Old 10-16-2013, 01:45 AM   #155
autoCAR
Drives: 5/2013 scion frs
Originally Posted by illmatic View Post
Has anyone weighed the OEM front bumper beam vs the Beatrush beam?
beatrush front is 9.6 lbs
beatrush rear is 6 lbs
autoCAR is offline   Reply With Quote
The Following 6 Users Say Thank You to autoCAR For This Useful Post:
Anthony (10-16-2013), finch1750 (10-24-2013), illmatic (10-16-2013), mokinbird87 (04-10-2015), SuperTom (09-09-2018), supra2nv (11-06-2015)
Old 10-27-2013, 11:21 PM   #156
autoCAR
trd chassis brace kit, complete
(minus bolts, since they replace existing bolts, just are a bit longer to accommodate the braces)
scale weighs in .2lbs incraments.
The Following 3 Users Say Thank You to autoCAR For This Useful Post:
Anthony (10-27-2013), SuperTom (12-27-2019), supra2nv (03-04-2014)
Old 11-03-2013, 04:59 PM   #157
diss7
Drives: AE86, 2x GT86, TE27
I finally bought some uber accurate scales, so I've started weighing things. Here's the first lot of stuff I've taken out. Minimal tools/effort/time taken. 20kgs in 20 minutes
All weights are metric. (kg) Car is NZDM 86 spec (Non GT), which is a lighter version than US spec - which is similar is to NZDM GT86. (Non GT has lighter wheels, seats, brakes, different interior etc etc) So, some of the parts I have may be different to US spec cars. Anyway...
Before I stripped, I weighed car...
1194kg with 1/4 tank of gas. So, Toyota NZ's claim of 1180kg is pretty bang on.
Stripping time...
Boot floor panel
1.231
Boot internal side linings
0.403
0.417
Boot rear centre trim
0.313
Centre foam tyre well insert
0.570
Side foam insert
0.182
0.173
Jack + Handle + 2 tow hooks + wheel brace + screwdriver
3.105
Rear seat back
6.969
Tyre repair kit
1.351
Rear seat cushion
1.893
1.867
3rd brake light - detachable part only, not incl. base
0.196
Rear seat belt receivers (both) incl. bolts
0.308
Brackets found under rear seat cushions, assume for child seat?
0.285
Bonnet/hood lining
0.456
Owners manual/service folder
0.903
Rear floor mats (both)
0.368
Total removed 20.990
Some other stuff I had laying around
Bride Low Max bucket seat - fake - seat only, no brackets
5.830
Bride Low Max bucket seat - genuine - seat only, no brackets
5.527
205/40/17 Achilles 123 Semi slick - new
7.986
205/40/17 Ling Long Crosswind - 90% tread
8.850
diss7 is offline   Reply With Quote
The Following 3 Users Say Thank You to diss7 For This Useful Post:
Anthony (11-03-2013), Blokatos (05-02-2016), SuperTom (04-09-2025)
Old 11-16-2013, 09:21 AM   #158
jm1681
Drives: MKVI VW GTI
Not so much a weight reduction as a balancing act, but has anyone moved their battery to the trunk yet? Even if you're only running a 5lb battery, 5lbs out back is better than 5lbs on the nose.
jm1681 is offline   Reply With Quote
Old 11-16-2013, 09:39 AM   #159
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I got a 3 pound battery. I don't think the extra cable would warrant the move. But yeah, if you're more concerned about balance than overall weight reduction, then moving the factory battery to the back would be a great idea.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 11-18-2013, 03:07 AM   #160
my name is joe
The battery in between the two axles is the better way to balance the car. Most guys mount the battery behind where the passenger seat used to be.
my name is joe is offline   Reply With Quote
Old 11-20-2013, 01:15 AM   #161
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Originally Posted by Anthony View Post
Car: 2,751lbs
(Based on complete BRZ Premium MT with full tank of gas)
Exterior
--Wheels, Tires, Nuts-- [Unsprung weight]
Wheels
41.40lbs - OEM + tires (Source)
20.10lbs - OEM (Source)
For aftermarket weights, just go here.
Lug nuts (x5)
0.590lbs | 267.6g - Muteki SR48 (Source)
0.440lbs | 199.5g - Muteki SR35 (Source)
0.410lbs | 185.9g - Gorilla Chrome Tuner (Source)
0.275lbs | 124.7g - OEM (Source) (Additional Source)
0.250lbs | 113.3g - Rays Engineering (Source)
0.250lbs | 113.3g - VMS Racing (Source)
0.202lbs | 092.0g - CSG aluminum (Source)
0.144lbs | 065.3g - Gorilla forged aluminum (Source)
[/COLOR][/SIZE]Suspension & Bracing
Very Nice! Exactly what I was looking for. Thanks for this.
ProjectD is offline   Reply With Quote
The Following User Says Thank You to ProjectD For This Useful Post:
Anthony (11-20-2013)
Old 11-30-2013, 08:20 PM   #162
Anthony
Weight Nazi
Anthony's Avatar
APR Carbon Fiber Mirrors
The mirrors themselves are STUPIDLY light. The bases are disappointingly heavy though.
I've only got one installed so far, and I can definitely say these mirrors are not photogenic. In other words, they look great in person. Much better than what I'd expected. I thought they were going to look too small, but not at all.
0.2750lbs - APR mirror itself
1.0875lbs - APR mirror + supplied hardware
2.1250lbs - OEM mirror + hardware
1.0375lbs of weight saved per side
Note that I didn't weigh the rubber gasket thing because I left it on the car. You will definitely want to do the same, unless you're 100% certain you'll never drive in the rain. Otherwise you'd definitely get water inside of your door where it would collect.
The Following User Says Thank You to Anthony For This Useful Post:
PoorMansRacing (12-05-2013)
Old 12-03-2013, 12:48 PM   #163
TheLaughingMan
TheLaughingMan's Avatar
For the guys that did the 3 lb battery, did you just put together a custom tray and tie downs or what? Is there a kit? I've been looking but only found an 11 lb kit
TheLaughingMan is offline   Reply With Quote
Old 12-03-2013, 01:04 PM   #164
Anthony
Weight Nazi
Anthony's Avatar
Mine will be custom.
Old 12-03-2013, 01:25 PM   #165
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Front Springs - 1306g = 2.88 lbs
Rear Springs - 1162g = 2.56 lbs
Dustin is offline   Reply With Quote
The Following 2 Users Say Thank You to Dustin For This Useful Post:
MaximeT (03-26-2016), PoorMansRacing (12-05-2013)
Old 12-03-2013, 11:40 PM   #166
TheLaughingMan
Are you going to do a DIY guide when you're done?
I would really appreciate it and I'm sure other members would too
Old 12-03-2013, 11:45 PM   #167
Anthony
Weight Nazi
Anthony's Avatar
Depends. If all works out as planned, it's going to be the most pain-in-the-ass thing ever, and I will just sell the solution I'm conjuring. But if it turns out to be really easy, then yeah. Totally DIY-threading that shit.
That still a ways away though. Still need to fix my driveshaft and final drive situation...
Old 12-03-2013, 11:49 PM   #168
Anthony
Weight Nazi
Anthony's Avatar
HAHAHAHAHA! I'm so drunk right now. I thought this was the diffuser thread.
Yes, I'll make a DIY for the battery tray solution, but... spoiler alert... I'm just going to drill some holes in my firewall and zip tie that bitch to the firewall. The end.
LOL but my diffuser is going to be absurdly complex. Excuse my drunkeness. I don't know where I live right now.
ProjectD (01-19-2014)
diet, heavy, light, reduction, weight
So what is the official weight? brillo Scion FR-S / Toyota 86 GT86 General Forum 76 05-03-2020 06:11 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 06:09 PM
2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 124 05-28-2012 01:20 PM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 03:04 AM
