.
Still, I've said that, do the current low model AWD/4WD NA Honda i4 engine (in US) vs current low model AWD NA Subaru H4 engine (in US) and compare the hp/l & tq/l. Comparing FF/FR vs AWD isn't really fair comparison.
I'm using current CR-Z, which is 4wd. They have K24Z1 engine inside & pushin' 166hp/161tq (from wiki) do the math and 69hp/l & 67tq/l. Looks to me, it's almost same hp/ & tq/l range as current Subaru engine me.
Old 04-09-2010, 10:47 AM   #209
Matador
hashiryu
Drives: Mk4 Supra
Like Mike said, chassis dynos measure whp not bhp.
eh?
The CR-Z uses a 1.5L engine and hybrid motors. It makes like 122hp. Total.
Did you mean CR-V?
Old 04-09-2010, 01:24 PM   #210
ichitaka05
Site Moderator
ichitaka05's Avatar
Never mind, don't worry bout it.
eh?
Did you mean CR-V?
out of that quote I've wrote, only reply I get is the name mistake and not commenting on hp/l & tq/l which I thought was the main topic. Yes, thank you. I meant to write CR-V, not CR-Z.
FT-86 Concept to be unveiled at Toyota Metapolis on 10/23 ahead of Tokyo Motor Show! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 8 12-15-2011 11:19 PM
Live pics and videos of Toyota FT-86 from Tokyo Motor Show (compilation)! Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 67 10-31-2011 08:09 PM
