Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
#15 |
Drives: 2013 FRS
I got it alittle yesterday and then this morning it was reallly loud pop sound idk wtf it is but i know its normal. My cars gonna be at toyota overnight tonight so they can duplicate the sound, we'll see wht happens
#17 |
Drives: white Sport-tech
-22 thismorning and this was worse than ever... Hope it's normal cause it does it a lot.
#18 | |
Drives: FR-S 6MT
It was 23 degrees here this morning.. So it's probably 55 in the garage And it will pop and stumble some when I go to start it.. My car is spoiled down here in the Carolina's... Stay warm! |
#19 |
Drives: 2013 SWP BRZ
Mine is not as nearly pronounced as the video above, but only during the first 20 seconds or so on start up there's a very very faint pop sound, then once the revs drop down it goes away, and doesn't happen at any other point in time. Sounds like it's just running very rich on startup.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#20 |
mine went on for a good minute thismorning, very loud and the first time ive seen it actually change the rpms.
weather is just starting to stay cold here now, im goign to get a video in the morning and bring it in to subaru. it does look like this is common... hopefully this car doesnt explode in the cold. to broke for a beater. |
#21 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#22 |
The Answer
Drives: Mazda 2
I heard that noise all last winter during cold starts, warm weather came back and made it through the entire summer and never heard it again.
It has yet to be cold enough here for me to hear it again so far this season...so it sounds like normal crazy cold start sound this car makes in the cold. The exhaust is crazy loud during the startup, the cam phasing / spark timing must be acting up to warm up that cat fast and makes wierd ass noise in the process.
#23 | |
Drives: 2013 frs
Imo this is normal on cold starts |
#24 | |
Drives: 2013 BRZ Limited AT
If I start the car and immediately change gear out of park (auto trans), the revs immediately drop to ~1k and there is no weird popping. I assume it's the crappy cat warm-up procedure with negative timing. Maybe the engineers in Japan didn't spend much time testing in freezing cold environments? |
#25 | |
Drives: 2013 frs
As soon as a drive the car for 15 mins, the noise would disappear |
#26 | |
Have you noticed if the pop/stutter goes away once you get rolling? I can bump to neutral in my auto and it goes away completely as the revs drop immediately as it passes through reverse. If you give a light blip of throttle does that make a difference? It'd be nice to know what exactly is causing the pop. Seems almost like a misfire/cutout or split second power loss like cylinders not firing intermittently. The fact that it goes away as soon as the revs drop and the car warms up makes me think it's a startup fueling issue that Subaru or Toyota should sort out. |
The Following User Says Thank You to kuhlka For This Useful Post: | Young_makaveli (11-26-2013) |
#27 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
Mine does this when left outside and 25 F or lower. It's a backfire in the intake system. Cold fuel in the intake not atomizing and probably pooling. Cold start enrichment (the choke for old carburated guys). This fuel is then ignited in the intake system and you hear the muffled pop.
#28 |
Drives: 2013 Whiteout Scion FR-S
I'm getting the same popping noise on cold starts as well...was kinda alarming at first, but after the car settles down all is well.
yesterday was -7 degrees celsius (approx 19 F) car starts at 2k idle...then 1.5...then 1. About 4 minutes later, the car is ready ![]() |
The Following User Says Thank You to Snowball For This Useful Post: | Migero86 (12-10-2013) |
Popping noise from engine bay during start up, free rev, light roll on throttle | heeltoe86 | Tracking / Autocross / HPDE / Drifting | 44 | 12-01-2014 09:28 PM |
foot rest popping noise | abutterman | Issues | Warranty | Recalls / TSB | 34 | 02-20-2014 11:56 PM |
DI Popping noise, just installed new updated tune file. | Bg8780 | Issues | Warranty | Recalls / TSB | 21 | 06-27-2013 11:56 PM |
BRZ gas pedal popping/squeaking noise | chenshuo | Issues | Warranty | Recalls / TSB | 8 | 05-10-2013 09:52 AM |
Cold Start Exhaust Volume | SilentMike | Engine, Exhaust, Transmission | 15 | 04-04-2013 10:49 AM |
