Old 11-28-2013, 12:37 AM   #1
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Pics of back seat panels removed
So I'm thinking of adding an amp and some small-ish subwoofers in the back.. there's a good amount of space for some shallow 8's maybe. Here's some photos from taking out the passenger side back panel.
To take the bottom seat out, just unbolt the front and push down on the back of the seat while pulling the seat forward.. there's a small clip in the back. To take off the panel, there's a few clips to take off in the trunk nearest the back seat, then partially pop out the side plastic on the bottom rear door frame.
Next, pop out the clip towards the back of the now removed seat. Now pull the panel towards the drivers side from the bottom left. The panel is held on by about 7 clips.. pull until it gives some resistance, then pull quick to pop the bottom left one out. As you pull the others out, use force from close to the clip so you don't bend the panel too much (it will have some pliability though).
When they're all out, you can move the seat belt out of the way and gently nudge the panel forward towards the front of the car and pull it through the passenger or driver door.
It worked for me
Mike
mike_ekim1024 is offline   Reply With Quote
The Following 3 Users Say Thank You to mike_ekim1024 For This Useful Post:
hmong337 (11-28-2013), Wolfdogelite (04-04-2015), ZionsWrath (11-30-2013)
Old 11-28-2013, 01:45 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
How much do the rear seats weigh?
Old 11-28-2013, 02:18 AM   #3
mike_ekim1024
Not more than a few pounds.. they're just foam wrapped with fabric. The panel weighs more.
The Following User Says Thank You to mike_ekim1024 For This Useful Post:
Old 11-30-2013, 08:11 AM   #4
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
this is exactly what i wanted and have been waiting for someone to look into it except i want it behind the driver seat. is it necessary to take out the side panel? do you have any plans for a sub box that'll still let the back seats fold down? and so that the folded back won't affect sound quality. i have to build a sub box for a upcoming school project so i'd thought why not accomplish 2 things at once
andrew5826 is offline   Reply With Quote
Removing the Back Seat Matizzay Cosmetic Modification (Interior/Exterior/Lighting) 11 07-05-2014 06:43 PM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 07:59 AM
Back seat space bill323 Scion FR-S / Toyota 86 GT86 General Forum 23 08-07-2012 04:11 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 09:17 AM
Fold down back seat? slizoth Scion FR-S / Toyota 86 GT86 General Forum 3 10-18-2011 06:40 PM
