Old 10-10-2013, 05:33 PM   #71
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by Scalzo View Post
can you provide prt numbers for the nrg quick release?
I believe the srk400. I wanted a thin one since I have the long standard hub.
I am actually looking into getting rid of my standard hub and the nrg quick release so I can get the short hub and rapfix. I'm 6 3 and it's a little too forward for me. Well not really but I want a short one since my arms are long lol. #tallpeopleproblems
ft86me is offline   Reply With Quote
Old 10-25-2013, 10:39 PM   #72
Shawnofthedead
Shawnofthedead's Avatar
Drives: Black on black with so much class
It all depends on the car really I had installed my wb 540 and a nardi. No matter what calibration from a shop , dealer etc or not. Mine isn't ,has nor will not turn on so I'm in full slip always living dangerously. Haha it's fairly annoying to see the amber lights blasting in my face but when I do figure it out I will make a DIY.
Shawnofthedead is offline   Reply With Quote
Old 10-25-2013, 11:36 PM   #73
JerryMichaels7
Drives: Whiteout FRS
Anyone figure out a way to rig up CC with an aftermark wheel? or is it 100 percent not possible?
JerryMichaels7 is offline   Reply With Quote
Old 10-25-2013, 11:53 PM   #74
TeamZleep
Drives: 2013 FRS/2011 TDI
I modified my hub and made a bracket inside the hub to fit the cruise control stalk.
TeamZleep is offline   Reply With Quote
Old 10-25-2013, 11:56 PM   #75
JerryMichaels7
that I would to see how you did it, CC was the main reason I haven't even really thought about getting an aftermarket steering wheel
Old 10-27-2013, 06:48 PM   #76
TeamZleep
I found the two wires for the cruise control on the other side of the clockspring. Then I pulled them back a bit to tie into the cruise control box.
Then, I took the cruise stalk apart, soldered wires to the actual board (it's not really a board, just some tabs molded in plastic connected to the plug/3 resistors). With it all apart, it's really easy to see which closed circuit controls what motion. After figuring out how all of it worked, I soldered wires to it, then put the box together with the wires coming out where the stalk used to be. I used solder/heat shrink on everything.
I kept the oem plug into the cruise stalk, and just soldered/heat shrunk the two wires before the clockspring to the two that go to the cc plug. After that, I ran the wires to two 3-way momentary switches (One switch for "on/off" and "cancel", and the other for "+ Res" and "- Set"). Then I mounted the two switches to the left of the radio on the faux carbon panel.
I used my label maker from work for now, but I will be switching to the aircraft style black/gray label to make it not stand out too much.
Kinda racecar, and I dig it so much.
Old 10-30-2013, 03:17 AM   #77
Shawnofthedead
First word of advise to anyone installing Whilst in the process of removing the steering column in no way let the clockspring leave its point of zero degree otherwise you will have to take it to the dealer and pay to have your car re calibrated and aligned fail. I placed the oem wheel back on again to reset to no avail to to the wise no wtf you are doing that DIY posted is kind of worthless or should be edited
Old 11-17-2013, 12:47 AM   #78
zlegend
yee
zlegend's Avatar
Drives: mehhhh i lost count.
Well today driving home my traction turned off and a check engine light went on... Anyone had this problem before?
I have a works bell short hub with a nrg tilt shift plus a nardi deep dish
zlegend is offline   Reply With Quote
Old 11-20-2013, 06:16 PM   #79
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Can you guys post up your set ups?
Steering wheel:
Hub:
Quick release:
I'm new to this shit and.I have no idea what to buy besides a momo steering wheel I liked
Sent from my LG-D803 using Tapatalk
Scalzo is offline   Reply With Quote
Old 11-20-2013, 07:55 PM   #80
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Steering wheel:
Hub:
Quick release:
Works Bell Normal Hub
Vertex 330mm Steering Wheel.
Still no issues...
Old 11-21-2013, 09:17 PM   #81
Knshro13
Drives: 10 series FRS
I kept cruise control with my aftermarket wheel. It was quite simple. I saw evasive's pikes peak car had a custom bracket made out of carbon fiber. Kel, who works at the shop there works great with carbon and fiberglass.
I am using works bell hub.
Knshro13 is offline   Reply With Quote
Old 12-03-2013, 01:53 AM   #82
Timtamtt
Timtamtt's Avatar
Is there a diy for installation of aftermarket hubs and qr? Just got the rapfix. Not sure which wb hub comes with resistor, I was looking to get the wb slim hub
Timtamtt is offline   Reply With Quote
Old 01-10-2014, 03:37 AM   #83
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
how do i get that kit? how much $$$?
NYCsubaruBRZ is offline   Reply With Quote
Old 01-12-2014, 09:04 PM   #84
kylefrs
kylefrs's Avatar
Drives: Scion FRS
i just took off the wheel and tried to make another wheel i got work. didn't work and showed lights all over. abs trac steering and airbag. so i just put the stock one back on. trac and abs won't go away. trac control and vsc buttons do not work. also cruise control does not work. why?
kylefrs is offline   Reply With Quote
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 12:56 AM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) — General Topics 125 04-09-2012 08:46 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) — General Topics 40 12-03-2011 10:43 AM
FT-86 concept's steering wheel Dark Scion FR-S / Toyota 86 GT86 General Forum 35 08-07-2010 06:17 AM
