Sam Strano
Old 11-13-2013, 12:24 PM   #309
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by 7thgear View Post
our local autocross organizers have Yokohama as a major sponsor.. we all might get really good deals on the AD08r.. but from what i gather this tire doesn't stand up to the price and utility of the new Dunlops or RS3s
thoughts?
I've scoured internet forums for feedback from top-level autocrossers on the performance of the AD08R, but I haven't seen much of anything. It seems the cost is just too far above the other tires in the category and the TireRack testing didn't seem to indicate they were any better than the Z2s, RE-11s, or Rivals. The 225/45/17 size averages about $40-$50 more per tire than the competition, so it just doesn't seem worthy of the plunge. If you can get them for a discount, we'd love to hear your feedback!
jprice130 is offline   Reply With Quote
Old 11-13-2013, 01:27 PM   #310
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Agreed.
@7thgear if you can get the AD08R for a price closer to what the other tires cost, it's worth trying out.
G_Ride is offline   Reply With Quote
Old 11-15-2013, 04:48 PM   #311
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by JRTritsch View Post
BTW has anyone tried the Toyo in RTR? I'm leaning on trying both the Z2 and the Toyo next year but I won't bother with the Toyo if it will just get destroyed by the lack of camber.
I've tried it on our 7" rim. Grip was fantastic. Took a while to get used to the Toyo vagueness, but the times were there! Wear was shocking. I wouldn't consider running them for a full season, as they would not last. It would be interesting to use for a Tour event. The tire is fast and the grip is there.
225/45-17 size was tested.
For the Toyo to last as long as the Z2 or Rival, it needs to be squared up or even a bit stretched...with more front camber, IMO.
Now only if we had a a plus 1" in wheel width option instead of diameter...
simpleisbest is offline   Reply With Quote
Old 11-18-2013, 10:17 AM   #312
mrazny
Drives: BMW 135i, soon to BRZ
you wouldn't be in C-Street...
mrazny is offline   Reply With Quote
Old 11-18-2013, 11:41 AM   #313
simpleisbest
Senior Citizen
Drives: Scion FR-S
Hmm...I think I read the rules. Why do you say that?
Old 11-18-2013, 06:22 PM   #314
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
He's saying that an extra inch would move you out of C Street. I don't think he understood what you were actually saying.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 11-19-2013, 12:15 PM   #315
mrazny
If you think that the wheel allowance should've instead been +1 width instead of +1 height, then the cars would be classed accordingly. The SAC recommendation would likely bump the twins relative to other cars.
The Twins' gains for the extra inch would be more than other cars gains. the 7" is part of why the grouping is what it is.
The Following User Says Thank You to mrazny For This Useful Post:
simpleisbest (11-19-2013)
Old 11-19-2013, 01:17 PM   #316
jetfire
Drives: DGM BRZ
if you go 18s with the proper rubber to go up a size, you're effectively raising your center of gravity
so i wouldn't see this as a benefit
16s on the other hand...
but i gather the tire sizes equal out anyway so there is no point
17s it is
i would imagine the increase in center of gravity would be negligible vs. the grip improvement you'd get from running 18's?
jetfire is offline   Reply With Quote
Old 11-19-2013, 01:56 PM   #317
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
why would you think you'd be getting any significant grip increase from going up to 18's?
which isn't to say there isn't.. but there are a few things that need to be kept in mind
the forumla isn't that black and white
Old 11-19-2013, 02:08 PM   #318
dsgerbc
Drives: BRZ(sold), STI
What center of gravity? If you keep the OD the same, you'd have the same CG.
The rotational inertia of the rim matters a bit. If you move the thick aluminium band of the rim's barrel within your tire/wheel combo an inch further from the center (somehow keeping the weight the same), you'd increase rotational inertia by %10%. I think it takes about 5-6hp to accelerate all four wheels at WOT. With 18" rim you'd have 0.5HP less going to toward acceleration. Peanuts, if you ask me.
Grip increase? Hm. Maybe a bit sharper turn-in, if you go with tires with lower sidewall, keeping the overall diameter the same.
Old 11-19-2013, 02:16 PM   #319
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the arguments are assuming the relative tire size goe sup along with diamater for a change in gearing.
Old 11-19-2013, 02:30 PM   #320
dsgerbc
I guess in practice you're right, there aren't any decent options of preserving the overall diameter with going to 18".
Old 11-19-2013, 09:10 PM   #321
simpleisbest
Senior Citizen
Drives: Scion FR-S
Personally, I think other cars in our own class will gain much more vs the twins with the current allowance rule and become much faster as a result.
I guess we'll find out this year how the SAC's wise decisions with regards to classing turn out. I think that we will have an uphill battle with the 370Z and only have a slight advantage on tight and heavy transition courses. It will be rough at many regions around the nation, including mine.
Needless to say, I can't share your faith in the SAC's ability make smart decisions and balance the classes. Just look at the poor souls with non-M3 BMWs in F-Stock/Street!! It looks like a virtual garbage dump sunday with the M3's on top.
Old 11-20-2013, 02:55 PM   #322
mrazny
had a long post, the site went into maintenance...
Classing is about strong classes, not doing the best for every submodel of car. If "A" bmw and "A" mustang are in the hunt, F Street did it's job.
The SAC job is huge, with SEB oversight and wishes along with balancing newer driver needs, established driver needs, overall parity, and quality of competition. Those are solid guys putting in a ton of work for whats a thankless job.
They do better than most give them credit for.
All i can say about wheel width or *any* rules allowance... be careful what you wish for. STX heavy cars wanted more wheel/tire, they got bumped to STU. There's just not room for everyone to get what they want unfortunately. NASA classing doesn't work.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
