Old 11-19-2013, 09:17 PM   #15
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Nice and clean E36. Sucks to hear about the issues but damn that thing looks mint!
Old 11-19-2013, 09:54 PM   #16
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
Drives: SWP BRZ Limited
Congrats! Those vaders are mint. Something you don't see very often
Doctor Who is offline   Reply With Quote
Old 11-19-2013, 10:12 PM   #17
ayau
Drives: Some rust bucket
Cliff notes: DGAF
The Following User Says Thank You to ayau For This Useful Post:
Dave-ROR (11-20-2013)
Old 11-19-2013, 11:32 PM   #18
KAR
Drives: Whiteout 6spd
i always wanted a white with black interior..
but here is mine
KAR is offline   Reply With Quote
The Following User Says Thank You to KAR For This Useful Post:
Old 11-20-2013, 08:52 AM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ayau View Post
Cliff notes: DGAF
This
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-20-2013, 03:48 PM   #20
KAR
Make sure you get all the chasis/suspension reinforcements so you won't have trouble in the future.. Things usually crack and fall apart
Old 11-20-2013, 04:04 PM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
All of it has been done already with one exception (but the parts were included).
Head has been resurfaced, head gasket, water pump (metal impeller), thermo housing, thermostat, recent radiator (I might replace it again anyways with either a Z3M or aluminum one), hoses, expansion tank, etc has also been done. Suspension arms have been blasted and powdercoated, new diff carrier bushings, all suspension bushings replaced. Balljoints also replaced. Rack replaced with a low mileage rack. Oil filter housing gasket, oil pan gasket and VC gasket replaced recently.
The VC is leaking again though so I'm going to replace the VC gasket set along with the gaskets on the bolts (which seems to be where it's leaking mostly) and the VANOS line while I'm there.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-20-2013, 07:14 PM   #22
MtnDrvr86
Drives: 2002 honda civic ex
The E36 Vader seats are one of my favorite seats Ive head the pleasure of driving in. The only car Ive owned that came close to them, as far as support and comfort, was my '91 Mazda MX-6 GT turbo.
MtnDrvr86 is offline   Reply With Quote
Old 11-20-2013, 07:26 PM   #23
Diode Dynamics
Diode Dynamics's Avatar
Good God man, that is a gorgeous E36 M3
Congratulations on the seemingly well-bought car
Parts get pricey though...
Nick C.
John C.
Diode Dynamics
Old 11-20-2013, 07:51 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Nick C.
Thanks. It is getting a few rust issues.. some bubbling here and there.. will likely fix it since the rest of the car seems so solid I do want to remove the yellow fog light tint. Not a fan really of that. I might swap back to the OEM taillights as well. The car is currently on some Eibach coilovers which will be returned to the PO, I have some Bilstein Sport dampers and OEM springs in the garage to install. I'll throw it up on the lift in the next few weeks to check the car out in detail.
Here's a list of some of the stufff that was done recently (within the last year and a half):
- Pioneer In-dash Nav/DVD Player Unit
- Bluetooth and microphone accessories
- XM/Sirius ready (receiver included) - Pandora Internet Ready
- Euro blue passanger side mirror replacement (no objects in mirror text on the glass) - heated
- 2 new door handle assemblies
- Rear window gaskets replaced
- OEM Bosch starter replaced (Feb 2013)
- OEM used replacement coil packs
- Spark plugs just replaced
- OEM front splitters
- New M3 front lip
- New OEM foglights with luminex yellow film
- Silverstar light bulbs in the fogs
- DJ Auto FXR Retrofit with custom E55 shrouds, custom install (looks entirely oem)
- Front Bumper/Hood/Trunk Lid were replaced with much better condition oem parts with excellent condition paint (original matching VIN panels included)
- Rear plastic trim pieces replaced
- Extra OEM dealer cut key
- AA track-pipe
- Autothority chip
- K&N air filter
- 12mm spacers up front & 5mm in rear
- Head Work Completed (June 2013)
-- Head Resurfaced
-- Head Gasket Replaced
-- Head Bolts replaced (OEM)
-- Vanos Rebuilt (DR. Vanos Stage 1)
-- Valve Cover Gasket replaced
-- Oil pan gasket replaced
-- New exhaust gaskets
- Valve cover, sandblasted and powdercoated crinkle black
- Eibach Adjustable Lower Control Arms
- Sand Blasted/Powdercoated rear subframe
- Ireland (Urethane) Diff and Subframe Bushings
- Low mileage Rear Trailing Arms w/brand new ball joints and Turner RTAB Limiters
- Differential seals replaced
- Sanblasted/Powdercoated front Control Arms with new ball joints and bushings
- Sandblasted/Powdercoated X-brace
- Brand New Lemforder Tie Rods
- Low mileage used 95 steering rack replacement OEM
- Geba water pump with metal impeller
- Thermostat
- Upgraded aluminum thermostat housing
- Sealing gaskets
- Expansion tank
- Tank cap
- Upper & Lower rad hoses (silicon)
- Radiator hose clamps
- Accessory Drive Belts
- New OEM electric auxiliary fan
- New OEM clutch fan
- Brand New Slotted and Drilled Rotors (June 2013)
- Brand New Hawk HP Plus pads (June 2013)
- Complete Flush of brake system with ATE Gold - same as super blue just gold
- Brand New OEM front pads (still in the box)
- Rogue Engineering Rear strut tower mounts
- Ground Control front Camber/Caster plates
- Strut Tower, Chassis, Suspension, etc reinforcements
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-21-2013, 09:58 AM   #25
Diode Dynamics
Wow!
Nick C.
John C.
Diode Dynamics
Old 11-21-2013, 11:53 AM   #26
Meehow86
Drives: 2013 Subaru BRZ Premium 6MT
lol, thats a pretty long list. Always loved that generation M3!
Meehow86 is offline   Reply With Quote
Old 12-04-2013, 06:43 PM   #27
Coaster
Coaster's Avatar
Drives: Civic
I have 2 question about the car.
Does it really wear out tires fast?
Is it costly to maintain/buy parts?
Really nice car though. Thanks.
Coaster is offline   Reply With Quote
Old 12-04-2013, 07:57 PM   #28
KAR
good alignment and an easy right foot will do you fine, stress on that "GOOD ALIGNMENT"
I think German cars are expensive to maintain but if you look around the net, you can find good deals, and learn how to fix things..
Thanks
Coaster (12-23-2013)
Daily Driver Problems Anthony Other Vehicles & General Automotive Discussions 28 08-30-2013 03:23 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
