Old 11-22-2013, 11:06 AM   #43
mike the snake
Isn't antilag really hard on the turbo and engine? Will this be an ECU-induced anti-lag, or one with other special equipment like I've seen on rally cars. I've been told the anti-lag systems on those cars pretty much self destruct the turbos and need rebuilding very often.
Originally Posted by FullBlown View Post
Yes sir, it is available for sale. We will have it on the site shortly.
Yes it will be laggy, but for drag racing it shouldn't be much of an issue. With the help of brake boosting or a rolling anti lag, it won't be too bad.
This car will be using anti lag for sure.
Old 11-22-2013, 11:07 AM   #44
Dipstik-sportech
Dipstik-sportech's Avatar
Ahhhhhh Bill!!!!!!!! Lol
Old 11-22-2013, 11:34 AM   #45
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Anti-lag will be controlled through the ecu. It is tough on the turbos but well worth it.
Not his fault this time haha
FullBlown is offline   Reply With Quote
Old 11-22-2013, 11:37 AM   #46
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
This may be a dumb question, but can anti lag be turned on and off by selecting different tune maps?
campy is offline   Reply With Quote
Old 11-22-2013, 11:42 AM   #47
Dipstik-sportech
Rolling anti lag......u have my attention
Old 11-22-2013, 12:12 PM   #48
JerryMichaels7
Drives: Whiteout FRS
screw brake boosting!! roll at 40 and just WAAAA!!!! POP DA POP POP
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 11-22-2013, 12:18 PM   #49
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Im assuming motec gives you full control of the throttle body for anti-lag as well as the injector missfireing? Correct?
WHITE is offline   Reply With Quote
Old 11-22-2013, 12:31 PM   #50
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Concerning the 8.8 rear end. LJ, do you all know the weight difference between the stock components and FBM ones? Just curious.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 11-22-2013, 12:38 PM   #51
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by SmsAlSuwaidi View Post
Any how do you know that ?
People are pushing the stock block on a 12.5:1 cr for over 10k miles with over 400whp. That thing was unheard of a year ago, because people said this motor won't handle any boost.
People also doubted many platforms and they turned out as beasts.
Sent from my IBrick
400 WHP is a far cry from 600+. That's a 300% increase in output power and stress on the motor, as opposed to the 200% of 400whp.
With an STI and it's more fragile EJ257, 600whp is a 200% increase and that severely limits its lifespan. With the stronger FA20, I wouldn't be as concerned about a 200% increase, but a 300% is sure to have its long term consequences.
When you take a motor like the FA20 and build it up that powerful for racing, you accept that you're severely limiting its lifespan and accepting that you're going to be swapping blocks after (at best) a few tens of thousands of miles. Cost of doing business there.
Facts of the game no matter the engine: when you exceed it's designed power output, depending on the design it can take it, but in so doing you're going to cut short its normal lifespan by an increasing amount the more power you continue adding onto it.
^GT5 Replay Photo Mode^
Old 11-22-2013, 12:41 PM   #52
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I can get that info for you mike, We have the OEM diff sitting on the shelf here. The 8.8 with all the guts inside weights roughly 85lbs
yes sir
The Following User Says Thank You to FullBlown For This Useful Post:
brzaapi (11-22-2013)
Old 11-22-2013, 12:47 PM   #53
Dipstik-sportech
FBM 600+HP Build
you do know the only stock items in the block are the crank and the bearings right? Because racecar
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Murseman27 (11-22-2013)
Old 11-22-2013, 01:33 PM   #54
brzaapi
CAR-AHOLIC
brzaapi's Avatar
yes sir
Thank you Sir....much appreciated.
Daily: Audi TT RS
Old 11-22-2013, 04:28 PM   #55
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Respect
Old 11-22-2013, 06:43 PM   #56
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
Oh lord this is interesting.
xDBOYx is offline   Reply With Quote
holy cow
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Max's BRZ STX Build blkwrxwag Tracking / Autocross / HPDE / Drifting 157 10-13-2014 03:14 PM
God's Build GodSays Member's Car Journals 13 04-17-2013 01:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
