Old 11-21-2013, 03:59 PM   #1
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
10 series headlights retrofit with regular frs need help!
Hey all I know this is technically the wrong section but I am pressed for time! Does anyone know if their is a quick fix for the different wiring harness setups on the 10 series headlights to make them compatible with our regular frs? I am in a situation where I have the headlights but seemingly will have to spend another thousand or so dollars to make them compatible with my car... Doesnt sound right to me, does anyone know of a fix for this? If their is any sort of wiring solution I can buy I am all ears!
thank you!!!
brandon
"Careful though, I've seen many of my friends turn from ironic bros to full on bros by accident." - cfusionpm
bdanisi is offline   Reply With Quote
Old 11-21-2013, 04:36 PM   #2
Gen
Drives: Scion FR-S
thank you!!!
brandon
Do you have the 10 series wiring harness? You have to move pins around to make it play nice with the FR-S wiring.
This details it pretty well
http://www.ft86club.com/forums/showthread.php?t=39576
Gen is offline   Reply With Quote
Old 11-21-2013, 04:39 PM   #3
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
I think that's the problem... If I get the 10 series harness will it work easily?
Sent from my Galaxy Nexus using Tapatalk
Old 11-21-2013, 04:41 PM   #4
Gen
Drives: Scion FR-S
It saves you from having to splice into the harness, but you still have to repin. There was someone on here that sold an extension that did the repinning for you, but I can't recall what his name was. Either way, it's not too bad.
The Following User Says Thank You to Gen For This Useful Post:
bdanisi (11-21-2013)
Old 11-21-2013, 04:46 PM   #5
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
OK thanks for the heads up if you think of the name I'll owe you one!
Old 11-21-2013, 05:37 PM   #6
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
http://www.ft86club.com/forums/showthread.php?t=50025
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
The Following User Says Thank You to Calavera For This Useful Post:
Will retrofit your headlights for free (read more inside) retrosmiths Exterior Parts (Aero, Lighting, Etc.) 28 10-20-2014 07:36 PM
Scion 10 series headlights gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 19 04-20-2014 11:26 PM
Will retrofit your headlights for free (read more inside) retrosmiths Southern California 9 09-27-2013 08:31 AM
Garage Sale - Headlights, lighting, retrofit parts, etc retrosmiths Exterior Parts (Aero, Lighting, Etc.) 3 08-02-2013 10:31 PM
