Old 11-19-2013, 12:02 AM   #43
whataboutbob
AutoX-10/10ths every run
Originally Posted by SubiePig View Post
Not as bad as you would think. If can take the first 3 and stand them up on the back one at a time, its a bit tight on the sides but I bought some Tire Rack bags so they don't mess up the interior next time. The last one I put on the trunk off to the side. Still have room for a jack, tool bag, and overnight bag for trips. I put a set of 225/17's in there this weekend and they fit MUCH easier.
For me the proper loading is 2 vertical behind the passenger seat, 1 horizontal behind the drivers, and on horizontal in the trunk. Fit gear around as appropriate.
Build thread:Here
Old 11-19-2013, 07:54 AM   #44
Stevo22
Stevo22's Avatar
Drives: GR86
Car looks great. Thanks for the high res pictures. What are you new alignment specs?
Stevo22 is offline   Reply With Quote
Old 11-19-2013, 08:14 AM   #45
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
3.3 degrees front 1/8th toe out
2.5 degrees rear 1/16th toe in rear.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following 2 Users Say Thank You to SubiePig For This Useful Post:
haison (09-05-2014), levifig (03-13-2014)
Old 11-20-2013, 03:29 PM   #46
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Do you know how much you're lowered from stock?
eSOLOR is offline   Reply With Quote
Old 11-20-2013, 05:04 PM   #47
SubiePig
About a inch in the front and 3/4" in the rear
Old 11-20-2013, 05:34 PM   #48
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Those wheels are beautiful. I reckon need these.
Anthonytpt is offline   Reply With Quote
The Following User Says Thank You to Anthonytpt For This Useful Post:
SubiePig (11-26-2013)
Old 11-20-2013, 06:57 PM   #49
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
With the +35's and 245/40/s, is there ever a concern with the fender rubbing the outside of the tire during hard cornering? It seems like they stick out a bit too much?
Still can't decide between +35 or +45...
Aznsky is offline   Reply With Quote
Old 11-20-2013, 08:52 PM   #50
Eric1855
Drives: LP DSP / CSP '13 BRZ
I've never had a problem with rubbing on +38s (17x9 and 245/40s) with stock suspension or coilovers.
Eric1855 is offline   Reply With Quote
Old 11-21-2013, 08:41 AM   #51
SubiePig
I have 255's on them and they don't rub at all on the fender. I looks like the tire rubs the fender liner at the front inside of the wheel well at full lock but just barely.
Old 12-09-2013, 08:42 AM   #52
SubiePig
Did the BRZ's first track day this weekend at MSR Houston. Car felt great, need brake pads badly as the end of the last 2 sessions the brakes were getting pushed really hard. I ran a 1:48.1XX in the last session, the car would be in TTD for NASA Time Trials, the record lap on that track right now is a 1:49.813...1.7 seconds slower.
Old 12-09-2013, 08:56 AM   #53
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Nice! Look into some DS2500s for awesome mix-duty pads that don't dust too much. Mine are awesome for RTR/CS and hard driving. I ran AX6 on track days and while amazing on track, they were too touchy for autocross, not enough modulation.
Assuming you did brake fluid already?
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 12-09-2013, 09:36 AM   #54
SubiePig
Sure did, I have ATE Blue! I put it in when I did the Chasebay's stainless lines.
I am leaning toward Carbotech XP10's but I will see what happens, I have till the end of next month.
Old 12-09-2013, 10:02 AM   #55
Kido1986
Dodging cones
Kido1986's Avatar
If you're interested in better, lighter rotors to go with it, I have some DBA 4000 T3s I'm not using (3000 miles, 5 autocrosses, no track), just with some surface rust I need to clean (garage had a small flood :/).
I can't imagine the XP10s would work well autocrossing a light(ish) car. If the 6 was any indication, you'll have a switch for a brake pedal at autocross speeds/grip levels. On the track though, I'm sure they will be epic.
Old 12-10-2013, 02:41 PM   #56
SubiePig
Chasing down the Vette around MSR Houston.
[ame="http://www.youtube.com/watch?v=OKWE_vIoLOI&feature=share&list=UUALlMc16gV tUiEC_ILWb2EA"]Front Straight at MSR Houston - YouTube[/ame]
God's Build GodSays Member's Car Journals 13 04-17-2013 01:31 PM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 04:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 03:40 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 05:52 PM
