Old 06-26-2013, 08:05 PM   #43
bestwheelbase
Drives: 1985 P-Type
I am going to try this on my non-FT86. Anybody got leftover foam? I don't feel like ordering an entire roll when all I need is a little bit. Hook me up with foam and I will hook you up with a t-shirt discount.
Old 06-26-2013, 11:18 PM   #44
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
I have most of a roll left. Let me know how much you need.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 06-27-2013, 02:54 PM   #45
bestwheelbase
Drives: 1985 P-Type
Thank you kind sir! I will take an exact measurement and contact you via PM.
Old 08-17-2013, 02:12 AM   #46
dawnst3ar
Drives: 2013 MT FR-S Asphalt
Just ordered a set. How long does shipping take?
dawnst3ar is offline   Reply With Quote
Old 08-17-2013, 09:38 PM   #47
wdninja
wdninja's Avatar
2-3 days once I send them out. I'm currently on vacation out of state, so they'll go out first thing Tuesday morning. Sorry for the delay, I'll throw in a tube of 3M Automotive Weatherstripping Adhesive for your troubles.
Old 08-19-2013, 06:24 PM   #48
dawnst3ar
Excellent, Thanks!
Old 08-27-2013, 07:00 PM   #49
ZionsWrath
Thanks
ZionsWrath's Avatar
WELL.
It didn't work.
My driver side tail has lots of water, the right gets it sometimes.
I did the thicker gaskets, even did the adhesive all around the DIY said.
I'll check the sealing again, but it was perfect when i put it in...
LIAR!
Old 08-27-2013, 07:06 PM   #50
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
LIAR!
Ha, forgot about this topic.
Even after a second sealing, i had condensation again.
I went to the dealership and they replaced the taillights again, instead of just replacing the taillights they used a new type of gasket too. No problems so far...
This was about two months ago, yet again if they occur i'll give an update...
Old 08-28-2013, 10:07 AM   #51
wdninja
wdninja's Avatar
Thanks for the feedback! Through my experience so far I venture to say there was something else wrong with your previous set of tails, whether it be a hairline fracture in the housing, or the housing post-holes in the body panel might be bent (common issue).
I hope Scion/Subaru have pulled their heads out of their asses and are now providing a good enough gasket, but I have my doubts.
If you do find that your new tails get condensation again, let me know and I'll send you another set of gaskets.
Old 11-30-2013, 05:10 PM   #52
styl3z
styl3z's Avatar
Drives: 2013 Scion FRS Whiteout
Hi,
Where would one find neoprene foam and 3M Auto Black Superstrength Weatherstrip Adhesive?
Thanks
styl3z is offline   Reply With Quote
Old 11-30-2013, 05:18 PM   #53
MrBodyMassage
Drives: 1994 Toyota MR2 Turbo, WRB BRZ Lim
wdninja's gaskets completely fixed my problem. Thanks again dude.
MrBodyMassage is offline   Reply With Quote
Old 11-30-2013, 07:23 PM   #54
wdninja
wdninja's Avatar
No problem!
Old 11-30-2013, 07:36 PM   #55
wdninja
wdninja's Avatar
Originally Posted by styl3z View Post
Hi,
Thanks
You can get both straight from me if you'd like. I took the initiative to get the better gaskets manufactured.
If you want to DIY, you can get the adhesive at most auto parts stores (I get mine at Advance Auto Parts) and you can order a roll of the foam, but you have to cut it yourself.
PM me for details either way.
Old 12-01-2013, 03:34 AM   #56
styl3z
styl3z's Avatar
I was thinking of buying from you, but I wanted to see if its cheaper if I do it myself. Since I live in Canada, it'll be $40.
condensation, diy, gaskets, tail lights
Tail Light Condensation rbrtndrws Issues | Warranty | Recalls / TSB 1033 04-16-2019 10:57 AM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
tail light Sketch575 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-11-2012 02:32 AM
Tail light replacement? alexm Cosmetic Modification (Interior/Exterior/Lighting) 5 06-05-2012 04:38 PM
