Old 11-20-2013, 01:28 AM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Beware: Excessive rust on suspension parts
During the process of installing my Ohlins, I'm surprised by the amount of rust I've found on the threads of various suspension pieces...
One notable piece was the front anti-roll bar endlink threads:
My car has approx 10k miles on it (10150 as of 11/19/13), and the end link bolt already shows excessive amounts of surface rust. This is probably the worst I've seen in recent cars I've owned...
Everything will come off in a couple of weeks once I let the suspension settle more, but this is something that should be addressed if you are looking to do any work on the car. I think areas with salt on the streets should pay special attention to this, as I am located in Los Angeles.
-alex
Old 11-20-2013, 02:52 AM   #2
CSG David
CSG David's Avatar
-alex
Uncoated steel will rust. Also note many components have had lots of cost reduction implemented in order to keep the base price of the vehicle low. Use some WD40 to clean up the threads and coat it with anti-seize. This will reduce the wear on it and provide a layer of corrosion prevention coating on it.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
B L U E S L A T E (11-20-2013), RehabJeff86 (11-21-2013)
Old 11-20-2013, 03:00 AM   #3
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Somebody showed me this when we were talking about rusty camber bolts.
Looks like an awesome product.:
[ame="http://www.youtube.com/watch?feature=player_embedded&v=DZrjXSsfxMQ"]http://www.youtube.com/watch?feature=player_embedded&v=DZrjXSsfxMQ[/ame]
Intent > Content
Old 11-20-2013, 03:17 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
A lot of rust stays at the surface and is pretty much harmless.
Old 11-20-2013, 03:30 AM   #5
mav1178
mav1178's Avatar
... it's not just the endlinks, there's several other areas as I noted.
In any case, surface rust is surface rust, but one should be aware of them when working on suspension.
Of interest: the wheel studs also showed rust, but inconsistent across different studs. I know someone else had virtually new stock studs snapping, and there may be some rust buildup in there.
Either way, threads like these should be cleaned up when the opportunity presents itself. Rust may not be an issue, but rust buildup + lack of cleaning may lead to seized bolts/damaged threads later on if left unchecked.
-alex
Old 11-20-2013, 11:19 AM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
That vanishes through time, even more so when subjected to heat and cold.
Old 11-20-2013, 12:24 PM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
that's japanese steel for ya..
poke undernearth an Audi or Merc, won't find that type of degredation.
Old 11-20-2013, 12:28 PM   #8
CSG David
CSG David's Avatar
Cheap Japanese steel.
It's just the composition make up of the material and the lack of "exotic" materials. When planning a project, this is what keeping within budget means.
Old 11-20-2013, 12:33 PM   #9
mav1178
mav1178's Avatar
I wish that were the case, but the ~7+ Nissan/Infiniti vehicles I previously owned + the last 2 Toyotas never showed this level of surface rust after 5 months and 10k miles.
This is a very minor thing, but again it's an issue that needs constant monitoring whenever you work on the suspension. Or this is just an excuse to get aftermarket endlinks.
Well played Subaru, well played...
-alex
Old 11-20-2013, 12:42 PM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Infinity is a higher level than Subaru...
and AFAIK these are subaru bolts and nuts...
Old 11-20-2013, 12:54 PM   #11
mav1178
mav1178's Avatar
Infiniti and Nissan uses the same hardware/fasteners, just because it's a "luxury" brand doesn't mean the basic hardware is a higher quality.
And yes I am fully aware these are Subaru hardware. I guess the main point I'm making here is, 1) this seems to be excessive for 10k worth of driving in 5 months (keep in mind the car is garaged when I'm home), and 2) it would be wise for anyone to clean up thread rust whenever they work on their suspension.
-alex
Old 11-20-2013, 01:22 PM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
-alex
i get surface rust on OEM subaru nuts/bolts in less than a week of driving, it is what it is.
Excessive Rust? video inside BRZnut BRZ First-Gen (2012+) — General Topics 45 03-12-2014 07:53 PM
NEW Brake and Suspension Parts for sale! seven Brakes, Suspension, Chassis 12 02-27-2013 12:31 AM
AVO suspension parts for the BRZ/FRS AVOturboworld Brakes, Suspension, Chassis 11 10-09-2012 10:43 AM
AVO suspension parts for the BRZ/FRS AVOturboworld Brakes, Suspension, Chassis 0 06-21-2012 06:25 PM
