Old 11-21-2013, 12:13 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Coil pack part numbers?
Hey guys wondering if there is multiple coil pack numbers for the FRS/BRZ.
I have this number SU00304670 but is that the same for all 4? I assume there is no difference between these for a manual car vs auto?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 11-21-2013, 12:27 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
They all looked the same when I pulled them out of my BRZ. I don't see any reason manual or auto would make a difference.
Old 11-21-2013, 12:30 PM   #3
feldy
feldy's Avatar
How much of a pain in the ass was it? I need to replace coil one. Started to pop a p0351 code two days ago. Cleared it. Came back on cleared it again. Has not been back on since. But its also been raining so I have not driven the car hard at all.
Did your di seals go after this as well?
Old 11-21-2013, 12:44 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I pulled mine to look at my spark plugs. I lifted the motor up to gain access. It took me about 3 hours in total to pull and gap all 4 spark plugs.
Old 11-22-2013, 03:48 AM   #5
brn12345
brn12345's Avatar
SU00304670 is the revised coil after December 2012. All coils are the same for all cylinders. The older coil code ended with 00417.
brn12345 is offline   Reply With Quote
The Following 2 Users Say Thank You to brn12345 For This Useful Post:
ATL BRZ (03-11-2014), Sportsguy83 (11-22-2013)
Old 03-11-2014, 11:57 AM   #6
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Same here. P0351 last night in a WOT 2nd-3rd gear data logging pull. Cleared and could not replicate. Was idling in a parking lot for 10 minutes immediately before the pull. It's possible the coil is over heating and failing over time. Coil #1 is right above the header/OP junction. It gets pretty hot down there.
Did you replace your #1 coil yourself? If so, did you jack the engine up or use some trick tools to get it done without?
Subaru parts dept at my local dealer just gave me a part #22433AA651 for the coils
The Following User Says Thank You to ATL BRZ For This Useful Post:
RavioliG (07-17-2015)
Old 03-11-2014, 12:31 PM   #7
feldy
feldy's Avatar
No the coils can be replaced with out jacking up the motor. The passenger side is easier then the drivers side. But either way I did not do it myself. It was covered under warranty. Coil one is on the passenger side front just move the fuse box out of the way to get in there.
The Following User Says Thank You to feldy For This Useful Post:
ANyone know these part numbers? J-Money Scion FR-S / Toyota 86 GT86 General Forum 3 04-22-2013 01:37 PM
Anyone have part numbers to share? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 3 01-29-2013 03:13 PM
Part numbers 20valvewynn83 Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 07:16 AM
How do I get JDM part numbers? InstantNoodles Cosmetic Modification (Interior/Exterior/Lighting) 2 07-09-2012 05:29 PM
part numbers Staticfrost BRZ First-Gen (2012+) — General Topics 5 05-29-2012 01:02 PM
