Old 11-22-2013, 02:06 PM   #1
Shizuma
Shizuma's Avatar
Drives: 2015 Dodge Challenger SXT
tpms broken
So I took my brz to get my snow tires mounted today and they told me one of the tpms sensors was broken and was just bouncing around loose in the tire, while I know tires and rims aren't covered under warrant are the tpms sensors?
Shizuma is offline   Reply With Quote
Old 11-22-2013, 02:11 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would guess that the shop that mounted your snow tires broke the TPMS in the process of unmounting your summer tires. I doubt the dealer will cover it under a manufacturer defect.
Old 11-22-2013, 03:06 PM   #3
AznBRZer
Drives: 16 CBS WRX Limited
That's impossible. If it was broken to begin with, your TPMS light would've come on. I'm also betting that the shop broke it while taking off your summer rubber.
This is another reason why I buy a separate set for my winters: less chances to break something.
AznBRZer is offline   Reply With Quote
Old 11-22-2013, 03:29 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
Agree with above - if the TPMS was broken, your light would've already told you that. Shop broke it.
Old 11-22-2013, 04:22 PM   #5
andrew20195
Drives: 2013 Subaru BRZ
I agree with the above. The type of sensor/valve stem our cars use is similar to the Acura system I worked with for 7 years. I broke the first one I tried to remove a tire from. If you don't stretch the bead around the sensor, the bead will catch and break it off.
I suppose there is a tiny chance the factory improperly installed it, the sensor fell off in the tire, and somehow didn't get beat to hell rolling around inside and was still transmitting. That is not the most likely scenario, though.
andrew20195 is offline   Reply With Quote
Old 11-22-2013, 04:32 PM   #6
connorlug
Drives: #1553 10 Series FRS
The shop broke it, they will need to pay for a new factory sensor and for the dealer to program it.
connorlug is offline   Reply With Quote
My car got BROKEN into. Hiros86 Northern California 25 02-25-2014 11:33 AM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
Still not broken in Drftfan Scion FR-S / Toyota 86 GT86 General Forum 38 06-13-2013 07:51 PM
Broken into sharris721 BRZ First-Gen (2012+) — General Topics 42 04-28-2013 12:22 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
