Old 11-23-2013, 07:24 PM   #4481
Kicker6820
Drives: '13 Subaru BRZ WRB 6MT, 06 Scion xB
Washed mine and then spent the rest of the day buffing out some door scuffs.
Some people have no respect for other people's property
Kicker6820 is offline   Reply With Quote
Old 11-23-2013, 08:05 PM   #4482
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Originally Posted by tobin View Post
Got a front plate warning...guess the bumper's finally getting drilled
Don't drill it! Get a GrimmSpeed plate relocation kit.
http://www.grimmspeed.com/license-pl...on-kit-subaru/
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
The Following User Says Thank You to BRZNutt For This Useful Post:
cerealcable (11-23-2013)
Old 11-23-2013, 09:12 PM   #4483
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
Got TIS and cheap OBD-II cable to work on a low-end Win-7 laptop & changed some convenience settings:
Disabled DRLs
Switched to one-key-button-press-unlocks-both-doors
Switched to two-key-button-presses-opens-trunk (though I might change this again to one really long press opens trunk)
Thinking about shortening the interior light on time when a door is opened next
Fun stuff...
993Fan is offline   Reply With Quote
Old 11-23-2013, 09:14 PM   #4484
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Drove mine through Toronto's first big snowfall.
daiheadjai is offline   Reply With Quote
Old 11-23-2013, 09:23 PM   #4485
Burrcold
Drives: Subaru BRZ Limited
Toronto had a big snowfall?
Old 11-23-2013, 09:28 PM   #4486
daiheadjai
daiheadjai's Avatar
We're the guys who called in the army, so YMMV.
Anything that causes white-out conditions is pretty big for us.
BTW - I'm north of HWY7, and for some reason, snow generally doesn't like to go south of Markham. North of 16, people had their flashers on because visibility was pretty poor.
Old 11-23-2013, 09:49 PM   #4487
Burrcold
Ah gotcha. I was downtown and there were a few squalls, and that's about it.
Old 11-23-2013, 11:11 PM   #4488
larryboy
Drives: hot wheels
my forza 5 brz since i cant afford a real one :/
larryboy is offline   Reply With Quote
The Following 4 Users Say Thank You to larryboy For This Useful Post:
bjun (11-24-2013), chanomatik (11-25-2013), Steve201brz (11-24-2013), Stierzy34 (11-23-2013)
Old 11-24-2013, 12:33 AM   #4489
Howardwei
Originally Posted by shiumai View Post
they'll fit no problem, but they'll poke out a bit in the front and rear without camber.
Would doing 8.5 front and 9.5 rear lose the balance of this car. I want to close the gap without messing with the stock suspension set up at all. approx. 1 inch. since i will probably be running 255 back and 235 front. does poking out make it rub? I am getting one with offset 40
Howardwei is offline   Reply With Quote
Old 11-24-2013, 01:17 AM   #4490
DSOmegaX
DSOmegaX's Avatar
Brought her to finally meet her twin! @switchlanez
@dsomegax.cars
The Following 4 Users Say Thank You to DSOmegaX For This Useful Post:
chanomatik (11-25-2013), ichitaka05 (11-25-2013), sprintertrueno86 (11-24-2013), switchlanez (11-24-2013)
Old 11-24-2013, 01:46 AM   #4491
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Installed TapTurn module, awesome little unit
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 11-24-2013, 04:01 AM   #4492
alan.chalkley
Drives: 4wd zooks
installed cusco carbon antenna.
alan.chalkley is offline   Reply With Quote
Old 11-24-2013, 04:34 AM   #4493
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
depends on who you talk to and what you're looking for. i wanted more grip and got it. if you want the tail-happy slide-around feel that the stock tires have, you'd lose it. some don't like staggered setups for various reasons, some do for their own reasons.
the gap isn't going to close unless you get larger diameter tires, then your speedo will be off. i stuck to as close to the stock diameter as possible, and closed the gap by lowering the car.
i don't know whether that setup would rub as i never ran it with the stock height - i lowered my car before i got my wheels.
shiumai is offline   Reply With Quote
Old 11-24-2013, 05:18 AM   #4494
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by DSOmegaX View Post
Added STi bear and valve stem caps =P
Attachment 40676
Please tell, where to get sti bear!!!!!
