#113 |
Trust me, I'm the Doctor
Probably should add a water reservoir in the trunk and mount the constant flow pump (or an upgrade to that pump) there. That'll add water mass to flow through the system that is not anywhere near being heated by the engine and is after the heat exchanger. That should help in the high heat environments like us desert dwellers.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#114 |
Drives: Whiteout
Hi guys, so I found 1 leak today...anyone else ran into this problem?
[ame="http://youtu.be/0Kz00-0dP_M"]http://youtu.be/0Kz00-0dP_M[/ame] |
#115 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Is that coming from your throttle body?
#116 |
Drives: Whiteout
It is coming out of that clear tube, I am not sure what is it called, but I heard waste gate.
#117 |
Drives: 2013 Black FR-S
that just sends a vacuum signal to the bypass valve. a tiny leak isn't a huge problem there. i would still try to stop it
| The Following User Says Thank You to sw20kosh For This Useful Post: | y2janz2 (11-24-2013) |
#118 |
Drives: Whiteout
Thanks. Hopefully stopping it will clear my P0171 CEL.
Do you happen to know if I have to take off the manifold to fix it/try to stop it or how to stop it? The shop that I took it to didn't want to touch it, they just told me to call Innovate or take it back to where I got it installed. Nevermind it is connected to the throttle body. Last edited by y2janz2; 11-24-2013 at 04:24 PM. |
#119 |
Drives: 2017 Camaro 1SS
#120 |
Road Warrior
I removed the TB and sealed the grey plastic L connectors and put back together, took car down to the dyno.
Previous run with suspected leak 211whp180ftlb Leak fixed 233whp185ftlb The above made on 91 Oct 75mm pulley |
| The Following 4 Users Say Thank You to Ryan86 For This Useful Post: |
#121 |
Any other mods? What is your baseline stock dyno?
#122 |
Road Warrior
My base line was 155whp 141ftlb
I added AFE DIF, Borla Header, decatted 3" performance exhaust. I still have the stock overpipe, I seriously think it needs to go??? At 233whp the car is truly insane. |
| The Following User Says Thank You to Ryan86 For This Useful Post: | SirBrass (11-25-2013) |
#123 |
Drives: Raven FR-S
The stock OP is a pretty big restriction. Even though I have no numbers to prove it, when I replaced mine I noticed a world of difference. The butt dyno doesn't lie!
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#124 |
Road Warrior
OP is on my list, just trying to figure out which is the best to get.
I have the worst Butt dyno, truly not in sync with my car. When I think Booom I get terrible numbers and then I think the car is not pulling I feel no difference, whaaam 20whp gain. Having a dyno down the road, I have put every item installed in the dyno and understood what it has done, so when OP is fitted I'll share. |
| The Following User Says Thank You to Ryan86 For This Useful Post: | CK_Bladesmith (11-25-2013) |
#125 |
That's awesome. Question.. when it comes time for inspections, what do you do about having no cat?
#126 |
Road Warrior
Our laws don't require a vehicle inspection until 5 years old if I'm not mistaken.
I have due to sound of the Borla and decatted being just too crazy, fitted a HPC to the front pipe to reduce sound, but over here its Africa rules...
| Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! | Innovate Motorsports | Forced Induction | 577 | 10-15-2014 12:49 AM |
| Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! | Xero-Limit | Forced Induction | 12 | 03-10-2014 08:56 PM |
| Innovate Motorsports FR-S/BRZ traction control state modifier module... | mines13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-13-2013 01:06 PM |
| Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ | Innovate Motorsports | Forced Induction | 1987 | 03-13-2013 09:14 PM |
| FS: Innovate Motorsports OT-2 | pixel67 | Engine, Exhaust, Bolt-Ons | 0 | 01-05-2013 10:13 AM |
