Old 11-17-2013, 06:29 PM   #29
SilverTipp
SilverTipp's Avatar
Drives: Silver
I installed mine with a diode and 100 ohm resistor. 100 ohm is possibly a little bright ... I may add the other 100 ohm resister in series that came with the pack.
But ... glad I have them now working with the HID headlights either way! Thanks for the write-up. This was the only thing that bugged me on the 10-series. In fact, the salesman and I spent 15-20 minutes trying to figure out how to turn them on with the headlights before we realized we couldn't on day of my first test drive. lol
SilverTipp is offline   Reply With Quote
Old 11-17-2013, 06:37 PM   #30
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
@SilverTipp , do you mind to post picture of diode installed? I have no electrical knowledge and want to make sure I install it correctly. thanks
#944_10_Series_FRS is offline   Reply With Quote
Old 11-23-2013, 10:20 PM   #31
Luis_GT
The Following 2 Users Say Thank You to Luis_GT For This Useful Post:
#944_10_Series_FRS (11-23-2013), IntotheOcean (02-15-2014)
Old 11-25-2013, 12:49 PM   #32
mid_life_crisis
Drives: FR-S 10 #103 AT
Don't get too excited about that picture. It doesn't tell you the most important detail. That being, which end goes to pin5 and which goes to pin1. Diodes are designed to only flow current in one direction, which is why they are great for making sure you don't burn out circuits by flowing electricity the wrong way.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 11-25-2013, 01:07 PM   #33
mid_life_crisis
I have a question or two about this. If one resistor will do the job for both lights, then either they are in series or they are in parallel and the paths diverge in the connector, which is why the resistor before the connector would affect both.
How are they wired from the factory? Does anyone have the full pinout for this connector?
Old 11-25-2013, 01:21 PM   #34
Luis_GT
Goes from #5 (red) to #1
Old 11-25-2013, 02:41 PM   #35
mid_life_crisis
That still doesn't answer the question. Which end of the diode goes where? You know and I can certainly figure it out, but many of our fellow forum members have no clue which way to point the diode. Many of them have no idea why there's a stripe on the thing.
Edit: Damnit, you answered too quick. I edited too late.
Old 11-25-2013, 02:54 PM   #36
Luis_GT
The bag where the diode comes in says which direction the diode works... if it doesn't, only way to know is by using a voltmeter.
or you can just flip the cables between #1 and #5 if it's backwards, it's not that hard...
in the case of my diode, power flows from ring-less to ring.
Old 11-25-2013, 03:21 PM   #37
mid_life_crisis
For those of you wondering what the heck I'm going on about, here's diodes 101.
This is an incredibly simplified explanation of how a diode works. It really is an idiot's guide for people who don't need or want the scientific explanation but want it to be more than flippin magic.
With few exceptions diodes work the same way.
Picture the tube as having three areas: Positive end, negative end and what amounts to a neutral middle area. The ends are treated with material (technical term "doped") to make them have the charges they do.
Remember that opposites attract and likes repel.
Now imagine connecting the plus end to a voltage source and the negative (typically the one with the stripe) to a lower voltage. You hook the positive source to the positive end and the doped material is repelled towards that neutral center area. Same thing happens at the other end. They meet in the middle of that neutral zone. Now you have a complete path from one end to the other.
Now imagine something weird happens and for some reason the end that had the higher voltage suddenly drops so that it is lower than the other end. Opposites attract, remember. So now the doped material is pulled towards the ends, making that neutral zone bigger and turning it into the equivalent of a moat preventing movement through the diode, so the electricity can't go the wrong way.
Old 12-04-2013, 04:20 PM   #38
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
So... any chance a similar method like this could work on the BRZ's DRL strip?
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 01-18-2014, 06:22 PM   #39
#944_10_Series_FRS
Just completed this mod today. Thanks to @Siege and @Luis_GT for your help on the instruction.
The Following User Says Thank You to #944_10_Series_FRS For This Useful Post:
Luis_GT (01-18-2014)
Old 01-28-2014, 02:55 PM   #40
unikhmer
Drives: 2013 FR-S 10 Series
Can anyone post a picture of how you mounted the resistor?
unikhmer is offline   Reply With Quote
Old 02-16-2014, 05:11 PM   #41
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
im a straight nub with this kind of stuff.
can someone post a more detailed nub friendly guide?
subiestyle is offline   Reply With Quote
Old 02-17-2014, 12:37 AM   #42
Retro86
Retro86's Avatar
Drives: Awesome
im gonna need detailed instructions on these
Retro86 is offline   Reply With Quote
Installed 10 Series Headlights Today Calavera Cosmetic Modification (Interior/Exterior/Lighting) 58 02-15-2024 03:18 PM
Scion 10 series headlights gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 19 04-20-2014 11:26 PM
86 Headlights (10 Series) $656 Each at www.onlinetoyotaparts.com YMMV Calavera Cosmetic Modification (Interior/Exterior/Lighting) 42 08-21-2013 06:54 AM
GT86 European headlights ? rikdrt1 Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2012 04:32 AM
European delivery date ? Sylvain44 BRZ First-Gen (2012+) — General Topics 6 06-04-2012 07:27 AM
