Old 11-22-2013, 10:36 AM   #99
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by imom View Post
basically that's what you're asking...admit to a problem and issue a TSB. Once it's a TSB... all the 86 cars in the US will be coming in to get their cars fix whether they have the problem or not.
Couldn't the TSB stipulate a test method (in this case it would be rapid throttle modulation to reproduce the "firecracker" noise) to qualify for the repair? That way it wouldn't be EVERY car but rather the cars that have had failed seals. I believe that is the way the taillight TSB is worded, it isn't a blanket "if you fall within this range fix the taillights" but rather "if you fall within this range AND have these symptoms here's the procedure"
Add in an improved seal or tune to prevent it from happening again and I think most of us would be pretty happy. Hell even corporate leaning on dealerships to ensure every car that came in was covered under warranty would leave most owners satisfied.
ineedyourdiddly
Old 11-22-2013, 11:42 AM   #100
CSG Mike
CSG Mike's Avatar
If you have failed seals, you'll get the popping/firecracker noise under normal driving conditions.
Old 11-22-2013, 11:44 AM   #101
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
An improved seal or tune, aka a REAL fix, would make me extremely happy. Hell, i'd even be willing to pay for it myself.
I still would not be happy with a promise of warranty coverage because the warranty is a finite period and after that we are still on our own to deal with this significant flaw.
AyJay is offline   Reply With Quote
Old 11-22-2013, 12:05 PM   #102
strat61caster
Exactly, it'll be easy to weed out those who NEED seals and those that haven't exhibited problems yet. There are cars that have been driven hard without failure, I know you disagree but it's my opinion that it is too soon to say this affects ALL cars (as it seems that there have been very few if any cases on Automatic Transmission cars), it would mitigate the cost to Subaru/Toyota as opposed to the "fix every car!" assumption that imom made.
Not saying they should dodge the bullet, they should absolutely be responsible for repairing cars that failed under normal operation, which includes AutoX and HPDE.
Eh, manufacturers have repaired problems 'out of warranty' before because they know that a design issue exists and they need to be responsible for it. I guess a better way of saying it is to extend warranty on these components or the fuel system or whatever makes the lawyers happy. For example, Mazda extended the coverage on their rotaries to 8 years/100,000 miles, Toyobaru are totally capable of the same thing if the issue becomes widespread.
http://www.mazdausa.com/MusaWeb/disp...ownersWarranty
ineedyourdiddly
Old 11-22-2013, 12:27 PM   #103
AyJay
AyJay's Avatar
I was aware that Mazda did this with the RX-8 but it was many years into the production run before they announced this to combat the widespread perception that the car wasn't reliable.
I doubt I will wait many years into the producton run to see if the problem becomes widespread enough for Toyobaru to do something like Mazda did.
The Following User Says Thank You to AyJay For This Useful Post:
strat61caster (11-22-2013)
Old 11-22-2013, 01:04 PM   #104
strat61caster
That's totally fair, Toyobaru's loss, I'm sure many RX8 owners bailed before Mazda started making good, (and the resale value shows it).
Just trying to present a reasonable solution.
ineedyourdiddly
Old 11-22-2013, 09:38 PM   #105
imom
Drives: BRZ sold
Yeah...but that's dreaming if a corporation would go spend more money, especially on a labor intensive job as this. If a TSB was issued... how many customers would be raising their hands to change the direct injectors? I'd be one of the first...take care of my car before the engine gets damage... so it will include all the broken cars with injector problems and all the informed owners wanting theirs cars fixed before damage can be done to their cars or folks who want to drive hard or track cars...so it's going to be more then few folks demanding a fix...that's what TSB are to me...it's a green light to fix an issue or potential issue. I'm not waiting for my car engine go lean and cause more damage.
So yeah...I say it's daydreaming it'll happen any time soon. I say the constructive things is push for companies like DeatschWerks who make port injectors to make a better aftermarket direct injector...so again if this is the only issue to make the engine more robust...then it's worth the $1k+ in parts and labor.
imom is offline   Reply With Quote
The Following User Says Thank You to imom For This Useful Post:
strat61caster (11-25-2013)
Old 01-06-2014, 08:08 PM   #106
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Sorry to digress but I wonder how Toyota succumbed to issuing a recall on all those D4 direct injection only V6 engines in the IS250 and GS300 due to carbon buildup. A friend that works in a Toyota dealer told me they had to do a tear down on the engine of every car that came in with this problem (another friend's 2009 IS250 AWD was misfiring and this was done and fully paid for by Toyota). I don't see VW/Audi owning up to this problem with all the 2.0T and 4.2L V8 FSI engines on the road.
Maybe something similar will result with this DI injector seals problem who knows.
[ame="http://www.youtube.com/watch?v=sK2C0itdIDI"]2006 - 2010 Lexus GS300 & IS250 Engine Misfire Recall CSP (Repair Video) - YouTube[/ame]
krayzie is offline   Reply With Quote
Old 01-06-2014, 11:06 PM   #107
darthwong1138
Drives: Raven FR-S
Carbon buildup will not be an issue with these engines. The port injectors spraying fuel onto the top of the intake valves will keep the valves clean and prevent any carbon buildup.
darthwong1138 is offline   Reply With Quote
Old 01-07-2014, 09:03 AM   #108
krayzie
Drive From Home
krayzie's Avatar
I'm not saying our engine will have the same issue, what I mean is that Toyota and Subaru might end up having to issue a recall in a similar fashion to rectify the DI seals issue. Sorry I wasn't clear before.
The Following User Says Thank You to krayzie For This Useful Post:
darthwong1138 (01-07-2014)
Old 01-07-2014, 10:04 AM   #109
suaveflooder
Originally Posted by smbstyle View Post
9 track days on the car, no signs of the issue (no popping, no CEL, etc.)
Weird thing is, we have a bunch of FRS/BRZ owners come to the track events on a regular basis down here in the Southeast, and none of them have had this issue or made mention of it, and all but one are on the stock tune. If it wasn't for this forum I wouldn't even know it exists. We all run on 93 octane BTW; I'll sometimes throw a splash of 98 octane if I'm in a hurry at the race pumps on site.
@Dave-ROR, do you know of anyone in the area that has had the issue?
Only issues I've had with mine are the auto-dim mirror mount being loose and the HPFP crickets, knock on wood. Build date 2/2013.
I'm not worried about it; with the small percentage of failures, I'll continue to track the car and enjoy the car. If it happens it happens, and I'll deal with it if that time comes. The longer the car is out there, the more time the OEM and aftermarket has to come up with a solution, and the easier it'll be to find spare motors!
Well said!
suaveflooder is offline   Reply With Quote
The Following User Says Thank You to suaveflooder For This Useful Post:
jdubz13frs (04-11-2014)
Old 01-07-2014, 12:51 PM   #110
krayzie
Drive From Home
krayzie's Avatar
What is the ethanol content percentage for 93 octane down in the states?
Old 01-07-2014, 12:58 PM   #111
SteveGrillo
Drives: Brz
10% in every octane (in most states I believe).
SteveGrillo is offline   Reply With Quote
Old 01-08-2014, 12:43 AM   #112
bestwheelbase
Drives: 1985 P-Type
Most places "may contain up to 15%."
Some of us still seek out ethanol-free fuel. It's getting harder to find.
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 05:32 AM
Scion FRS / BRZ Issue Compilation and Questionnaire EL_to_TBD Issues | Warranty | Recalls / TSB 25 04-06-2013 02:44 PM
Nitro seal applied bacon_cheese_beer Cosmetic Modification (Interior/Exterior/Lighting) 0 11-19-2012 12:22 PM
2013 Scion Fr-S on the March Issue of MotorTrend KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 45 03-12-2012 06:25 AM
