Old 10-21-2013, 12:28 PM   #15
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
I got it alittle yesterday and then this morning it was reallly loud pop sound idk wtf it is but i know its normal. My cars gonna be at toyota overnight tonight so they can duplicate the sound, we'll see wht happens
sweetfrs is offline   Reply With Quote
Old 11-24-2013, 08:16 PM   #16
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
Keep us posted
Maverick22 is offline   Reply With Quote
Old 11-24-2013, 09:15 PM   #17
Muskokan
Drives: white Sport-tech
-22 thismorning and this was worse than ever... Hope it's normal cause it does it a lot.
Muskokan is offline   Reply With Quote
Old 11-25-2013, 09:29 AM   #18
Mikem53
Drives: FR-S 6MT
At least it started for you... That's crazy cold..
It was 23 degrees here this morning.. So it's probably 55 in the garage
And it will pop and stumble some when I go to start it.. My car is spoiled down here in the Carolina's... Stay warm!
Mikem53 is offline   Reply With Quote
Old 11-25-2013, 09:51 AM   #19
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Mine is not as nearly pronounced as the video above, but only during the first 20 seconds or so on start up there's a very very faint pop sound, then once the revs drop down it goes away, and doesn't happen at any other point in time. Sounds like it's just running very rich on startup.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 11-25-2013, 12:40 PM   #20
Muskokan
mine went on for a good minute thismorning, very loud and the first time ive seen it actually change the rpms.
weather is just starting to stay cold here now, im goign to get a video in the morning and bring it in to subaru. it does look like this is common... hopefully this car doesnt explode in the cold. to broke for a beater.
Old 11-25-2013, 08:10 PM   #21
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by whtchocla7e View Post
I, too, have experienced the popping sounds at startup during the cold winter months.
I posted a thread about this exact issue earlier and your video is what I experienced this morning. I hope this isn't a common occurance with this factory cold start tune.
Luckrider is offline   Reply With Quote
Old 11-25-2013, 08:30 PM   #22
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I heard that noise all last winter during cold starts, warm weather came back and made it through the entire summer and never heard it again.
It has yet to be cold enough here for me to hear it again so far this season...so it sounds like normal crazy cold start sound this car makes in the cold. The exhaust is crazy loud during the startup, the cam phasing / spark timing must be acting up to warm up that cat fast and makes wierd ass noise in the process.
Rayme is offline   Reply With Quote
Old 11-25-2013, 10:26 PM   #23
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Originally Posted by Weeber View Post
Hey guys,
So a fair bit of owners on an Australian forum seem to be disheartened due to a "champagne cork" like popping in the engine bay during first start up and only during cold starts.
One claims the engine rev's drop before popping also noise seems to be apparent on both transmission types.
This to me, sounds like the initial stages of the infamous DI seal problem folks seem to be having. I don't know if I am being paranoid but better safe than sorry.
So my question is, would this be something they (and I, who do not have such issues) should be worrying about?
Thanks!
I can confirm that the revs drop under 1k before any popping occurs
Imo this is normal on cold starts
Young_makaveli is offline   Reply With Quote
Old 11-25-2013, 10:40 PM   #24
kuhlka
Drives: 2013 BRZ Limited AT
My popping/missing/stutter sound as in the video only occurs during the first 15-30 seconds of startup. Once the revs drop to 1k and lower it goes away completely. It only started doing it once the temps dropped below 40F.
If I start the car and immediately change gear out of park (auto trans), the revs immediately drop to ~1k and there is no weird popping. I assume it's the crappy cat warm-up procedure with negative timing. Maybe the engineers in Japan didn't spend much time testing in freezing cold environments?
kuhlka is offline   Reply With Quote
Old 11-25-2013, 10:42 PM   #25
Young_makaveli
Drives: 2013 frs
I don't know if this matters or not but my car is manual so maybe that goes into account ?
As soon as a drive the car for 15 mins, the noise would disappear
Old 11-25-2013, 11:07 PM   #26
kuhlka
After 15min of driving, the car should be fully warmed up.
Have you noticed if the pop/stutter goes away once you get rolling? I can bump to neutral in my auto and it goes away completely as the revs drop immediately as it passes through reverse. If you give a light blip of throttle does that make a difference?
It'd be nice to know what exactly is causing the pop. Seems almost like a misfire/cutout or split second power loss like cylinders not firing intermittently. The fact that it goes away as soon as the revs drop and the car warms up makes me think it's a startup fueling issue that Subaru or Toyota should sort out.
The Following User Says Thank You to kuhlka For This Useful Post:
Young_makaveli (11-26-2013)
Old 11-26-2013, 08:54 AM   #27
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Mine does this when left outside and 25 F or lower. It's a backfire in the intake system. Cold fuel in the intake not atomizing and probably pooling. Cold start enrichment (the choke for old carburated guys). This fuel is then ignited in the intake system and you hear the muffled pop.
FRSFirestorm is offline   Reply With Quote
Old 11-26-2013, 01:04 PM   #28
Snowball
Snowball's Avatar
Drives: 2013 Whiteout Scion FR-S
I'm getting the same popping noise on cold starts as well...was kinda alarming at first, but after the car settles down all is well.
yesterday was -7 degrees celsius (approx 19 F) car starts at 2k idle...then 1.5...then 1. About 4 minutes later, the car is ready
Snowball is offline   Reply With Quote
The Following User Says Thank You to Snowball For This Useful Post:
Migero86 (12-10-2013)
Popping noise from engine bay during start up, free rev, light roll on throttle heeltoe86 Tracking / Autocross / HPDE / Drifting 44 12-01-2014 09:28 PM
foot rest popping noise abutterman Issues | Warranty | Recalls / TSB 34 02-20-2014 11:56 PM
DI Popping noise, just installed new updated tune file. Bg8780 Issues | Warranty | Recalls / TSB 21 06-27-2013 11:56 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
Cold Start Exhaust Volume SilentMike Engine, Exhaust, Transmission 15 04-04-2013 10:49 AM
