Old 11-23-2013, 02:48 PM   #71
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Draco_PR23 View Post
@gdrider77 Which Perrin CAI are you using in your car? I'm thinking about buying one but since I have the Robispec radiator combo, I think the 3" wont fit or it will be tight.
-Wil
Im using the standard one..
http://www.rallysportdirect.com/Perr...rce=GoogleBase
Not sure how it will fit with the larger radiator though.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Draco_PR23 (11-23-2013)
Old 11-23-2013, 04:03 PM   #72
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I took some measurements and the space is larger than 2.5" but smaller than 3"
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 11-24-2013, 11:54 AM   #73
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You will have to notch it like mine is. Not a big deal, its thing metal.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (11-24-2013)
Old 12-10-2013, 02:30 PM   #74
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
What wheels do you have?
cjsporl1996 is offline   Reply With Quote
Old 12-10-2013, 06:00 PM   #75
gdrider77
gdrider77's Avatar
Miro 111
http://www.ft86club.com/forums/showt...light=miro+111
Old 12-11-2013, 02:35 PM   #76
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
So I have to bug you here, but from what I understand, you are using the grimspeed MBC? Easy to install/work with?
Old 02-07-2014, 12:28 PM   #77
gdrider77
gdrider77's Avatar
Very easy....i also have the ebcs installed, but not tuned for it yet, working on some things for that......
SkAsphalt (02-07-2014)
Old 02-07-2014, 12:34 PM   #78
gdrider77
gdrider77's Avatar
Latest update on my car.......failed welds on manifold.....
So noticed a significant amount of noise from below the car taht sounded like an exhaust leak. Lifted the car, and did an oil change and decided to pinpoint the exhaust leak as well. Like many others experienced, leaking at the mainfold-head flanges....well, i had the upgraded forester gaskets but those did not seem to hold, as there were clear visual build up/leaks, and also a very audible leak. Upon further inspection i saw that the header itself had broke a weld. So unfortunately, had to pull this all apart to get that part off.
Paul has been real good about getting this taken care of and is sending me a new header.
Just sucks i had to remove most of the turbo, lines etc....not to mention the costs of getting new gaskets. Went with the @GrimmSpeed brz/frs kit, so will be putting all new gaskets in throughout. Hope the new header isnice and smooth/even, toherwise will be taking to get it resurfaced first, before installing.
Old 02-07-2014, 03:31 PM   #79
xwd
Well as long as they take care of you, I know it's a PITA to have to deal with a critical piece of the equation going bad, a lot of wasted time and effort.
I'm not a big fan of wrapping Subaru headers, issue being they sit underneath the engine. They are a good spot for oil to drip/spill on and once the header wrap is soaked it just goes up in flames. I have good first hand knowledge of this.
The Following 2 Users Say Thank You to xwd For This Useful Post:
DoctorNick (02-07-2014), SkAsphalt (02-07-2014)
Old 02-11-2014, 08:12 PM   #80
gdrider77
gdrider77's Avatar
Just got my replacement header....
How flat would you consider the header flanges to be, to stay within spec....?
And to be clear, on the leaking one i had the forrester gaskets which seem to be about 1.25mm
I have now got the new @GrimmSpeed gaskets, and they are about 1.6mm thick, so hope that helps. I also grabbed some permatex ultra copper for extra insurance.
Sportsguy83 (02-11-2014)
Old 02-11-2014, 08:41 PM   #81
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I would get it re-faced by a local machine shop. Won't take long and it will be worth the peace of mind imo.
Didn't take very long to get the new header! And was it warrantied? I thought AVO's warranty was only 3 months...
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 02-11-2014, 08:50 PM   #82
gdrider77
gdrider77's Avatar
Yeah, i think their warranty is only 3 months, but i had a failed weld on my manifold, so think Paul was just trying to do the customer service thing and take care of me, really appreciate it paul @AVOturboworld.
The Following 6 Users Say Thank You to gdrider77 For This Useful Post:
AVOturboworld (02-12-2014), Draco_PR23 (02-12-2014), mwjcyber (09-06-2014), OjiGeorge (02-12-2014), Pitman (02-12-2014), SkAsphalt (02-11-2014)
Old 02-11-2014, 10:06 PM   #83
Sportsguy83
Drives: Limited BRZ
^^^ This +10000000
Old 02-12-2014, 03:28 AM   #84
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Glad to hear AVO took care of you. The header issues that people have been having makes me hesitant. Even if it's a PITA, it's great to hear that the vendor is helping you out!
OjiGeorge is offline   Reply With Quote
avo, bov, brz, turbo, uel
2013 Hot Lava FRS "Drift build" THA STI GUY Member's Car Journals 58 04-25-2015 04:55 PM
The RaceComp Engineering BRZ "Clubsport" Build Racecomp Engineering Member's Car Journals 100 12-18-2014 02:18 PM
KO's Raven FR-S Build: Name "Raven12s" KO Member's Car Journals 3 07-18-2013 02:09 AM
Whiteout "8ROKU" build from Dallas (Frisco) jacobzking Member's Car Journals 23 06-27-2013 01:56 AM
Norsamerican's WRB BRZ aka "Backdraft" Build norsamerican Member's Car Journals 2 06-20-2013 07:16 PM
