Old 09-22-2013, 07:30 PM   #1
DarkSunrise
DarkSunrise's Avatar
DarkSunrise FR-S
Current Mods
Engine/Exhaust/Tune
- Perrin oil cooler +10 lbs
- OFT / E85 tune
- K&N air filter
- Mishimoto inlet tube
- OEM 2017+ header
- Perrin resonated CBE -5 lbs
Transmission
- Exedy stage 1 clutch & 12 lbs FW -8 lbs
- Verus forged clutch fork and pivot
- Whiteline trans bushing insert
Suspension/Chassis
- RCE T2 coilovers
- OEM front camber bolts
- RacerX rear swaybar adjustable endlinks
- Whiteline rear diff cradle and outrigger inserts
Wheels/Tires/Brakes
- RR Racing Stage 2 BBK / Wilwood BP20 pads [FRONT] -3 lbs
- Carbotech XP10 pads [REAR]
- Goodridge SS brake lines
- WedsSport TC105n 17x8 +42 / Federal SS595 235/40/17 (canyon) -20 lbs
- Apex ARC-8 17x9 +42 / GTRadial Champiro SX2 235/40/17 (track)
Engine Bay
- Group 151R battery (JDM tray) -5 lbs
- Verus fuel rail and DI ECU brackets -5 lbs
- Verus bellhousing cover plate
- Raceseng cam plate cover
Aesthetic
- Winjet headlights w/Morimoto XB35 HID ballasts
- JDM clear sidemarkers
- JPM Coachworks alcantara cluster hood
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Mr.Impreza (10-19-2016), p_mike_v (09-06-2014)
Old 09-22-2013, 07:30 PM   #2
DarkSunrise
Perrin NR CBE
One of the first mods I did was a Perrin CBE (non-resonated). Love this exhaust. The fitment is excellent, it looks great, and the tone is deep and has lots of texture. My only complaint is that the volume is slightly loud after it warms up fully, but nothing unreasonable.
Specs
- 2.5" diameter piping, 2.43" ID
- 304ss construction
- 29.2 lbs [stock is 38.5 lbs]
I noticed the muffler section turned a deep bronze/brown color after some extended spirited driving. I'll post some pictures later.
Old 09-22-2013, 07:31 PM   #3
DarkSunrise
<reserved>
Old 09-22-2013, 08:50 PM   #4
DarkSunrise
HPDE @ Summit Point Shenandoah
Took the FR-S to its first track days at SP Shenandoah a couple of weekends ago. I had done a number of autocrosses with it, but it was time to get it out on a full track.
Short story: the car and mods were great, better than expected even. Detailed review below. Copied (and shortened) from another thread:
Awesome 2 day HPDE at Summit Point Shenandoah over the weekend. First off, I met some great guys at BMW CCA (NJ chap), so if you ever get a chance to run with them, it's fun. I don't have a ton of track experience, but was one of the quicker drivers in my novice run group, so take this all from that perspective:
1) We ran nearly the full course with a hot pit leading to Turn 1. I've never run this configuration before and loved it.
2) The car was exactly what I was hoping for -- reliable, consistent, and fun. It was at home on a technical course.
3) Stock suspension - I was impressed by what they put into this car from the factory. Body roll was well controlled and the balance felt great. Slight understeer mid-corner, but a soft transition to oversteer with either power or lift. Really felt the sublime balance in the cave esses, the hook, the turn before bridge straight, and big bend. In autocross I always felt the car was a bit loose, but on the track, I could not imagine a more forgiving but balanced textbook RWD car. I think there is headroom for even stickier street tires.
4) Sumitomo HTR ZIII - These are not aggressive for a max performance summer tire, but they match the factory suspension well and don't overwhelm the Stoptech pads. I recommend these tires if (like me) you don't have a ton of track experience and aren't looking to set the fastest times possible. They did not get greasy until midway through the later sessions.
5) Stoptech brake pads / fluid - They worked fine. I only got mild pad fade towards the end of each day. Fluid did not boil. Running mild tires definitely helped here. With more aggressive tires, these pads will almost certainly fade IMO.
6) 100 octane - well worth the extra $100 over two days for that extra bit of protection for the DI seals. The car even missed a cool-down session when my instructor wanted to take the car out for an extra session, and everything was fine. I did have one small hiccup at idle after a red flag came out while I was WOT down bridge straight and I had to immediately stop the car with no cool-down, but it was fine after a restart.
7) Power - The car could definitely use a bit more power, especially mid-range. I did a ride-along in my instructor's M3 and the midrange torque allowed him to stay in higher gears, whereas I was downshifting like crazy in my car trying to keep the RPMs above 4500 -- to the point where my instructor mentioned he was impressed with my downshifting skills. Must be all the practice I get in this car Speaking of which...
8) Gearshift/clutch - Have to mention this. I loved how easy it was to heel-toe at will in this car. Very intuitive and the gates were precise/easy to find. I've done the clutch pedal adjustment and would recommend that.
Course map:
http://www.summitpoint-raceway.com/i...ah_circuit.gif
And a bunch of pictures:
The Following User Says Thank You to DarkSunrise For This Useful Post:
IBill4You (07-13-2015)
Old 11-20-2013, 12:12 PM   #5
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Nice!! That Shenandoah circuit is a tough one.
PoorMansRacing is offline   Reply With Quote
The Following User Says Thank You to PoorMansRacing For This Useful Post:
DarkSunrise (11-21-2013)
Old 11-21-2013, 05:15 PM   #6
DarkSunrise
Thanks! Yeah definitely tough to master, but so much fun in light/nimble cars.
2022 BRZ Build
2013 FR-S Build
PoorMansRacing (11-21-2013)
Old 11-21-2013, 05:21 PM   #7
PoorMansRacing
Anorexic
A bunch of people I've spoken with hate the circuit. NASA won't run HPDEs there because of how narrow it is and the extreme hard braking. But I'm with you - I love it. Nothing wrong with a good challenge
Old 11-21-2013, 05:29 PM   #8
DarkSunrise
Bunch of wusses! I always look forward to Shenandoah. I recently went a couple of weeks ago and it was perfect with the fall foliage.
2022 BRZ Build
2013 FR-S Build
Old 03-09-2014, 09:35 PM   #9
torqdork
torqdork's Avatar
Drives: RV-7
Beautiful photography, tremendous circuit (parts could pass for Nurburgring), inspiring writeup, thanks!
torqdork is offline   Reply With Quote
The Following User Says Thank You to torqdork For This Useful Post:
DarkSunrise (04-09-2014)
Old 05-18-2014, 10:41 PM   #10
DarkSunrise
Just got back from a two-day track event at SP Shenandoah. Incredible weekend. Couple of quick thoughts:
1. I finally got cleared for Solo (no instructor), woot! I did my last two runs on Sunday without an instructor. Very different experience, and while I've had fun with and learned something from all of my instructors, it was definitely enjoyable being out there solo.
2. My first instructor asked why I wasn't in intermediate and my second instructor flat out told me I should be in intermediate. I had no idea -- nobody says after X track days, you should be in intermediate. Wish it was more clear, but now I know I guess.
3. I played around with late apexes a lot. It was amazing to me how much a late apex opens up room for track-out. You can get on the throttle earlier/harder without running out of track. Nifty.
4. I played around more with trail-braking into the sharper corners. It does not feel like it will bite in this car, at least in the mild degree I'm using it, but it does allow for more turn-in. Not night and day, but noticeable. Felt stable.
5. On a tangent, I randomly had lunch with Jack Baruth (and a couple of other instructors). For a guy who doesn't like our cars much, Jack is pretty hilarious and tells some great stories. He was there doing a track segment for Road and Track's long term C7 Stingray. After lunch, he was like, grab your helmet and I'll give you a ride in the new Stingray. Holy hell. Baruth in the C7 is devastating. That man can drive (smooth and fast) and the new Vette is massively quick.
Only had time to snap a quick picture during grid (btw the C7 has a nice interior):
I can also say in absolute truth, I passed a car with Baruth in it multiple times.
6. Lastly, have to comment on the FR-S. It was awesome again. I will have to add camber bolts as I'm chunking/chewing up the outer edges of my tires pretty badly, but the brakes were holding up with the Sumitomos, and I would just back off slightly when I could feel the pads starting to fade.
I had an ABS light early in the morning after I managed to lock up a wheel going 100+ mph, but once I restarted the car, it was fine. Perhaps that tire was wet/cold.
2022 BRZ Build
2013 FR-S Build
torqdork (05-18-2014)
Old 08-17-2014, 10:02 AM   #11
DarkSunrise
Different car, but brought my MK6 GTI on all-season tires out to the track after a long hiatus. Drove the piss out of it. Story of the day was understeer. Corner entry, corner exit. Even with trail-braking, the car just did not want to rotate and would run wide. That said, it was fun taking a step back and lapping at 8/10ths. The car seemed better balanced just under the limit, and tire wear (melt?) evened out F-R.
One interesting thing I saw - my max speed on the back straight was only 98 mph, whereas with the FR-S, I routinely hit 103 mph. The GTI should be faster, so I would guess that's all about corner exit speed leading to the straight.
Getting absolutely destroyed by a buddy of mine driving his stage 2 TT-RS on P Zero Corsas.
Slowly chasing down an S5, but did manage to get a point-by eventually.
The GTI rolls over and play dead.
2022 BRZ Build
2013 FR-S Build
Old 08-28-2014, 08:37 PM   #12
DarkSunrise
My credit card took quite a hit this month, but things are getting rolling.
Bit the bullet and ordered a set of Wedssport TC105Ns. Size is 17x8 +42. These will be my next set of track wheels.
Going against the concave trend, but I think these look good anyway.
If anyone is interested in buying a set, @CSG Mike sells them at a great price, and it's great being able to support a vendor who's done solid track development work for our aftermarket.
Some CSG swag:
2022 BRZ Build
2013 FR-S Build
CSG Mike (08-28-2014), Hyper4mance2k (05-25-2015)
Old 08-28-2014, 08:42 PM   #13
DarkSunrise
Then I needed some new track tires to go with the wheels. 235/40/17 NT05's:
Not expecting these to be the greatest track tires, but wanted something with more heat resistance than my old 215/45/17 Sumitomo HTR ZIII's. Helps that these were pretty cheap
2022 BRZ Build
2013 FR-S Build
Old 08-28-2014, 08:45 PM   #14
DarkSunrise
To round out the handling mods, also got Whiteline camber bolts and rear differential inserts.
Thought about getting coilovers, but I barely clear the ramp to my work parking garage. I definitely can't go any lower, at least not for the time being.
Will get all of the above installed before my next track weekend on Sept. 6-7 and report back.
2022 BRZ Build
2013 FR-S Build
