Old 11-19-2013, 11:22 PM   #1
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Need help with shifter dimensions
Hey so I have this wacky idea (gated shifter) but in order to pull it off in UG and to save me the head ache of having to rip my shifter out of my car-now that it's put away for the winter. I was wondering, if anyone who has replaced their shifter with short shifter and is familiar with precision measurement, could measure their the stock shifter for me and give me as much detail as possible about length, ball/pivot height from the linkage bore, the diameter of pivot ball, width of the linkage cylinder., angle of rake of shifter from the pivot, etc....so that I can make an accurate CAD model. I hope I'm named the different parts correctly if not feel free to correct me. Thanks a lot in advance.
Gords_zenith is offline   Reply With Quote
Old 11-20-2013, 06:40 AM   #2
Gunman
Drives: 2019 Mazda Miata RF
I got nothing, just nice to see another NX cad jockey!
Old 11-20-2013, 08:04 AM   #3
Malt
Drives: 2015 WRX
I'm close to durham. Do you just want my stock shifter to measure and you can get it back to me when you are done?
Malt is offline   Reply With Quote
Old 11-20-2013, 08:47 AM   #4
mad_sb
Drives: 2013 Asphalt FR-S
measurement won't matter since the trans is mounted on soft rubber bushings and the shifter carrier is as well. In short, the shifter location WILL change with loading and unloading of the drive train and chassis.
Old 11-20-2013, 09:28 AM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
But points on the shift lever don't move with respect to one another.
Old 11-20-2013, 09:45 AM   #6
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
So you're assuming the plate will move with the transmission? That would be odd looking, like a shaker hood inside your car.
The Following User Says Thank You to SloS14 For This Useful Post:
mad_sb (11-20-2013)
Old 11-20-2013, 09:49 AM   #7
boredom.is.me
Custom User Title
I'm pretty sure the LEVER stays the same. I said nothing about any other part...
Old 11-20-2013, 11:19 AM   #8
Gords_zenith
That sounds like an idea! Where abouts you can pm me. Thanks man
Old 11-20-2013, 11:23 AM   #9
Gords_zenith
I've thought about that, haven't got to the point of figuring it out yet, just running ideas through my head, but I'm hoping with trans bushings things will be more precise. Although I'm aiming to develop something doesn't require those so I don't have to buy extra stuff. We'll see how it goes, what got me thinking about it was the R8 gate and lambo gate=pure awesome not to mention the Ferrari's of past.
Old 11-20-2013, 11:24 AM   #10
Gords_zenith
Haha well my NX4/5 skills are just wasting away otherwise, so I like to keep active on it a little bit.
Old 11-20-2013, 06:24 PM   #11
mad_sb
no, but they may move with respect to the chasis, which is what the gate would be bolted too no? Not sure if this idea would work or not but given how much i have seen shifters jump around during wheel hop I don't think so.
Old 11-20-2013, 06:30 PM   #12
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Am i mistaking when I say the diameter of the reverse lockout probably make the distance between gear changes to small to create a gated shift pattern? Yu would probably have to eliminate that reverse lockout.
BoxRZ_86 is offline   Reply With Quote
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
fog light dimensions cj1pilot246 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-06-2013 02:02 PM
Manual shifter stalk thread dimensions for knobs bcj Scion FR-S / Toyota 86 GT86 General Forum 1 03-19-2013 06:42 AM
Shark Fin Dimensions?? srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 0 08-16-2012 04:11 PM
